gkreidl
Re: Real Time Transcoding of DVB TV Streams
Wed Jan 30, 2019 12:03 pm
Jonny_Muc wrote:
Wed Jan 30, 2019 7:59 am
Thank you for that awesome work! The real time transcoding performs really good on a Raspberry 3 with Jessie. Much better that other solutions I tried, even on powerful desktops.
Unfortunately my cheap STB accepts only ts-streams, but not mkv-streams. Is there any way to create ts-streams as output?
Regards
JM
I've tested it with the mpegtsmux module but could not get it to work.
Minimal Kiosk Browser (kweb)
6by9
Tue Feb 26, 2019 3:18 pm
Would you be prepared to do some experimentation for me?
We now have V4L2 codecs and resizer merged into the 4.19 kernel branch, and the rpi-update kernel has been updated to be 4.19. They use CMA for their memory allocations, so you'll need to add "cma=256M" or similar to the start of /boot/cmdline.txt. (CMA is not the same as gpu_mem in that Linux can still hand it out to other users, but may move those about in memory should a user request a CMA allocation it can't otherwise fulfil).
GStreamer (>1.10 IIRC) supports these through
video4linux2: v4l2jpegdec: V4L2 JPEG Decoder
video4linux2: v4l2mpeg4dec: V4L2 MPEG4 Decoder
video4linux2: v4l2mpeg2dec: V4L2 MPEG2 Decoder
video4linux2: v4l2h263dec: V4L2 H263 Decoder
video4linux2: v4l2h264dec: V4L2 H264 Decoder
video4linux2: v4l2vp8dec: V4L2 VP8 Decoder
video4linux2: v4l2h264enc: V4L2 H.264 Encoder
video4linux2: v4l2jpegenc: V4L2 JPEG Encoder
video4linux2: v4l2convert: V4L2 Video Converter
It obviously detects MJPEG as JPEG even though they are currently distinct formats within V4L2.
Being V4L2 they also support passing dmabufs for zero copying of the data - this should be a moderate gain over the OMX components which will always copy the images between components.
Transcoding and resizing off the command-line I'm getting x1.2 of realtime (took 8min13 for a 9min56 clip) for a 1080P decode, resize to 800x480 with v4l2convert, and then reencode that.
Command line:
gst-launch-1.0 -e -vvv filesrc location=big_buck_bunny_1080p_h264.mov ! qtdemux name=mux ! queue ! h264parse ! v4l2h264dec capture-io-mode=4 ! v4l2convert output-io-mode=4 capture-io-mode=4 ! video/x-raw,format=I420,width=800,height=480 ! v4l2h264enc output-io-mode=5 ! h264parse ! qtmux ! filesink location=transcode.mov
Any chance you could try dropping this into your pipelines and see what performance you get? In theory it should be faster than the OMX versions due to the reduced copying.
I haven't read this whole thread, but it looks like you're currently having to use the GStreamer deinterlace component. It may be possible to wrap the GPU deinterlace as well, but I'm not sure GStreamer supports that function through V4L2 at present. Interlacing as a whole is one thing I need to check through - I suspect there are various bits of plumbing missing in the signalling. Always more to do.
Thanks in advance.
gkreidl
Wed Feb 27, 2019 9:55 am
Command line:
Thanks in advance.
This looks very promising! Unfortunately I cannot test it for DVB-Transcoding at the moment. I can't afford to install a new and possibly unstable kernel and firmware on any system right now (all running from HDD with boot partition on SD card). I have to wait until the new kernel becomes standard.
Does the video scaling use the GPU?
And having a chance to deinterlace using the GPU would really make a big difference. Most TV-Transmissions are interlaced (all SD channels and 1080i HD channels) and you may get "teared" images, especially on live sports channels without deinterlacing before you scale the image down to a lower resolution.
6by9
Wed Feb 27, 2019 1:21 pm
OK, I guess I'll grab your scripts and try hacking it myself.
gkreidl wrote:Does the video scaling use the GPU?
Yes, it's done on the ISP, so dedicated hardware.
gkreidl wrote:And having a chance to deinterlace using the GPU would really make a big difference. Most TV-Transmissions are interlaced (all SD channels and 1080i HD channels) and you may get "teared" images, especially on live sports channels without deinterlacing before you scale the image down to a lower resolution.
GStreamer crowd don't appear to have decided how they'd like deinterlacing to be represented by V4L2, and the V4L2 crowd don't seem to have specified it, therefore it's all in limbo and unsupported. I don't fancy trying to add it into GStreamer as I get lost in their classes.
The GPU deinterlacing routines only support a couple of field layouts, so trying to convince it to take the data could be tricky. It also needs the decoder to advertise the interlacing mode correctly, and at the moment I don't believe it does at all. There are some discussions as to how to handle this best for Kodi, so the same may be able to apply here.
gkreidl
Thu Feb 28, 2019 9:45 am
You don't have to "hack" anything. The best way to test new gstreamer tool chains is to use http-launch directly.
