elParaguayo
Re: (Yet another) Vintage Pi-Radio
Mon Oct 03, 2016 8:16 pm
If you are not using squeezelite then just delete the mode from this line: http://github.com/elParaguayo/PiRadio/b ... ain.py#L22
The code is a bit rough and doesn't handle errors brilliantly at the moment. To move back up a level you need to select "back" in the menu.
RPi Information Screen: plugin based system for displaying weather, travel information, football scores etc.
karrika
Tue Oct 04, 2016 5:56 am
Thank you for publishing the code. I found out that squeezelite is no longer found at googlecode. Could the binary be hosted at PiRadio? (I did find a file with the same name at https://github.com/Hypfer/squeezelite-d ... te-armv6hf )
I have used squeezeplayer on my android setup in the kitchen but I would like to try my skills in creating a PiRadio kind of setup that could have my wifes favourite records easily available.
texy
Tue Oct 04, 2016 6:33 am
elParaguayo wrote:If you are not using squeezelite then just delete the mode from this line: http://github.com/elParaguayo/PiRadio/b ... ain.py#L22
The problem for me is that the 'menu' isn't working - there is nothing to select visible on the display. However if I press the button on the encoder, the first item in the (hidden) menu is selected. So I removed the squeezelite entry from the line you outlined, and moved Bluetooth to be the first item. When I now press the button, Bluetooth is selected, and is working - also the metadata is shown on the display ;)
Tonight I will connect up the volume encoder and take another look, although I wont have a lot of time to look at it.....
Cheers,
Texy
elParaguayo
Tue Oct 04, 2016 9:02 am
karrika wrote:Thank you for publishing the code. I found out that squeezelite is no longer found at googlecode. Could the binary be hosted at PiRadio? (I did find a file with the same name at https://github.com/Hypfer/squeezelite-d ... te-armv6hf )
I'm a bit concerned that it's not at google code any more. I might visit the logitech forum and see if someone's hosting it elsewhere. If not, I don't have any real concerns about hosting the Pi compatible version on PiRadio.
elParaguayo
Tue Oct 04, 2016 10:08 am
texy wrote:The problem for me is that the 'menu' isn't working - there is nothing to select visible on the display. However if I press the button on the encoder, the first item in the (hidden) menu is selected. So I removed the squeezelite entry from the line you outlined, and moved Bluetooth to be the first item. When I now press the button, Bluetooth is selected, and is working - also the metadata is shown on the display ;)
Cheers,
Texy
Well, yes, that does sound like a problem!
Just a thought, which branch of the code are you using?
It might be worth adding some debugging to the display code so you can print the LCD lines to your screen and see whether or not they are registering properly.
texy
Tue Oct 04, 2016 10:17 am
I am using the Master branch from github. Hopefully I'll have time to play tonight. I'll probably end up using one of my 2.8" TFT displays, once I am happy everything else is working. The Roberts R300 I got from eBay, listed as non-working, in fact does, albeit with a very scratchy volume control.........
Texy
elParaguayo
Tue Oct 04, 2016 10:24 am
OK - I've been using v0.2 as it's got some improvements. It's a bit better than Master but there's still something I need to fix so hadn't merged yet. Unfortunately other parts of my life have taken over so development on this has really slowed down!
elParaguayo
Tue Oct 04, 2016 4:30 pm
That seems to be a clone of the google code binaries. Triode is one of the developers so it's good to see his name on that github account.
texy
Tue Oct 04, 2016 6:42 pm
elParaguayo wrote:OK - I've been using v0.2 as it's got some improvements. It's a bit better than Master but there's still something I need to fix so hadn't merged yet. Unfortunately other parts of my life have taken over so development on this has really slowed down!
So is v0.2 in a useable state at present?
I've made some progress - both encoders are connected and working. I can 'scroll' through the menu choices now. A couple of issues, probably down to my bad configuration :
- no metadata with airplay - I assume I mis-configured during installation, I used
./configure --sysconfdir=/etc --with-alsa --with-avahi --with-ssl=openssl --with-metadata --with-systemd
- InternetRadio works for the initial first station, ie Radio1, but when I try and change the station, it crashes, and I have to reboot to re-run. If I change the order of the station list so that Radio2 is the first station, then that plays fine, but again I cannot change it. Also strangely after the Pi is rebooted, but PiRadio is not started, as I don't have it auto running at the moment, the radio station audio can be heard.
It's a great bit of code all the same. I just need to iron out these little issues.
Cheers,
Texy
elParaguayo
Tue Oct 04, 2016 6:54 pm
So you've found two of the issues that I've got!
Airplay metadata - it is possible but I've not tried to implement it yet. The shairport service can send metadata to a pipe which the radio could read. There's some info here: https://github.com/mikebrady/shairport- ... ata-reader
Radio - I've no idea why it crashes! I'm keen to debug that one when I have the time.
