gmc
USB to Canon camera - stops working after waking up camera?
Sat Sep 13, 2014 7:51 am
I've hooked my Pi up to a Canon 600d camera. Running lsusb detects the camera and then using gphoto2 to take a pic. All working great.
The problem is after the camera goes to sleep, I press a button to wake it up but then the Pi no longer detects it as a usb device.
Nothing under lsusb.
I've have a few posts about running usbreset.c which I have tried but it doesn't help.
I have to unplug and reconnect the cable to get it working again.
Anyone has similar issues or know a workaround.
gmc
Re: USB to Canon camera - stops working after waking up came
Mon Sep 15, 2014 9:03 am
Still not having any luck - tried with and without a usb hub. Doesnt make any difference.
When the camera goes to sleep:
[  111.172690] usb 1-1.2: USB disconnect, device number 4
After waking up the camera - its not detected :(
marc bcn
Fri Sep 19, 2014 10:20 pm
Hello , everyone, I have a small proyect:
I can´t make working my camera with gphoto2.
RPI see the camera at the USB port and I can no make it work . Not take a picture , not download pictures from camera , etc ..... not functions at all.
I ´m new in raspberry , linux and all that , so maybe I did not configure the parameters of the camera in RPI and gphoto2 :( :( :( .
Can someone help me to make my canon 600d working whith RPI ?????
My porpuse is just to dowload the images from sd card on camera to a usb drive in RPI or internal sd card of RPI.
Thank you , I´m lost.
( sorry about my English :? :? :? )
gmc
Sun Sep 21, 2014 4:18 pm
Once you have your camera plugged in to the pi - run lsusb
Does it detect your camera?
marc bcn
Sun Sep 21, 2014 5:17 pm
Thank you.
Yes the camera is there. It sees the camera at the usb port.
gmc
Sun Sep 21, 2014 5:40 pm
Im interested to know if you have the same problem as me. if you leave your camera and it goes to sleep, when you wake it up does the Pi still detect the camera?
Mine doesn't - it might detect it once after a wake up but 9/10 times it doesn't.
marc bcn
Sun Sep 21, 2014 5:52 pm
My camera has never worked with gphoto2 at all .
I just install the program 4 days ago an efter trying lots of things I decide to put my problen into a forum .
Thank you
gmc
Sun Sep 21, 2014 5:54 pm
Try
gphoto2 --auto-detect
marc bcn
Sun Sep 21, 2014 6:25 pm
Auto detect recocnize the camera very well. Is there.
Thank you
gmc
Fri Oct 24, 2014 2:29 pm
Bump. Anyone else having this problem?
lester289
Wed Aug 17, 2016 3:28 pm
I am having exactly the same problem as you. Seems like the camera cannot be awakened by the USB port. Is that right?
Did you find a workaround to this?
Thanks.