You need a working TV backend which sends a http or udp MPEG TS stream. rtranscode can display the command line argument it uses (-sm argument). Here is a simple example (DVB--Sat, 1080i50 interlaced HD stream):
$ rtranscode -e=3 -sm -t=http://192.168.0.34:9082/bysid/108
http-launch 9080 /xyz.mkv video/x-matroska default souphttpsrc location="http://192.168.0.34:9082/bysid/108" is-live=true keep-alive=true do-timestamp=true retries=10 typefind=true blocksize=16384 ! tsdemux parse-private-sections=false program-number=-1 name=demux demux.audio_0_0403 ! queue ! ac3parse ! matroskamux name=stream streamable=true demux. ! queue ! h264parse ! video/x-h264,alignment=au ! omxh264dec ! video/x-raw,width=1920,height=1080 ! deinterlace mode=interlaced fields=top method=scalerbob tff=tff ! videoscale method=nearest-neighbour qos=false add-borders=true sharpen=0 envelope=1 ! video/x-raw,width=910,height=512 ! omxh264enc target-bitrate=1294222 control-rate=variable ! h264parse ! queue ! stream.
-e=3 sets deinterlacing to scalerbob ( without the -e argument no deinterlacing is used).
Copy the command line output to a text file and start experimenting with it. The gstreamer tool chain starts with "souphttpsrc". It must have "stream." as last argument (which must be the name of the muxer).
The first 4 arguments are used internally by http-launch (port, path, mime type and a special code word, leave it as "default").
The resulting stream can be accessed by http://localhost:9080/xyz.mkv (with the above settings).
gigo1988
Wed Mar 13, 2019 3:39 pm
Hi gkreidl,
if you know i have wrote some times ago that i ve issues by transcoding rlt hd and rtl 2 hd. Now i see some differents between other channels. the frame rate is not 25 like by sat1 and pro 7. on my stream test software on my server it show 25,6 by rtl and rtl2 and by pro7 and sat1 the right frame rate. Could you check this? on other transcoding method like on enigma 2 devices with software method i see the same issues.
gkreidl
Sat Mar 16, 2019 6:49 am
Hi gkreidl,
I cannot test these channels. They are encrypted and and I don't have access to them.
The channel frame rate should not really matter. It is not used in any decoder/encoder settings.
kazuko.nakamura
Mon Apr 15, 2019 1:12 pm
Hi everyone,
Would be possible to use rtranscode to stream and transcode video from webcam on RPi2 ???
gkreidl
Mon Apr 15, 2019 2:30 pm
Hi everyone,
No. The whole application is written for DVB TV streams.
gigo1988
Tue Apr 16, 2019 6:53 pm
Hi gkreidl,
it sounds like a new version is comeing :D is it right?
gkreidl
Wed Apr 17, 2019 6:11 am
Hi gkreidl,
No.
johndavies
Using a Pi TVHat, tvheadend URLs and rtranscode4
Thu May 30, 2019 5:55 pm
I put the following in the TVHat section and I thought i might as well post it here in case it is of use to anyone. I will accept that VLC produces a higher quality output than omxplayergui but I was curious to see if I could use tvheadend-generated URLs with the Pi TVHat and rtranscode4. My problem is that I am a skim reader after too many years of teaching and marking external GCSE History papers and this makes it very difficult for me to absorb technical information. Gkreidl's work on rtranscode4 is very well documented but I could not see how he produced the URLs so I decided to try tvheadend ones. The Minimal Kiosk Browser needs to be saved on the Pi.This also includes omxplayergui. rtranscode4 includes an install for the latest Minimal Kiosk Browser (aka kweb)
PRODUCING A CHANNELS LIST
It is easy to convert an m3u VLC playlist into one which rtranscode4 can use. Enter the following into a terminal for a playlist called playlist.m3u:
rtranscode -i=playlist.m3u -o=channels.dat
This will produce a channels file in the /home/pi directory which rtranscode can use. This needs to be copied elsewhere if you want a default channels list. The manual explains how you can add other lists of channels.
CREATING A DEFAULT CHANNELS LIST FOR RECORDING
This default playlist is stored as /usr/local/share/rtranscode/channels.dat. The way that I did it was to create an empty file by typing sudo nano and the path just mentioned into a Terminal, opening it up and copying the channels data stored in the home/pi/channels.dat into the /usr/local/share/rtranscode/channels.dat one and then saving it.Other channels in the rtranscode format can be added later.
