GeorgeIoak
24-bit/192kHz Audio Over HDMI
Mon Jan 06, 2014 11:51 pm
I've read that the latest distribution supports this so I downloaded 2013-12-20-wheezy-raspbian.img and ran it on my older original RPi. Here's some basic system information
pi@raspberrypi ~ $ uname -a
Linux raspberrypi 3.10.25+ #622 PREEMPT Fri Jan 3 18:41:00 GMT 2014 armv6l GNU/Linux
pi@raspberrypi ~ $ tvservice -a
     PCM supported: Max channels: 8, Max samplerate: 192kHz, Max samplesize 24 bits.
     AC3 supported: Max channels: 6, Max samplerate:  48kHz, Max rate  640 kb/s.
     DTS supported: Max channels: 6, Max samplerate:  96kHz, Max rate 1536 kb/s.
  DTS_HD supported: Max channels: 8, Max samplerate: 192kHz, Max rate    8 kb/s.
pi@raspberrypi ~ $ aplay -L
null
    Discard all samples (playback) or generate zero samples (capture)
default:CARD=ALSA
    bcm2835 ALSA, bcm2835 ALSA
    Default Audio Device
sysdefault:CARD=ALSA
pi@raspberrypi ~ $
So I decided to test using aplay but as you can see, it is converting the file to 16-bit/48kHz because I assume it thinks the hardware doesn't support 24-bit/96kHz.
pi@raspberrypi ~ $ aplay -v audio/JimmyAndTheCrows96kHz.wav
Playing WAVE 'audio/JimmyAndTheCrows96kHz.wav' : Signed 24 bit Little Endian in 3bytes, Rate 96000 Hz, Stereo
Plug PCM: Rate conversion PCM (48000, sformat=S16_LE)
Converter: linear-interpolation
Protocol version: 10002
Its setup is:
  stream       : PLAYBACK
  access       : RW_INTERLEAVED
  format       : S24_3LE
  subformat    : STD
  channels     : 2
  rate         : 96000
  exact rate   : 96000 (96000/1)
  msbits       : 24
  buffer_size  : 32768
  period_size  : 8192
  period_time  : 85333
  tstamp_mode  : NONE
  period_step  : 1
  avail_min    : 8192
  period_event : 0
  start_threshold  : 32768
  stop_threshold   : 32768
  silence_threshold: 0
  silence_size : 0
  boundary     : 1073741824
Slave: Hardware PCM card 0 'bcm2835 ALSA' device 0 subdevice 0
Its setup is:
  stream       : PLAYBACK
  access       : MMAP_INTERLEAVED
  format       : S16_LE
  subformat    : STD
  channels     : 2
  rate         : 48000
  exact rate   : 48000 (48000/1)
  msbits       : 16
  buffer_size  : 16384
  period_size  : 4096
  period_time  : 85333
  tstamp_mode  : NONE
  period_step  : 1
  avail_min    : 4096
  period_event : 0
  start_threshold  : 16384
  stop_threshold   : 16384
  silence_size : 0
  appl_ptr     : 0
  hw_ptr       : 0
But if I use omxplayer it does appear that the file is played in 24-bit/96kHz. My AVR only displays frequency and not bit level so I can only confirm that it is playing at 96kHz.
pi@raspberrypi ~ $ omxplayer -p audio/JimmyAndTheCrows96kHz.wav
Audio codec pcm_s24le channels 2 samplerate 96000 bitspersample 24
Subtitle count: 0, state: off, index: 1, delay: 0
have a nice day ;)
So I installed mplayer to see how it would play the files and it too produced some interesting results:
pi@raspberrypi ~ $ mplayer -ao alsa audio/test32bit_44.1kHz.wav
MPlayer svn r34540 (Debian), built with gcc-4.6 (C) 2000-2012 MPlayer Team
mplayer: could not connect to socket
mplayer: No such file or directory
Failed to open LIRC support. You will not be able to use your remote control.
Playing audio/test32bit_44.1kHz.wav.
libavformat version 53.21.1 (external)
Mismatching header version 53.19.0
Audio only file format detected.
Load subtitles in audio/
Opening audio decoder: [pcm] Uncompressed PCM audio decoder
AUDIO: 44100 Hz, 2 ch, s32le, 2822.4 kbit/100.00% (ratio: 352800->352800)
Selected audio codec: [pcm] afm: pcm (Uncompressed PCM)
AO: [alsa] 44100Hz 2ch s32le (4 bytes per sample)
Video: no video
Starting playback...