Yes, v0.2 is useable - it's what I've got running at home.
As for rebooting, I've got a separate script that runs in the background. Holding both buttons down restarts the radio service (but this is only relevant if the radio is running as a service).
Question for you, when you start the radio does the code immediately jump into the first "mode" e.g. Bluetooth, Radio etc? It does on mine and I can't work out why!
texy
Tue Oct 04, 2016 7:30 pm
Ah - well I'm glad it's not only me with these issues :D
I think the issue I have with the menu selection is the same as going into the first mode - did you intend to have the selection menu up first - well that would be the logical approach, UNLESS you want it to 'remember' the previous selection on reboot (obviously it would need to have a look-up file, or some other method to achieve this).
Currently I am looking into enabling the USB sound card I have now fitted - it's been a while since I've done this........
Texy
elParaguayo
Tue Oct 04, 2016 7:58 pm
I certainly thought about having it go straight into the first mode, but I don't think I ever actually implemented it.
As for the radio, mpc is giving a return code of 1 which is causing the crash - unhelpfully there doesn't seem to be any error message. I may be able to stop the crash by just ignoring the error message but that feels like a hack. I'd rather understand why mpc is giving an error.
texy
Tue Oct 04, 2016 8:44 pm
Can't get USB DAC to work...will have to wait until the weekend now.
Texy
elParaguayo
Tue Oct 04, 2016 8:53 pm
I haven't tried USB audio but have been tempted as there is some static on the speaker. Don't know if that's the amp or the pi.
Also curious as to whether this would make any difference.
Douglas6
Tue Oct 04, 2016 9:02 pm
texy wrote:Can't get USB DAC to work...will have to wait until the weekend now.
This works for me, in /etc/modprobe.d/alsa-base.conf:
options snd_usb_audio index=0
options snd_bcm2835 index=1
options snd slots=snd-usb-audio,snd-bcm2835
texy
Wed Oct 05, 2016 6:38 am
elParaguayo wrote:I haven't tried USB audio but have been tempted as there is some static on the speaker. Don't know if that's the amp or the pi.
Ah - I didn't know about that. I'll give that a go....
Thanks,
Texy
texy
Wed Oct 05, 2016 6:39 am
I had it in my mind that that only applied to older wheezy builds, but I will give that a go as well.
Thanks,
Texy
karrika
Wed Oct 05, 2016 7:06 am
Last summer the natural Pi audio through the 3.5mm plug was much better than before. We used it for all sound at the theater. No problems with static or hiss.
Next year I plan to test the Audio Injector HAT's. They have rotary knobs to adjust both external input and master output. It allows us to have the music and sound effects on the SD card in the Pi controlled by QLC+ and easy mixing of an external source. This would be overkill for PiRadio (unless you want to sing karaoke in a microphone while cooking).
elParaguayo
Wed Oct 05, 2016 7:08 am
I never want to sing karaoke. Ever.
elParaguayo
Wed Oct 05, 2016 11:54 am
elParaguayo wrote:I certainly thought about having it go straight into the first mode, but I don't think I ever actually implemented it.
I'll do some more debugging by trying mpd/mpc outside of the PiRadio environment and see if that gives me any more clues.
elParaguayo
Wed Oct 05, 2016 6:50 pm
Pretty sure it's not my code.
From the command line I can jump around the playlist but it sometimes stops and gives me an "error: timeout" message and I'm the unable to send any further commands via mpc. Some googling to be done methinks...
EDIT: Seems to be behaving better if I use ALSA as the audio output for mpd rather than pulse.
texy
Thu Oct 06, 2016 4:04 pm
Thank you - now working with usb soundcard.
Texy
elParaguayo
Fri Oct 07, 2016 7:44 am
Hoping to have a crack at the Airplay metadata this weekend. I've got a pretty good idea as to how to do it.
texy
Fri Oct 07, 2016 8:17 am
elParaguayo wrote:Hoping to have a crack at the Airplay metadata this weekend. I've got a pretty good idea as to how to do it.
That would be great - it looks a very complex subject. Also, although not relevant for the 20 x 4 display, album art would also be useful, and for Bluetooth......I'll duck now :lol:
Texy
elParaguayo
Fri Oct 07, 2016 8:35 am
Texy
It is complex. Fortunately, someone else has already done the bulk of the hard work so it's just a case of reading a pipe and looking for the relevant tags and decoding the data.
I think the album art is available over Airplay metadata but is disabled by default. Enabling it and capturing should follow the same process above. However, I don't have much interest in doing it.
No idea about Bluetooth artwork but, again, not something I'm immediately interested in.
That said, if I've got time I'll probably end up taking a look to see if it's possible just as an intellectual exercise!
