Page 18 of 19
Re: Modifying a 3.5" car display for USB power.
Posted: Mon Jul 03, 2017 3:17 pm
by MathiasRyan
Lordasriell wrote:Hello,
i didn't have the same board as you, but i was able to make it work at 5.2v.
The Step-Down Converter ,wich is a JW5022 (datasheet here) output 5v on pin 3 (see datasheet), so by putting 5v directly on this pin it will work like a charm ( maybe i can take of the chip too ?)
http://imgur.com/3VDslSd
the board itself (i don't think i have seen it in the topic ?)
http://imgur.com/bIwEC5f
the JW5022 Synchronous Step-Down Converter (sorry i took the picture after the mod so we can't really see the name)
http://imgur.com/ds6Iu6b
The screen working with a Pi zero w, both on a gba sp battery. (850mha, maybe a little bit low :| )
i thought this might help someone ^^
I have the same screen as this. I found another link online that shows this chip removed. Have you tried it?
http://www.sudomod.com/wiki/index.php?t ... #Variant_9
Also can the set of three buttons be removed from the screen if only one AV source is being used? Should the board detect which AV line is in use?
Posted: Wed Jul 12, 2017 3:40 pm
by lexgamer
I need your help :(
I try to run a screen with this type of card.
http://hpics.li/f5dce1b
It turns on, flashes, displays colors, sometimes I see the interface of Recalbox.
Can you help me to soluttion this problem how can I do to power it in 5v?
Thank you
Posted: Thu Jul 13, 2017 7:19 am
by BMS Doug
lexgamer wrote:Hi,
I need your help :(
Thank you
We would need better pictures / data from the card.
We need to identify the voltage regulator used, discover it's output voltage and how to bypass it (if necessary.
There is one 8 pin chip and 2 6-pin chips, please post the chip identifiers from those.
Posted: Thu Jul 13, 2017 6:43 pm
by lexgamer
Hi Doug,
I hope its enough
http://hpics.li/b0bd100
Posted: Fri Jul 14, 2017 7:27 am
by BMS Doug
lexgamer wrote:Hi Doug,
I hope its enough
Hi LexGamer
It looks like a 25Q40 (the 8 pin chip) is 4M-Bit flash memory, one to the 2 six pin chips must be the voltage regulator.
Posted: Sat Jul 15, 2017 8:05 pm
by lexgamer
How can I test what chip is right? Is this risky?
A ship is 02683
EDIT : It's ok that works !! the left ship is regulator voltage .
Thank you for your help :)
Posted: Tue Aug 22, 2017 7:42 am
by c_roemer
A ship is 02683
@lexgamer, can you tell what you did to make it work?
i have a little struggle with the board version, and i don't know if it is broken by now.
thanks in advance
Christopher
Posted: Thu Aug 24, 2017 9:31 am
by Hiroc80
Hello guys. I bought the BW auto monitor from Amazon. I connected the monitor to my Rasberry Zero but it does not work. Does anyone know how I can modify it to 5V? Attach the monitor photo. Thank you :)
Posted: Wed Aug 30, 2017 8:35 pm
by Scionsamurai
Hello all,
I have this board.
5" reverse monitor pcb https://imgur.com/gallery/4K83d
I'm having trouble getting it to run off of 5v. It's a 5" reverse monitor. The 8 leg(pin?) Chips are labeled "MK 25D40BTIG 1717" (located in the middle of the board) and "Toehcode TD1519A FB516462" (side of pcb: there is a scratch on the or in the first word and B516 of the last word. Used best guess to get those so they might be off)
Any assistance would be greatly appreciated and sorry if this board was already addressed and I missed it.
Posted: Fri Sep 01, 2017 9:16 am
by BMS Doug
Hello all,
I have this board.
The TD1519A is the voltage regulator. Measure the output voltage from pin 3. and let us know what it is.
Posted: Fri Sep 01, 2017 9:18 am
by BMS Doug
We'd need to know about the voltage regulator chip to help.
Posted: Sat Sep 02, 2017 12:46 am
by Scionsamurai
Thank you for the reply BMS Doug!
I'm not sure if i'm in need of a new(decent) multimeter. I wasn't getting any reading from 1,3,4,5,6, or 8. I was getting in between 3.7 and 4.8 on 2 and 7.
Posted: Mon Sep 04, 2017 1:34 pm
by BMS Doug
This was when you were feeding it from a 5V supply?
Please connect a 12V supply to the board for testing purposes and tell us the voltage output on pin 3.
Posted: Mon Sep 11, 2017 10:19 pm
by cmiles74
I believe I have this same unit. I think the label on the part is: MK, 25040ATIO, 1645. I'm not a big electronics guy, but this looks like the right part.
https://photos.app.goo.gl/XIZ2kUxLp210WMSD2
Posted: Sat Sep 16, 2017 2:05 pm
by robbaz
Hi guys, I got the same BW screen board and I tried to check the two 6-pinned chips looking for the voltage regulator as BMS Doug said. I searched online for their datasheets without success. One is labeled as O26B3 and the other as JWBV 795D. I think that the second one is the voltage regulator. I supplied the board with 12V and these are voltages on each pin.
