JohnPud
Distorted USB audio
Sun Jul 01, 2018 6:24 pm
I downloaded the current version of Raspbian and made a fresh install on a USB stick. When I enabled the Creative Play!2 USB audio player the sound was distorted. I knew it should work because I had it working last year when I bought it. I loaded the April 18 image but didn't update and the Play!2 worked as expected. I then apt-get updated to the current OS version and the sound is distorted again. :-( This suggests to me that there may be a problem with the latest Raspbian distro - has anybody had a similar problem? All I did was disable the internal audio, and I am using the default ALSA configuration. The sounsblaster Play!2 is the only option presented when I right-click on the speaker icon.
Man in a van
Re: Distorted USB audio
Mon Jul 02, 2018 10:15 am
I use a Stoner Acoustic u11 without a problem on the new, and previous, OS (full desktop and Lite versions)
When you updated did you run both commands?
sudo apt-get update
sudo apt-get -y dist-upgrade
Ronnie
JohnPud
Mon Jul 02, 2018 1:41 pm
I ran the commands without the -y - what does that do?
epoch1970
Mon Jul 02, 2018 2:11 pm
"man apt-get" would be useful in this case.
("-y" injects "Yes" when the system asks something, so that it can run unattended. Unless you answered "No" somewhere, you don't need to re-run the update. Although it won't hurt.)
