P09
RPi4 + Buster + Kodi 18.x and PVR-HTS addon (TVHeadend stream client) - SOLVED
Wed Sep 04, 2019 7:33 am
Hi have someone PVR-HTS addon for Kodi 18.x as TVHeadend stream client? I can not find any to install into the RPi4 Kodi 18.x build (see https://www.raspberrypi.org/forums/view ... 8&t=246837). Have someone some solution how to run TVHeadend stream in this Kodi build (in Buster and Raspberry Pi 4 Model B)?
P09
Re: RPi4 + Buster + Kodi 18.x and PVR-HTS addon (TVHeadend stream client)
Wed Sep 04, 2019 12:11 pm
Solved - I am using pvr.hts addon from LibreELEC (LibreELEC (Leia) 9.1.002 ALPHA) now (my second SD card which I am trying with my RPi4). Everything ok, just Kodi 18.x is consuming a lot of CPU in Raspbian - it is still not official and optimized version of Kodi for RPi4 so we have to wait or experiment.
alfi
Re: RPi4 + Buster + Kodi 18.x and PVR-HTS addon (TVHeadend stream client) - SOLVED
Fri Sep 06, 2019 11:36 am
I have just successfully tried packages from deb-multimedia.org (https://www.deb-multimedia.org/dists/st ... ckage/kodi), incl. pvr-hts. Probably it is more easy and maintanable way than copying packages or binaries from LibreELEC :-)
