Page 3 of 3
Re: Beta Boards mechanical data
Posted: Wed Apr 18, 2012 5:33 pm
by killor
Now a seller on ebay has given me this information:
..."Dimension x (ethernet / usb mini usb side to side) 84.81mm
Dimension and (sound / video to hdmi side) 55.92mm
Board is 1.5mm deep
Overall height (from top to bottom of usb connector adapter of sd cardis around 22mm)
ethernet port overhangs by + - 1.5mm
overhangs by port usb2 + - 7.5mm
overhangs by 6.7mm analogue video".....
Wait someone with more confidence  :-((
Posted: Sat Apr 21, 2012 9:08 pm
by Gert van Loo
Just curious: with all the PIs out there has anybody now checked/verified my measurements?
Posted: Sun Apr 22, 2012 9:44 am
by HansH
I get from different people different measurements...
85.0 x 56.17  but also  84.9 x 55.9
Not heard yet anybody about the component positions and sizes
Posted: Mon Apr 23, 2012 10:27 am
by killor
I have a forum member that has an RPI and asked to verify your measurements and I must say are quite accurate,
Bone you've done a good job!
Posted: Mon Apr 23, 2012 2:03 pm
by arm2
Can someone with a production board please confirm how far the largest component on the underside protrudes?
It is probably the SD card holder but the lugs that hold the USB sockets in place don't look small. I've seen everything from 1.9mm to over 5mm for various brands/models of SD holders.
I would think a vernier gauge would be needed!
Posted: Mon Apr 23, 2012 2:49 pm
by HansH
My case from thingiverse got printed and I am told it fits perfectly after adapting the pcb width.  The pcb width is reported from 55.9 – 56.19
So far I know nobody changed the component positions, so everything is confirm Gert measurements.
I use 3.5 mm as sd cardholder height...
Posted: Tue Apr 24, 2012 11:13 am
by raspi
I just designed my Raspberry Pi case and I am going to get a set of 5 made initially. If all proves well I shall produce more if there is a demand for them. There WILL be a 20% donation made to the Raspberry Pi Foundation on any profit.
Please look and comment at: raspi.co.uk
Thank you.
Posted: Wed May 02, 2012 2:06 pm
by LMWmichael
Hi All
New member, just used the dims here to create a solidworks model of the Pi
if anyone is interested i'll upload it to 3D content central for people to try out
waiting for my Pi to arrive, which should be the end of the month to tidy up dimensions and connector/part positions
feedback greatly appreciated
<img src="image/png;base64,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
Re: Beta Boards mechanical data
Posted: Wed May 02, 2012 2:12 pm
by LMWmichael
sorry about the previous pic, its a bit big try this instead
Posted: Mon May 07, 2012 1:25 am
by Lolo34140
I'm currently working on the CAO Pi board production dimensions. I near finished to draw and to place all the connectors and parts present on the Pi board.
I will share the dimension as soon as finish on my website : http://freakyshape.com/
Posted: Fri May 18, 2012 12:16 pm
by Lolo34140
You can download my Raspberry Pi board dimensions here (.STL):
http://freakyshape.com/raspberry-pi-boa ... ical-data/
I hope it will help all those who need this musearements.
Posted: Fri Sep 14, 2012 12:35 pm
by eightbit
Hi Gert,
can you please renew the drawing with measurements from current production boards, including the mounting holes of the modB rev2 board?
Thanks in advance,
eightbit
Posted: Fri Sep 14, 2012 1:38 pm
by jamesh
eightbit wrote:Hi Gert,
Thanks in advance,
eightbit
I'm pretty sure Gert won't have time to do that, but if someone out there with a rev2 would like to oblige...
Posted: Tue Jan 15, 2013 8:11 am
by Gert van Loo
Done,
very late reply, I know, but it is done now.
Posted: Mon Apr 22, 2013 7:32 pm
by jtisdo
Gert van Loo wrote:Done,
Gert,
Is that what's in the top section of this post?
I am wondering if you could add the following to it.
Location of the P1, P5 and P6 -- just the Pin 1 location from 0,0
Posted: Sat Apr 27, 2013 1:22 pm
by Gert van Loo
No I can't do that.
It sounds strange but the reason is simple:
I have provided all measurements using a simple digital caliper.
If I indicate the pin-1 that information is likely to be used in PCB design.
(I think that is also the reason why you asked).
A digital caliper is not accurate enough to provide that data.
I will have to ask the foundation (especially Pete Lomas) for the
Gerber database. From there I can give figures exact enough for PCB design.
I am, not sure they are willing to give that data out.
Posted: Mon Apr 29, 2013 12:55 pm
by TonyD
Gert, many thanks for updating the drawing.
Any chance someone could post it as a file attachment as scribd is asking for $9 to download it :-(
Posted: Mon Apr 29, 2013 5:07 pm
by Gert van Loo
That should be incorrect. I posted it as free.
I will have to look into that.
Posted: Mon Apr 29, 2013 6:45 pm
by Gert van Loo
TonyD wrote:Gert, many thanks for updating the drawing.
Can anybody confirm this?
It is free to me but then it is also in my account so I can't reliably check this.
Posted: Mon Apr 29, 2013 9:21 pm
by rurwin
I can confirm it
I clicked the download button on the page...
I skipped the login...
And then I got a payment required page...
Posted: Mon Apr 29, 2013 10:01 pm
by Gert van Loo
Now that REALLY pisses me off!
I do all the work and somebody else is cashing in on it!
I will take action but sometime tomorrow after I am calmed down and had a good nights sleep.
Posted: Tue Apr 30, 2013 12:40 pm
by liz
Gert is currently jetlagged and cross, but he'll be sending me a PDF later on today, and I'll get it hosted here instead.
Posted: Wed May 01, 2013 1:31 pm
by TonyD
Thanks Gert & Liz
