dajefortee
Raspberry pi as packet sniffing tool
Wed Apr 24, 2019 1:59 pm
I have a school project and the aim is to load test a Rpi as a packet sniffing tool.
I'm looking for a tutorial or advice.
For now, I just connected two laptops via ethernet cable with the Rpi but I do now know how to start packet exchanging....any suggestion?
B.Goode
Re: Raspberry pi as packet sniffing tool
Wed Apr 24, 2019 2:35 pm
Welcome to the Raspberry Pi forums.
General advice: before you can meaningfully 'sniff' (ie. monitor) the traffic on a network it is helpful to have a basic understanding of the data communication protocols being used on that network.
For a network composed of two Linux workstations the usual choice of protocols would be those known as TCP/IP. But this is not mandatory.
Wireshark and tcpdump are two tools commonly used for network monitoring.
dajefortee
Thu Apr 25, 2019 8:08 am
Great!
I managed to connect two Windows workstation, changing the protocol setting.
Now the two computers are connected and communicate, in between there is my Rpi. Now how can I monitor the traffic, I found out something about Wireshark but each suggestion is welcome.
Thanks for the great support!
hesam_m
Thu Apr 25, 2019 12:37 pm
Maybe there are some python libraries to work with Network protocols
DarkPlatinum
Contact: Website YouTube
Thu Apr 25, 2019 12:39 pm
Great!
If you planning on using the Raspberry Pi for cyber security reasons, I would recommend looking online for Kali Linux on Raspberry pi image. (Sorry don't have a link on hand)
1 * Raspberry Pi Zero W, 1 * Raspberry Pi 2, 1 * Raspberry Pi 3 1 * Raspberry Pi 3B + :mrgreen:
Check Out My Raspberry Site (Run on a Raspberry Pi 3B :) ): https://html.dynu.net
omegaman477
Fri May 17, 2019 7:57 am
Just remember that the RPI Ethernet interface is actually connected to the CPU via r=the sad old USB2 bus. So your not going to get Gigabit/s throughput. With good efficient sampling code, the 3B+ CPU will likely outperform the ethernet NIC. So your limitation will be because of the NIC.
A good article on RPI Ethernet speeds. https://www.jeffgeerling.com/blogs/jeff ... networking
..the only thing worse than a stupid question is a question not asked.
