Ghenghis
RPi Zero cardboard cases anyone?
Mon Dec 14, 2015 11:33 am
Is there already such thing as cardboard case templates available for the zero? Everyones churning out 3d printed or manufactured cases, but there doesn't seem to be anything diy-able solution for keeping our zeros safe..
java
Re: RPi Zero cardboard cases anyone?
Tue Dec 22, 2015 8:22 pm
Would not mind either, if there was a cardboard template, for a case, I could use till I found a commercial case that I like. That is one that appeals to me, if I could find plastic/nylon screws and standoffmig locally, I just might make a case myself, just don't have the means to post accurate neat drawings to the forum if I do.
killor
Wed Dec 23, 2015 1:48 pm
Do it yourself. :!:
You can use this site http://www.templatemaker.nl/ to generate the main template and then make holes for connectors ,etc. ;)
We have a discount for purchases made in ETSY site :o
Discount Codes :MAYTHE4TH :!:
Gary Littlemore
Thu Dec 24, 2015 12:58 pm
I can't test the template as I've not got my Zero yet... try the attached.
Pi_Zero_Template_65_x_30_mm.zip
(1.24 KiB) Downloaded 1146 times
Had to attach the pdf into a zip file as pdf's wasn't allowed on the forum.
3b+, 2b, b+, b, Zero & Zero-W
java
Thu Dec 24, 2015 8:00 pm
Gary Littlemore wrote:I can't test the template as I've not got my Zero yet... try the attached.
Zip file contains STL files - what do I need to be able to print those. Do not see PDF file to download.
Thanks.
Burngate
Fri Dec 25, 2015 9:47 am
There was a .pdf in it - no .stl files - when I downloaded it - am I doing something strange?
java
Mon Dec 28, 2015 3:52 pm
Burngate wrote:There was a .pdf in it - no .stl files - when I downloaded it - am I doing something strange?
Just downloaded it, again, and now I get a zipped PDF file, my original download, had STL files in it - not that it matters, thanks
java
Tue Dec 29, 2015 11:09 am
Printed the PDF file this morning. The diagram does not print dark enough to be seen with any ease. Are the any suggestions on how I might darken it?
karrika
Wed Dec 30, 2015 9:14 am
Thanks for the link to the template maker. I created a case for my Miscap + PiZero setup.
http://79.125.115.174/pics/MiscapPlain.pdf
http://79.125.115.174/pics/MiscapPlain.svg
Actually I would like to have some nice graphics design for the case. White is a bit dull.
Would it be ok to set up a competition for designing the coolest graphics for this PiZero + Miscap template? The price would be 1-3 Miscap boards depending of the number of cool entries. I know that this is a shameless scam for Miscaps. But on the other hand I have no good ideas for the graphic design myself.
The voting could be by the poll mechanism in case there is a small number of entries.
Here is a picture of Miscap with an ENC28J60 module for Ethernet and a 3.5mm headphone plug for sound.
opticyclic
Tue Jan 05, 2016 3:34 am
Thanks for the template. It only took about half an hour to cut it all out and stick together.
I used some coloured card instead of thick cardboard to make the folding easier.
I then wrapped a couple of those twisty wires through the corner holes to hold it in place.
However, your slots for the sdcard and Ethernet seem to be on the wrong side though.
yoosi
Tue Jan 05, 2016 10:26 pm
opticyclic wrote:Thanks for the template. It only took about half an hour to cut it all out and stick together.
Can you upload a picture of the completed case?
karrika
Wed Jan 06, 2016 1:39 pm
Thanks for the note. I found it out the hard way. They are now fixed. As the images were links only they should now be correct.
opticyclic
Wed Jan 06, 2016 2:28 pm
See below for my completed case.
I will have to redo it as I did it with the ports on the wrong side but you get the idea.
Also, remember that this is for a Miscap hat so there are holes for an ethernet port that you don't need if you just have a zero by itself.
Karrika: It is fairly obvious where to fold, but could you put some dotted lines in anyway? :)
karrika
Wed Jan 06, 2016 3:50 pm
Done. Better now?
Perhaps it would be good to make a very small PiZero-only case with minimum height.
karrika
Wed Jan 06, 2016 4:07 pm
yoosi
Thu Jan 14, 2016 9:07 pm
[quote="karrika"]Here is an attempt for a folded PiZero case.
http://79.125.115.174/pics/PiZeroPlain.svg
http://79.125.115.174/pics/PiZeroPlain.pdf
Thanks for sharing this! I've made a few modifications that I believe increase the strength and durability. Perhaps someone will recreate my crude drawing in a usable format.
chrisoh
Fri Jan 15, 2016 12:47 am
My limited edition case :)
Raspberry Pi 3 model B Idle @ 250mA
  • HDMI +200mA
  • Minecraft 1.9 Server +100mA
  • 2.4Ghz dongle +20mA
karrika
Fri Jan 15, 2016 5:07 am
Wow. This case is a real masterpiece.
lofiguy
Tue Aug 23, 2016 4:25 pm
Hi there. I just came across this thread. I'm no technical designer, but I made a cardboard case for a RPi Zero V 1.3 a couple of months back. Thought I'd share it with you just in case you like it and want to print out the image for yourselves. If so, you may wish to tinker with the sizing depending on the thickness of the card you use in your printer :D
Oh, and someone just mentioned that this might get a bit hot. I had no issues but if it's a worry, cut a larger hole where the strap fits and raise the bottom and extend the height. Edit it to your heart's content.
MAP FOR PI ZERO single.png (20.2 KiB) Viewed 7003 times
blaablaaguy
Wed Aug 24, 2016 1:30 pm
karrika wrote:Wow. This case is a real masterpiece.
Sarcasm?
This signature intentionally left blank.
karrika
Wed Aug 24, 2016 2:06 pm
Not at all. Simple and functional. All the other cases did not have a good way to keep it together. Here you have a string that ties PiZero to the case. As the sides are open you will also have a way for the heat to escape. I really like the idea. Of course the cardboard could be colored. Perhaps stripes or circles?
simonishe
Wed Feb 08, 2017 12:40 am
A little mix of two boxes, I'll make a better one later.
karrika-yoosi-pizero-case-2017.pdf.zip
(11.33 KiB) Downloaded 260 times
