fabolandry
Most recent IP cam Tutorial for Rpi Zero W
Fri Sep 28, 2018 8:12 am
I have navigated the web for few weeks and I have tried few tutorials. Unfortunately most of them have dead links and popping errors as soon as they can. What would be the best tutorial I can use for such a trivial project with my Rpi Zero W. Do we have ready SD card image that i can just download and that would work with my Rpi Zero W ? Please help
Re: Most recent IP cam Tutorial for Rpi Zero W
Fri Sep 28, 2018 8:53 am
Just follow our own tutorials, from the front page of our site.
The current Raspbian image works on all models of Pi, including the Zero.
B.Goode
Fri Sep 28, 2018 9:20 am
What camera hardware do you have, and what do you hope to accomplish with it?
Your question is ambiguous.
Do you have an official Raspberry Pi camera module ( https://www.raspberrypi.org/products/camera-module-v2/ ) that you want to use with an RPi Zero to implement an 'IP' cam?
Or do you have a commercial IP web cam that you hope to access and view from an RPiZero?
Or some other possiblity that I haven't thought of?
fabolandry
Fri Sep 28, 2018 11:18 am
B.Goode thanks a lot for the reply I have the Raspberry Pi camera module
B.Goode
Fri Sep 28, 2018 11:55 am
And what do you want to do with it?
There is Raspberry Pi Foundation documentation about their own Camera Module here:
https://www.raspberrypi.org/documentati ... /camera.md
If you find "dead links and popping errors " in that documentation and don't know how to report it to the Raspberry Pi Foundation mention it here and someone will help you get it reported.
itsmedoofer
Tue Oct 02, 2018 11:35 am
Why not give this a go:-
https://www.raspberrypi.org/forums/view ... 43&t=63276
It may not be exactly what you are looking for but it works and its simple.
IanS
Tue Oct 02, 2018 1:13 pm
I use the RPi-Cam-Web-Interface as linked above with a Pi0W and it provides a high framerate, low latency stream with a very low CPU load. Many of the other 'IP Cam' methods can have several seconds of latency.
The only drawback is that even a Pi3 cannot display the stream at full speed, although a PC can. I would guess the encoding is hardware assisted by the GPU, but the playback (Chromium running under X) is not.
