pcmedicjax
Reboot to specific OS based on command
Tue Feb 02, 2016 12:10 am
Is there a way to run a command via ssh that will reboot the RPI2 to a specified OS.
Scenario:
I have an RPI2 with BerryBoot and 3 OSes on it. Raspbian, Openelec and Retropie.
Openelec is the Default OS right now.
What I want to do is if I am watching a movie in kodi and want to play a game after that I want to be able to use my smartphone with raspSSH to tell the RPI to reboot to Retropie. or Raspbian if i want to surf the net.
elatllat
Re: Reboot to specific OS based on command
Tue Feb 02, 2016 3:11 am
Yes you can edit
root=/dev/mmcblk0p2
in
/boot/cmdline.txt
though replacing all of boot is recommended
You can also add a button to do that for you in kodi with "Advanced Launcher".
SBC with 32GB RAM: https://hardkernel.com
FAQ : https://raspberrypi.stackexchange.com
Unanswered: https://www.raspberrypi.org/forums/search.php?search_id=unanswered
pcmedicjax
Tue Feb 02, 2016 3:40 am
I don't think I understand your reply. I am looking for a simple command line thst can be sent via ssh ie;
sudo reboot os1 or
sudo reboot os2 or
sudo reboot os3
I hope this makes sense.
DirkS
Tue Feb 02, 2016 9:29 am
pcmedicjax wrote:Is there a way to run a command via ssh that will reboot the RPI2 to a specified OS.
https://github.com/maxnet/berryboot/issues/233 and http://rvalbuena.blogspot.com.au/2013/0 ... os-on.html describe what needs t obe done.
If you create a script it's possible to run that script using ssh...
DirkS
Tue Feb 02, 2016 9:31 am
elatllat wrote:Yes you can edit
root=/dev/mmcblk0p2
in
/boot/cmdline.txt
I don't think that will work with berryboot...