ERECORDING CHANNELS IN REAL TIME
There is no PVR feature which allows you to record hours or days ahead. Typing rtranscode into a terminal will produce a gui for recording the channels stored in Channels.dat and choosing various settings for quality etc. This puts the saved programme in the home/pi directory. There is a command which allows you to save to a named directory. The command is rtranscode -l=/path/to/chosen/directory and, if this is entered, the gui showing channels available and the settings appears. Other commands are easy to apply. t and Enter allow you to enter a time for recording e.g. 1:00 records for one hour. r and Enter starts recording. s and Enter stops recording at any time. q and Enter quits the rtranscode gui.
WATCHING TV PRORAMMES
As far as I know there is no way of watching a TV programme and recording it at the same time. I do not think that there is a rtranscode command that will show a TV programme. The only way i know how to watch a TV programme is by using the RT-GUI. To do this you open up the rtranscode4 and install kweb (Minimal Kiosk Browser) which also loads omxplayergui. Then you open up the kweb directory to gain access to the RT-GUI. To make your channel list available to it, you run create_kpages.py
This allows your channels.dat to be added. When ever you add extra channels to your channels.dat, file, you need to run create_kpages.py again for these new channels to be recognised. If you put a copy of RT-GUI in your /home/pi directory. There is an added bonus. Entering ./RT-GUI into a Terminal and pressing Enter will produce the RT-GUi entry scheme where you can choose a programme, press the Transcode box , wait a few seconds until the blue bar stops flashing qand then press the Play Transcoded Stream box to watch the programme of your choice.
I shall finish by apologising to gkreidl and to the Raspberry Pi community if I have missed anything glaringly obvious or made any basic errors.
david_Est
Mon Jun 24, 2019 7:24 am
Would be great if new rpi4 has the capabilities to support this. Even greater if HEVC codec is selectable for encoding
6by9
Mon Jun 24, 2019 7:38 am
Hevc is decode only on the pi4.
We are chasing down an issue that only showed up in the last few days where simultaneous encode and decode with the h264 codec block stalls. We're actively digging into it at the moment. It seems to be some hardware quirk as the same code on Pi3 works fine.
david_Est
Mon Jun 24, 2019 12:58 pm
OK! thank you guys for your work!
typer08
Fri Jun 28, 2019 10:15 am
I have problem:
   pi@raspberrypi:~/rtranscode4/web $ ./serve.py
  File "./serve.py", line 21, in <module>
    import rtc4
ImportError: /home/pi/rtranscode4/web/rtc4.so: undefined symbol: PyFPE_jbuf    [/ code]
What am I doing wrong?
Thank for any answer.
typer08
Fri Jun 28, 2019 10:23 am
I have a problem:
   	import rtc4
gkreidl
Fri Jun 28, 2019 11:25 am
I have problem:
    import rtc4
Which OS (Jessie, Stretch, Buster)? Which kind of RPi?
Did you updgrade your system to a newer Python version?
david_Est
Fri Jun 28, 2019 10:25 pm
It would be great to have this supported in debian buster, since is last thing that i have to migrate from my old rpi3 to my new rpi4
now on buster if I perform 2nd post instructions and
rtranscode
i got an
rtranscode: symbol lookup error: rtranscode: undefined symbol: PyFPE_jbuf
gkreidl
Sat Jun 29, 2019 4:36 am
rtranscode
i got an
You cannot use a RPi 4 for transcoding at the moment for a number of reasons.
1) 6by9 reported, that accessing the h264 block for decoding and encoding at the same time is currently impossible on the RPi 4. They are working on it, but until this is fixed no solution will work.
2) Even if this problem is fixed, I have no idea in which condition the gstreamer omx module on Buster is. In the past no gstomx module we got worked out of the box. It always required patches. I think that I'll try to use V4L2 on Buster for transcoding as 6by9 suggested, but this will require a lot of changes.
3) It will take some time until I can start working on a buster version. I won't buy a RPi 4 until the FLIRC case for it is available (in about 4 weeks but it may take longer until my German supplier can deliver it). All my RPi systems run from HDD and are in full use. I cannot simply replace an SD card and start working on Buster.
typer08
Sun Jun 30, 2019 8:34 pm
Sorry!
I didn't write that it is about RPI3B + and the Buster system.
Rtranscode on Stretch worked well.
I must now return to Stretch.
I am waiting for a solution to the problem in Buster.
grkblood13
Fri Jul 12, 2019 1:34 am
has anyone had any luck running rtranscode on the pi zero? I'd like to run tvheadend and transcode into a h.264 TS stream with it.
gkreidl
Fri Jul 12, 2019 2:15 am
I never tried it. It might work for SD streams.
6by9
Wed Jul 24, 2019 9:23 am
Last night's rpi-update release has a fix for the simultaneous encode/decode issue on Pi4, so hopefully all is good to go now.
gkreidl
Wed Jul 24, 2019 10:07 am
Thanks, that's good news.