Can you help me to understand how to power this screen with 5V?
Posted: Mon Sep 18, 2017 8:27 am
by BMS Doug
I Agree that the JWBV 795D is the voltage regulator, I was also unable to locate a datasheet.
The voltage regulator will have a recognisable set of inputs and outputs, the first 4 are likely to be present on most voltage regulators:
Vin (Input Voltage)
Vout (Output Voltage)
En (Enable)
Gnd (Ground)
The remaining pins are more varied, possibly:
Fb (Feedback)
BS (Bootstrap)
These Voltage regulator datasheetsmight give an idea of what to expect although it doesn't entirely match.
Pin 1: 6.2V (Vout?)
Pin 2: Gnd (Gnd)
Pin 3: 0.8V
Pin 4: 9.7V
Pin 5: 12V (Vin)
Pin 6: 2.7V (FB?)
Posted: Mon Sep 18, 2017 8:29 am
by BMS Doug
I would suggest feeding the board with a reduced voltage and seeing how the voltages change, try 9V if you can.
Posted: Wed Sep 20, 2017 6:16 pm
by robbaz
Hi BMS Doug, at the moment I don't have a 9V DC supply reliable at home so I tried with an higher voltage, 24.4V. I hope this will help anyway!
These are my measurements:
Pin1: 7.18V
Pin2: gnd
Pin3: 0.78V
Pin4: 20.2V
Pin5: 23.7V
Pin6: 2.98V
Posted: Thu Sep 21, 2017 7:41 am
by BMS Doug
Pin1: 7.18V
Pin2: gnd
Pin3: 0.78V
Pin4: 20.2V
Pin5: 23.7V
Pin6: 2.98V
Pin 1: 7.18 (was 6.2V) (Vout?)
Pin 2: Gnd (Gnd)
Pin 3: 0.78 (was 0.8V)
Pin 4: 20.2V (was 9.7V)
Pin 5: 23.7 (was 12V) (Vin)
Pin 6: 2.98 (was 2.7V) (FB?)
Not that there was any doubt but Pin 5 is confirmed to be Vin.
Pin 1: Vout?
Pin 2: Gnd
Pin 3:
Pin 4: Enable
Pin 5: Vin
Pin 6: FB?
I'm pretty sure that Pin 1 is the output and Pin 6 is the feedback, how can we prove it?
Its time to step up to destructive testing:
If we disconnect pins 1 and 6 from the circuit board but leave enough connected to the chip we should see one of them drop to 0v (the feedback pin) and the other increase to near the supply voltage (the Vout pin).
Posted: Thu Sep 21, 2017 8:33 am
by BMS Doug
If Vout is 6.2 - 7V then there is no guarantee that a 5V supply will be enough to drive it.
Posted: Thu Sep 21, 2017 5:08 pm
by robbaz
Pin 2: Gnd (Gnd)
Pin 1: Vout?
Pin 2: Gnd
Pin 3:
Pin 4: Enable
Pin 5: Vin
Pin 6: FB?
Yay, destruction time! :D Have you any tip about how to disconnect only those pins on this tiny component (other than probably phisically remove them forever with a cutter)?
Searching on another forums I also found this thread where a user suggested to completely remove the chip and connect 5V directly to our pin6 (feedback?) but another user tried this mod and did not succeed (maybe because he said that already fried the screen before).
What do you think about?
Posted: Fri Sep 22, 2017 7:31 am
by BMS Doug
I read that thread but am unconvinced in light of your voltage readings. if pin 6 is showing 2.7V (one of the common output settings for a voltage regulator) then the output voltage from the chip pretty much has to be either:
2.7V (which you read from pin 6) - which would mean that 5v is twice the designed output voltage and very likely to destroy the board.
or:
~6V (which you read from pin 1) with a voltage divider circuit producing a Feedback value on Pin 6 (which I think is the more likely). In this case putting 5V on pin 1 would reduce the voltage regulators output to 0.
Industrially produced boards tend to use a high melting point lead free solder, If you wish to de-solder the pins and pull them away from the board I would dilute the solder holding them to the board with a low melting point solder (such as chip-quick) and then bend them clear. The price of Chip-quick doesn't make it very economical for single usage purchase, possibly using a normal lead alloy solder would serve the same purpose (although not quite as well).
This video is a good guide to de-soldering.
Posted: Fri Sep 22, 2017 8:06 am
by robbaz
or:
Ok! I got the same impression reading that thread.
I'll try to desolder that chip! I was concerned about how to desolder just two of those six pins but I'll try and I'll let you know as soon as possible! Thank you ;)
Posted: Wed Nov 01, 2017 9:08 pm
by tamrielx
Images aren't displayed for me : [
Posted: Mon Nov 06, 2017 8:51 pm
by MathiasRyan
Just to update on this. I only tried to get this screen working today. I soldered the 12 volt power line of the screen to the 5 volt pad underneath the USB power of my rpi zero. After an initial amount of flickering the image stabilized. The screen appears to work without any modification.
