digitalfriction
iphone screen
Wed Sep 19, 2012 9:57 am
I have read on a wiki that the RPi should be able to connect to an iPhone screen?
I have a broken iphone 3GS, where the lcd is fine. Can anyone point me in the right direction to wire the display up?
Andy
ghans
Re: iphone screen
Wed Sep 19, 2012 10:02 am
That info is incorrect.
It is impossible. For your own sake , stick with a HDMI or DVI screen.
ghans
mikerr
Re: iphone screen
Wed Sep 19, 2012 10:05 am
Not possible, but the following facts may have confused you into thinking that way:
digitalfriction
Re: iphone screen
Wed Sep 19, 2012 10:09 am
I dont want to go down the route of a DVI/HDMI screen, I am looking for something more like this:
http://www.youtube.com/watch?v=LDw7oB-axzs
or
http://www.youtube.com/watch?NR=1&featu ... a-n1S4gSzw
are there any guides on connecting generic small (upto 5") displays to the RPi?
Is composite the only way these screens will connect?
RaTTuS
Contact: Twitter YouTube
Re: iphone screen
Wed Sep 19, 2012 10:19 am
no you will be able to use the DSI at some stage in the future
or you can use a small HDMI screen
Covfefe
hackerseraph
Re: iphone screen
Sun Sep 24, 2017 3:06 pm
ghans
Raspberry Pi developers, doing the "impossible"
https://www.youtube.com/watch?v=vCWGMM00ZEk << Raspberry Pi driving an Iphone 4 LCD
mahjongg
Re: iphone screen
Sun Sep 24, 2017 7:02 pm
In this case wiring up the display involves an expensive interface that converts from HDMI to the specific flexible PCB (FPC) signals of this particular display, in fact it has all the electronics of an LCD monitor, and only uses the LCD from a tablet instead of a normal LCD panel. And as any other tablet display uses a different set of FPC cables, so you will need a different interface board for each tablet screen, and it must be exactly the right one.
This is just an expensive commercial solution, its NOT a "simple way to wire up the display to a PI" as was asked by the OP, so yes the answer stays NO, unless you want to pay big bucks for an adapter to convert the LCD into a full HDMI monitor, and the expertise to find *exactly* the right adapter board for the LCD. And NO, there is no simpler/cheaper way to interface this LCD to a PI.
it also doesn't need any special skills, just the money to buy the commercial solution.
