Dam_Fr
Raspberry Pi + 433Mhz RF Transmitter + Receiver
Sun Feb 08, 2015 6:55 pm
I just receive my 433Mhz RF Transmitter + Receiver shiped from ebay :
I would like to test it by sending and retrieve a data on the same Raspberry Pi. Is it possible ?
Thanks in advance for your help.
Dam
jimallyn
Re: Raspberry Pi + 433Mhz RF Transmitter + Receiver
Mon Feb 09, 2015 3:15 am
Sure, you can do serial data in and out via the GPIO port. See for example:
http://elinux.org/RPi_Serial_Connection
“So you say you love the poor? Name them.” - Gustavo Gutierrez
joan
Mon Feb 09, 2015 9:01 am
http://www.raspberrypi.org/forums/viewt ... 87#p598087 will let you receive/send Virtual Wire messages for test purpose. You can send and receive on the same Pi.
Spoonf1
Mon Feb 09, 2015 9:36 am
Hey,
i have the perfect thing for you :) i had the same problem as i wanted to test my RF TX/RX 433Mhz with my Raspberry Pi.
Here is what i have done : http://i-build-stuff.blogspot.ch/2015/0 ... ng_27.html
