Borromini
HifiBerry Amp+ no audio with Raspbian Buster
Tue Sep 03, 2019 8:10 pm
Hi guys. I have an RPi 3B with Raspbian and Mopidy. Things (Mopidy, sadly) broke at some point - no audio playback anymore - and I decided to upgrade from Raspbian Jessie to Raspbian Buster, hoping that might help. I have replaced Mopidy with raspotify in the meantime, which seems to have solved the Spotify connectivity issues, but not the underlying audio problem. I've seen a few topics here about people with add-on sound cards losing their audio after upgrading to Buster, so I'm asking for help (I'm close to pulling my hair out).
ALSA output looks just fine, I've disabled onboard audio, followed the HifiBerry instructions for newer kernels, but no dice.
# aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: sndrpihifiberry [snd_rpi_hifiberry_amp], device 0: HifiBerry AMP HiFi tas5713.1-001b-0 []
  Subdevices: 0/1
  Subdevice #0: subdevice #0
I'm not sure what the 0/1 subdevice is about; it appeared as 1/1 at some point but it doesn't seem to make the slightest difference audio wise (still silent). Alsamixer sees the HifiBerry just fine either way.
Playing audio seemingly works but the speakers just stay silent:
root@rpi1:/usr/share/sounds/alsa# aplay Front_Left.wav
Playing WAVE 'Front_Left.wav' : Signed 16 bit Little Endian, Rate 48000 Hz, Mono
Raspotify seems to work nicely so that's not it either:
sep 03 21:49:40 rpi1 librespot[502]: INFO:librespot_playback::player: Loading track "Boy From School" with Spotify URI "spotify:track:7BR8iLWgruHFVRKMMDnIXD"
sep 03 21:49:42 rpi1 librespot[502]: INFO:librespot_playback::player: Track "Boy From School" loaded
sep 03 21:53:26 rpi1 librespot[502]: INFO:librespot_playback::player: Loading track "Shaken" with Spotify URI "spotify:track:34snR09BNIrTszPmmgt1dP"
sep 03 21:53:26 rpi1 librespot[502]: INFO:librespot_playback::player: Track "Shaken" loaded
sep 03 21:59:40 rpi1 librespot[502]: INFO:librespot_playback::player: Loading track "Close Cover" with Spotify URI "spotify:track:43m5TqybPGRZ3C2qAQbISH"
sep 03 21:59:40 rpi1 librespot[502]: INFO:librespot_playback::player: Track "Close Cover" loaded
sep 03 22:03:02 rpi1 librespot[502]: INFO:librespot_playback::player: Loading track "Twisted - Original Single Edit" with Spotify URI "spotify:track:3fq00pI0Pw
sep 03 22:03:03 rpi1 librespot[502]: INFO:librespot_playback::player: Track "Twisted - Original Single Edit" loaded
sep 03 22:04:57 rpi1 librespot[502]: INFO:librespot_playback::player: Loading track "Fear Inoculum" with Spotify URI "spotify:track:4XW5PGlQ3S4B8Bti7meocj"
sep 03 22:04:57 rpi1 librespot[502]: INFO:librespot_playback::player: Track "Fear Inoculum" loaded
Thank you :)
epoch1970
Re: HifiBerry Amp+ no audio with Raspbian Buster
Wed Sep 04, 2019 8:24 am
Volume muted perhaps? Have you checked settings with "amixer"?
LTolledo
Wed Sep 04, 2019 9:24 pm
audio DAC HATS already supported in Raspbian Buster after latest update/upgrade? :o
Some people be like:
Borromini
Thu Sep 05, 2019 6:32 am
@epoch1970
I have unmuted both Master and Channels, but it looks like they weren't muted in the first place. It doesn't make a difference either, still no sound. Thanks for the tip though.
