Monitor 2 webcams locally
Posted: Fri Feb 10, 2017 8:00 pm
by PaulieTheKid
Hi, I'm working on a small project where I would like to monitor 2 webcams (Trust Spotlight Pro) on a lcd monitor connected by hdmi to a raspberry pi 3b.
The webcams are connected by usb to the pi, so the whole system should workswithout IP-camera's etc.
Pretty basic and pretty simple I would think.
I tried VLC but the framerate is to bad.
I'm happy with GUVCview, it shows a decent framerate (about 20 to 25 fps) when showing video form the 2 camera's simultaneously in 2 separate GUVCview instances.
When booted up, the lcd-monitor would have to show both video streams as some kind of split screen.
But when GUVCview starts, it's window pops up at a random position. I would like to have it pop up at a predefined position with a predifined size.
Or maybe I can embed the streams in a local browser and show the 2 video streams simultaneously that way.
I've searched for some info on both idea's but can't find any help.
Please help, and other usefull suggestions are welcome too!
Thanks,
Paul
Re: Monitor 2 webcams locally
Posted: Sat Feb 11, 2017 12:53 pm
by richrarobi
You might have to write your own? I was searching for gucview (via a search for webcam control on Linux) so found your post...
If you do, the only python interfaces for webcams I have found so far are in pygame and opencv.
There are some examples of pygame and cameras posted elsewhere.
The one in pygame look to be fluid (may change), so I am going to look at opencv.
I want to use a cheap webcam for motion detection alongside a picamera on a web viewer. (similar requirement, but different).
Anyone else?
