nabberuk
Confusion
Sat Jun 30, 2012 5:19 pm
I have a couple of questions that i'm a little confused about at the moment.
What's the difference between GPIO/SPI and I2C?
What are the differences in speed?
I'm looking to poll various sensors every second. (Accelerometer (X,Y and Z), Wind Direction) and based on the results change the position of a couple of servo's.
I'm confused on the 3 connections.
thanks
the autonomous sailing boat: www.autonboat.com
domesday
Re: Confusion
Sat Jun 30, 2012 6:38 pm
GPIO is a geral term to refer to the interface, General Purpose Input Output.
Some of the pins can be configured as a serial interface either I2C or SPI, SPI is the faster of the two.
leon_heller
Re: Confusion
Sat Jun 30, 2012 6:43 pm
I2C makes it easier to have several devices on the same bus, as each device has an address. SPI requires a chip select for each device on the bus.
Leon Heller
G1HSM
nabberuk
Re: Confusion
Sat Jun 30, 2012 8:02 pm
Hi thanks for the replies.
Are there any specs on the speed difference between I2C and SPI?
leon_heller
Re: Confusion
Sat Jun 30, 2012 8:10 pm
Max. speed for standard I2C is 400 kHz. SPI depends on the clock, but can go up to 50 MHz.
Leon Heller
G1HSM
nabberuk
Re: Confusion
Sat Jun 30, 2012 10:13 pm
So i'd be ok polling this sensor every second > http://www.hobbytronics.co.uk/lsm303dlh ... rd=compass
It's using I2C.
thanks