# amixer set Channels 30% unmute
Simple mixer control 'Channels',0
  Capabilities: volume
  Playback channels: Front Left - Front Right
  Capture channels: Front Left - Front Right
  Limits: 0 - 248
  Front Left: 75 [30%]
  Front Right: 75 [30%]
root@rpi1:~# amixer set Master 30% unmute
Simple mixer control 'Master',0
  Capabilities: volume volume-joined
  Playback channels: Mono
  Capture channels: Mono
  Limits: 0 - 248
  Mono: 75 [30%]
Borromini
Sat Sep 07, 2019 12:35 pm
So, I tried downgrading to a 4.14 kernel to see if that would work (now on the raspberrypi-kernel 20190401, which is the last 4.14 kernel the foundation provides).
I am seeing this in dmesg, but it looks OK after a few tries:
# dmesg |grep hifiberry
[    4.842036] snd-hifiberry-amp soc:sound: ASoC: CODEC DAI tas5713-hifi not registered - will retry
[    5.053607] snd-hifiberry-amp soc:sound: ASoC: CODEC DAI tas5713-hifi not registered - will retry
[    5.072486] snd-hifiberry-amp soc:sound: ASoC: CODEC DAI tas5713-hifi not registered - will retry
[    6.522518] snd-hifiberry-amp soc:sound: tas5713-hifi <-> 3f203000.i2s mapping ok
Module list seems to look OK, but still no sound:
bnep                   20480  2
hci_uart               36864  1
btbcm                  16384  1 hci_uart
serdev                 20480  1 hci_uart
bluetooth             368640  24 hci_uart,bnep,btbcm
ecdh_generic           28672  1 bluetooth
8021q                  32768  0
garp                   16384  1 8021q
stp                    16384  1 garp
llc                    16384  2 garp,stp
snd_soc_tas5713        1638Module                  Size  Used by
bnep                   20480  2
hci_uart               36864  1
8021q                  32768  0
garp                   16384  1 8021q
stp                    16384  1 garp
snd_soc_tas5713        16384  1
brcmfmac              307200  0
brcmutil               16384  1 brcmfmac
cfg80211              573440  1 brcmfmac
rfkill                 28672  6 bluetooth,cfg80211
snd_soc_hifiberry_amp    16384  1
snd_soc_bcm2835_i2s    16384  2
snd_soc_core          188416  3 snd_soc_bcm2835_i2s,snd_soc_hifiberry_amp,snd_soc_tas5713
snd_compress           20480  1 snd_soc_core
snd_pcm_dmaengine      16384  1 snd_soc_core
snd_pcm                98304  3 snd_pcm_dmaengine,snd_soc_bcm2835_i2s,snd_soc_core
snd_timer              32768  1 snd_pcm
i2c_bcm2835            16384  0
snd                    69632  6 snd_compress,snd_timer,snd_soc_core,snd_pcm
uio_pdrv_genirq        16384  0
uio                    20480  1 uio_pdrv_genirq
fixed                  16384  0
i2c_dev                16384  0
ip_tables              24576  0
x_tables               32768  1 ip_tables
ipv6                  425984  264  1
brcmfmac              307200  0
i2c_bcm2835            16384  0
fixed                  16384  0
i2c_dev                16384  0
ip_tables              24576  0
ipv6                  425984  26
epoch1970
Sat Sep 07, 2019 12:58 pm
FYI, this:
is normal or harmless. I see that on every I2s amplifier I have. It only happens at boot, IIRC.
Your sound issue is unrelated.
Borromini
Sun Sep 08, 2019 7:59 am
I thought so yes, but I'm grasping at straws.
Anything else I can check?
Borromini
Sun Sep 08, 2019 5:37 pm
Well, the good news is: I did a reinstall. First Raspbian Stretch on which I froze the kernel on the last 4.14 one. That worked, but it turned out the volume was way too low (somehow on Jessie 30% was plenty though).
Then flashed the latest Raspbian Buster image, booted, upped the volume considerably again. Still worked. Updated everything apt could find, rebooted, still works. So things are looking good!
Bad news: it seems like the low volume was the culprit and since my brother could only test in the evening, when his kids were asleep, we didn't turn it up enough. So lots of time wasted on that...