A:  23.5 (23.5) of 66.0 (01:06.0)  1.8%
MPlayer interrupted by signal 2 in module: play_audio
A:  23.6 (23.5) of 66.0 (01:06.0)  1.8%
Exiting... (Quit)
pi@raspberrypi ~ $ mplayer -ao alsa audio/JimmyAndTheCrows96kHz.wav
Playing audio/JimmyAndTheCrows96kHz.wav.
libavformat file format detected.
[wav @ 0xb63ecc78]max_analyze_duration reached
[lavf] stream 0: audio (pcm_s24le), -aid 0
Clip info:
 comment: Jimmy And The Crows
 encoded_by: Keith Greeninger, Chris Kee & Br
 date: 2013-07-25
 creation_time: 14:58:00
 time_reference: 0
 coding_history: A=PCM,F=96000,W=24,M=stereo,T=KORG AudioGate ver.2.3.2 (Windows 7),
 artist: Keith Greeninger, Chris Kee & Brain
 title: Jimmy And The Crows
AUDIO: 96000 Hz, 2 ch, s24le, 4608.0 kbit/100.00% (ratio: 576000->576000)
AO: [alsa] 48000Hz 2ch s24le (3 bytes per sample)
Video: no video
A:  36.9 (36.9) of 475.2 (07:55.2)  9.2%
MPlayer interrupted by signal 2 in module: decode_audio
A:  37.0 (36.9) of 475.2 (07:55.2)  9.2%
Exiting... (Quit)
So I'm confused as to what is happening and why it is behaving like this.
GeorgeIoak
Re: 24-bit/192kHz Audio Over HDMI
Mon Jan 13, 2014 8:17 pm
I just thought I'd post a reply to see if anyone could at least test playing a 24-bit/96kHz audio file. I good site for reference of where to get free downloads is http://www.24bit96.com/24bit96khz-downl ... nload.html
Thanks in advance,
George
dom
Mon Jan 13, 2014 8:30 pm
The alsa driver currently limits you to 16-bit / 48kHz. It could support higher - create a github issue to stop me forgetting about this:
https://github.com/raspberrypi/linux/issues
Openmax can support 24-bit / 192kHz. You can test this with hello_audio test app.
GeorgeIoak
Mon Jan 13, 2014 9:47 pm
Thanks for confirming this. I create an issue and give the hello_audio a try. Do you know offhand if hello_audio can handle flac or just is it just wav files?
dom
Mon Jan 13, 2014 10:10 pm
GeorgeIoak wrote:Thanks for confirming this. I create an issue and give the hello_audio a try. Do you know offhand if hello_audio can handle flac or just is it just wav files?
hello_audio is just a demo app that takes raw data (it generates a sine wave).
It shouldn't be hard to make it read data from a file. You can convert wav to raw with something like sox.
GeorgeIoak
Mon Jan 13, 2014 10:18 pm
OK, been a while since I messed with this. I thought this code had been changed. I was looking at https://github.com/raspberrypi/linux/bl ... 2835-pcm.c and noticed the formats and rates weren't implemented but I could have sworn I read somewhere that they were.
/* hardware definition */
static struct snd_pcm_hardware snd_bcm2835_playback_hw = {
        .info = (SNDRV_PCM_INFO_INTERLEAVED | SNDRV_PCM_INFO_BLOCK_TRANSFER |
                 SNDRV_PCM_INFO_MMAP | SNDRV_PCM_INFO_MMAP_VALID),
        .formats = SNDRV_PCM_FMTBIT_U8 | SNDRV_PCM_FMTBIT_S16_LE,
        .rates = SNDRV_PCM_RATE_CONTINUOUS | SNDRV_PCM_RATE_8000_48000,
        .rate_min = 8000,
        .rate_max = 48000,
        .channels_min = 1,
        .channels_max = 2,
        .buffer_bytes_max = 128 * 1024,
        .period_bytes_min =   1 * 1024,
        .period_bytes_max = 128 * 1024,
        .periods_min = 1,
        .periods_max = 128,
mhelin
Fri Apr 13, 2018 1:20 pm
How is this today? Can 24 bit/192kHz audio played using ALSA over HDMI now?
dom
Fri Apr 13, 2018 1:36 pm
Not trivially through alsa. It can from openmax.
