[Guide] Stream audio to the Raspberry Pi over Bluetooth
Posted: Mon Aug 05, 2019 1:24 pm
by Douglas6
Here's a quick guide to streaming audio to a Raspberry Pi over Bluetooth. PulseAudio is not required or desired. If you want your Pi to act as an audio sink, that is, to act as a Bluetooth speaker, follow the steps.
1. Unpair your Pi. Use bluetoothctl to remove any pairings it may have. On your phone, or other source, forget any pairings.
2. On the Pi, edit the bluealsa service unit
sudo nano /lib/systemd/system/bluealsa.service
EdIt the ExecStart line to add to the end of the line '--profile=a2dp-sink'. The line should look like
ExecStart=/usr/bin/bluealsa --profile=a2dp-sink
Save the file.
3. Now, you're also going to want to start bluealsa-aplay. Systemd works good for that.
sudo nano /etc/systemd/system/aplay.service
Insert into this file the following:
[Unit]
Description=BlueALSA aplay service
After=bluetooth.service
Requires=bluetooth.service
[Service]
ExecStart=/usr/bin/bluealsa-aplay 00:00:00:00:00:00
[Install]
WantedBy=multi-user.target
Yes, use '00's for the <bdaddr>. Save the file. Enable the service with
sudo systemctl enable aplay
Now, reboot.
Now you can pair and trust your phone (etc.) with the Pi, connect, and the phone's audio will play over the audio jack of the Pi.
[Most of this information comes from https://scribles.net/, which has many excellent guides for Bluetooth and BLE on the Pi]
Re: [Guide] Stream audio to the Raspberry Pi over Bluetooth
Posted: Sun Sep 22, 2019 5:53 pm
by Pulsar33
Hello
I was happy to find this guide because my first attempt when discovering the Pi4 was to install pulseaudio (as I used to do on my desktop). Unfortunately, it doesn't seem to be a good idea because many things don't work and the worst is that all sounds are set to mono instead stereo, which is unacceptable. However, I installed A2DP Sink with pulseaudio and it worked easily (but without stereo). So my Phone and my Pi4 can do the job.
So I tried your solution with ALSA on a fresh installed SD card. All is clear and easy to do, and seems to go well, except that there's no sound :(
At the same time, I can play audio with VLC for example, so the sound works on the Pi4. My Phone sees the Pi4, connects to it and displays "bluetooth audio" confirmation, with the corresponding ajusted audio level. The Pi4 sees my phone and register it as connected. All seems to be ok, but there's no sound.
I can see that :
$ systemctl list-units | grep ALSA
aplay.service loaded active running BlueALSA aplay service
bluealsa.service loaded active running BluezALSA proxy
Please, does someone have an idea of the problem ?
Best regards.
Pulsar33
Posted: Sun Sep 22, 2019 8:33 pm
by Douglas6
Is your phone Android or iOS?
Posted: Sun Sep 22, 2019 9:49 pm
by Pulsar33
None of these, but Ubuntu touch.
As said above, my phone works with A2DP Sink on Pi4 board if I install pulseaudio, but in mono and pulseaudio has other drawbacks.
BR. Pulsar33
Posted: Mon Sep 30, 2019 5:20 pm
by Radiofreak1041
I got audio streaming to the Pi3B+ to work via Bluetooth (A2DP) using Bluealsa, but in mono. Is there anyone who got this to work with stereo audio? And is it possible to route this audio to another program like Stereo Tool that can modify and output it to the audio jack?
Posted: Mon Sep 30, 2019 6:14 pm
by Pulsar33
Would be happy to know how to make this work.
Someone has an idea ?
Best regards
Pulsar33
Posted: Mon Sep 30, 2019 6:25 pm
by Douglas6
My Pi4 A2DP sink is working in stereo. No additional steps than the ones posted above.
Posted: Wed Oct 02, 2019 6:19 pm
by Radiofreak1041
It's very nice to hear that it works for someone! Can you maybe provide some information about your setup? Do you use ALSA as well, or PulseAudio? And have you specified an audio playback device somewhere in a config file? What RPi and phone OS's are you using?
Sorry for all these questions, I'm just excited to hear it IS possible :D
Posted: Wed Oct 02, 2019 6:52 pm
by Douglas6
More detail. I took a fresh Raspbian Buster image from the Raspberry website, updated and upgraded it on my Pi4 (this was 2 months ago). I then performed the steps listed in the first post of this thread. Exactly nothing more; exactly nothing less.
After reading your post, I found a stereo test audio file on the Web. With my Android 9 phone, I played the mp3 sample to my Pi with M-Audio AV40 speakers plugged into the audio jack. I clearly heard the words "front center" centered between the speakers, "side left" coming from (only) the left speaker, and "side right" coming from (only) the right speaker. The test file I used was the first link on this page: http://www.aoakley.com/articles/2018-08 ... o-test.php.
I think that's everything.
Posted: Sun Oct 06, 2019 1:32 pm
by impersson
Hey I have the raspberry pi 4 and get the error
"Failed to enable unit: File aplay.service: Bad message"
when entering
"sudo systemctl enable aplay"
I tried some other guide before that didn't work so maybe I messed up my installation? Im running raspbian.
Posted: Mon Oct 07, 2019 11:26 am
by Douglas6
Double check the the contents of aplay.service. You have mis-typed something.
