HeAdLeSs
Si4703 direct output
Sat Aug 06, 2016 9:22 pm
Hi folks :)
I got a Si4703 and I am wondering if it is possible to get the audio signal direct to the pi, via the GPIOs (I2C?). I don't want to use the cable output as I need the input of the USB sound card for the microphone. Does anybody know something about it?
Cheers
flatmax
Re: Si4703 direct output
Thu Aug 25, 2016 12:17 pm
Typically the i2c bus is used to set and read the chip's registers. Normally no way to get audio data reliably over i2c, unless it is low bit rate and the chip is setup to do that.
Matt
Check the Ultra 2 sound card - use our shop instead of Amazon Europe (Amazon USA is live).
Sound card for the Raspberry Pi with inbuilt microphone : www.audioinjector.net
Audio Inector Octo multitrack GPIO sound card