There do exist kernel patches that enable higher bitrates and multichannel through alsa,
but they didn't play nicely with sonic pi so haven't yet been merged, but it's something that will hopefully be resolved at some point.
benjaminbellamy
Sun Oct 14, 2018 6:30 pm
I am trying to make HDMI multichannel work for Roon Bridge.
I successfully played a 5.1 multichannel file with aplay:
pi@raspberrypi:~ $ vcgencmd hdmi_channel_map 0x0BFAC4C8
hdmi_channel_map=0xbfac4c8
pi@raspberrypi:~ $ aplay -c6 sgtpepper.wav
Playing WAVE 'sgtpepper.wav' : Signed 16 bit Little Endian, Rate 48000 Hz, Channels 6
NB: I am using 0xbfac4c8 and not 0x13fac688 because I only have 6 channel (0x0B) and I need to swap LFE and FC (so fac4c8=76542310 instead of fac688=76543210).
To do that, I had just updated channels_max and rate_max (and formats but this was useless) in linux/drivers/staging/vc04_services/bcm2835-audio/bcm2835-pcm.c:
static const struct snd_pcm_hardware snd_bcm2835_playback_hw = {
        SNDRV_PCM_INFO_MMAP | SNDRV_PCM_INFO_MMAP_VALID | SNDRV_PCM_INFO_BATCH),
        .formats = SNDRV_PCM_FMTBIT_U8 | SNDRV_PCM_FMTBIT_S16_LE | SNDRV_PCM_FMTBIT_S32_LE,
        .rates = SNDRV_PCM_RATE_CONTINUOUS | SNDRV_PCM_RATE_8000_192000,
        .rate_min = 8000,
        .rate_max = 192000,
        .channels_min = 1,
        .channels_max = 6,
        .periods_min = 1,
        .periods_max = 128,
…then rebuilt kernel.
NB: 24 bits does not work, I just get white noise, I think making that work is not as easy.
My problem now is that snd_pcm_set_chmap fails to work:
10/14 16:44:44 Trace: [RAAT::bcm2835 ALSA] [lua@0x7360fa14] [192.168.58.240:56757]  GOT [6] {"request":"setup","format":{"sample_type":"pcm","sample_rate":176400,"bits_per_sample":16,"channels":6,"sample_subtype":"none"}}
10/14 16:44:44 Trace: [RAAT::bcm2835 ALSA] alsa output setup: format is pcm 176400/16/6
10/14 16:44:44 Trace: [RAAT::bcm2835 ALSA] opening [hw:CARD=ALSA,DEV=0] 176400/16/6
10/14 16:44:44 Trace: [RAAT::bcm2835 ALSA] prefer larger samples = 0
10/14 16:44:44 Trace: [RAAT::bcm2835 ALSA] [ALSA] [hw:CARD=ALSA,DEV=0] using hw pcmformat S16_LE bitspersample 16
10/14 16:44:44 Trace: [RAAT::bcm2835 ALSA] [ALSA] [hw:CARD=ALSA,DEV=0] Requesting 2 periods
10/14 16:44:44 Trace: [RAAT::bcm2835 ALSA] [ALSA] [hw:CARD=ALSA,DEV=0] Requesting 7056 frames/buffer (3528 frames/period)
10/14 16:44:44 Trace: [RAAT::bcm2835 ALSA] [ALSA] [hw:CARD=ALSA,DEV=0] Initialized with 2 periods with 3528 frames/period and 7056 frames/buffer
10/14 16:44:44 Error: [RAAT::bcm2835 ALSA] error in snd_pcm_set_chmap: No such device or address (-6)
10/14 16:44:44 Warn: [RAAT::bcm2835 ALSA] [lua@0x7360fa14] [192.168.58.240:56757]  setup failed: RAAT__OUTPUT_PLUGIN_STATUS_DEVICE_INIT_FAILED
10/14 16:44:44 Trace: [RAAT::bcm2835 ALSA] [lua@0x7360fa14] [192.168.58.240:56757]  SENT [6] {"message":"RAAT__OUTPUT_PLUGIN_STATUS_DEVICE_INIT_FAILED","status":"DeviceInitFailed"
I'm a bit lost here…
Anyone would know where to dig?
Ben.
mhelin
Fri Sep 06, 2019 6:39 am
There is this issue reported five years ago, why does it take so long to solve it?
https://github.com/raspberrypi/linux/issues/494
