killor
Re: Cases for Pi and 7" touch screen?
Tue Feb 02, 2016 3:13 pm
ozzytom wrote:G'day John
Yes I have the .stl files.
I tried uploading them with my post but they were rejected by the file loader.....
What's your email address and I'll send them thru.
I printed them on a Flashforge CreatorPro with good results.
The LCD base took 8 hours to print and the rear cover about 3.5 hours using 1.75mm ABS
The rear case has a small support filler on each of the 4 interlock clips which needs to be filed carefully with a flat needle file. Aim for a 2.2mm gap.
If the clips break I also have provision for 4 screw holes to secure it to the RasPi board via 2.5mm threaded standoffs.
what 3D printer do you have?
Hi !!
Use suggestion
You could publish the "STL" files on the web http://www.thingiverse.com/ and there everyone could see your own designs and download them , etc..
by the way, it is a good design..
We have a discount for purchases made in ETSY site :o
Discount Codes :MAYTHE4TH :!:
rtaramelli
Wed Feb 03, 2016 11:29 am
dear tom,
would you be able to send me the stl files for the design?
brijesh4u
Wed Feb 24, 2016 11:49 am
Hello Ozzytom,
This is awesome design, i liked it so much.
please send it to me as well, brijesh.ku.mishra@gmail.com.
Brijesh
Markus1981
Thu Feb 25, 2016 12:43 pm
Hi Guys i really love this case and also would like to modify it to install this on my RX-7 as dashmounted screen . Please can someone email me the STL files ? I love this design
Markus.ippy1981 at gmail.com
tomkemp1989
Thu Feb 25, 2016 10:01 pm
Does anyone have the STL files for this housing that can send me? my email address is tomkemp1989 [at] gmail [dot] com
bop12
Mon Feb 29, 2016 8:24 am
Excellent case by ozzytom. Could you please send STL files to petr (dot) kreutz (at) gmail (dot) com ?
Thanks a lot !
rtaramelli
Mon Feb 29, 2016 11:41 am
Has anyone gotten the stl files yet?
ozzytom
Wed Mar 02, 2016 1:01 pm
Sorry folks.
Been quite busy lately and have not viewed the forum.
Excellent suggestion by Killor so I have published the stl files on thingiverse.com
Here's the link.
http://www.thingiverse.com/thing:1384316
regards
Tom
Mr Richard
Thu Mar 10, 2016 4:09 pm
look at this one i think it's the best yet just google for it it's from rs-components!
ASM-1900035-21
Athena
Wed Mar 16, 2016 6:09 pm
Hello Ozzytom,
Great desihn. Thank you for sharing it with us. Could you please send the STL files (or any format, I use SolidWorks 2015) to hiittite at gmail dot com?
sgamp
Thu Mar 17, 2016 7:18 am
Really great design. I would highly appreciate if you could send the file to me as well:
sgamp (at) audioelectroincs (dot) de
Many thanks in advance
Stephan
ozzytom
Thu Mar 17, 2016 10:39 am
The files can be downloaded from the link above on thingiverse.com
Regards
Ozzytom
geomarmorales
Thu Apr 07, 2016 1:48 pm
Hey Ozzy - anyway i can get the STL file for this please? Awesome work! geomarmorales (at) yahoo (dot) com
CharlieHorse1967
Tue Apr 12, 2016 2:16 pm
I am very interested in this for a project I'm working on. If you could, could you send the STL files to me at "cwrand" (at) gmail (dot) com? If not, please post where these are on the web.
ozzytom
Tue Apr 12, 2016 9:07 pm
ozzytom wrote:http://www.thingiverse.com/thing:1384316
Regards
Ozzytom
Haytham Amin
Sun Apr 17, 2016 9:49 pm
Ozz Can you please share the 3D images files? haythamelmogzay [at] gmail [dot] com
CarlRJ
Wed Apr 20, 2016 8:29 am
Mr Richard wrote:look at this one i think it's the best yet just google for it it's from rs-components!
ASM-1900035-21
I have one of these, got it from here: https://thepihut.com/products/raspberry ... creen-case, and found it perfect for my needs. It's compact, sturdy, form-fitting, and very secure. It stands upright (with screen nicely tilted back a bit), on its own. The "Pi case" is integral to the whole unit, but the "top lid" of the Pi case pops off, allowing easy access to gpios, hats, and such. The really cool part, from my perspective, is popping off the lid reveals two keyhole mounting slots in the upper back corners, for wall mounting. I've actually mounted mine under the front edge of a shelf in a bookcase, using a sort of adjustable L-bracket I made.
(I should add, it is not intended for easy access to the MicroSD card slot - there's no cutout. In my application, that's not a problem.)
buxy
Fri Apr 22, 2016 7:31 pm
ozzytom wrote:Here's some images of a 3D printed case I designed for the 7" LCD display with Raspberry Pi 2
The LCD display sits neatly into the case and is secured with 4 x M3 screws. There is a raised lip surrounding the screen to provide some protection.
The rear case cover has 4 interlock tabs to allow easy access to the pcb for development work.
Cutouts are provided for access to all the peripheral connectors on the Raspberry Pi 2 and B+
Slots are provided on both the bottom and top faces of the rear cover to allow convection cooling, as well as provision of slots and mounting holes for a small 25mm cooling fan on the side face.
I also included mounting tabs for the camera module and also a slot on the back face to allow access to the GPIO pins.
It's a work in progress. All feedback appreciated.
cheers,
Tom, from the land down under.
Hey Ozzytom, any chance you could forward those case files to me? Much appreciated! Email is nicobuxbaum(at)gmail.com
subhrajitb
Thu May 12, 2016 5:33 am
Hi Ozzytom,
Greetings of the day... Its a great work... congratulations... can I have the .STL files in my email id ? it is subhrajitb(at) gmail(dot)com.
CONGRATS once again.. great work..
supamonkey2000
Sun Jun 12, 2016 10:37 pm
NubCake wrote:Did anyone actually get the files from "Ozzytom" and can share them (upload them somewhere)?
Or send them to my e-mail "obmwo (at) 2die4 [dot] com", i would be very gratefull for it.
Greetings
I noticed that he now has the STL files on the thingiverse website:
http://www.thingiverse.com/thing:1384316/#files
Hope this helps as this is my first post on these forums :)
Brand new forums member (June 12, 2016) :D
"Be nice to nerds. Chances are you'll end up working for one." -Bill Gates
jontpython
Fri Jul 08, 2016 6:28 pm
beautiful design, ozzie.
Can someone send me the .stl files? recycleproject (@) gmail (dot) com
Thanks in advance!
stubbyfex
Wed Jul 13, 2016 10:33 pm
Here's a simple stand for my Pi3 and display. I made it out of wood.
It was influenced by the Interocitor in This Island Earth.
(I also posted this to the Facebook page)
I'm going to add a power supply board or battery to it as well.
giampiero
Tue Jul 26, 2016 1:10 pm
If you are looking for something more professional:
https://www.sferalabs.cc/strato-pi-touch-display/
uziel123
Wed Jan 18, 2017 12:32 pm
Here is what I came up with - let me know if anyone is interested...
MATCH UP iso.jpg (36.37 KiB) Viewed 4357 times
casi 7.jpg (63.28 KiB) Viewed 4357 times
