Page 19 of 20
Re: Relay Module KY-019 5V
Posted: Sat Oct 27, 2018 2:50 am
by tlfong01
tlfong01 wrote:
Sun Oct 21, 2018 8:21 am
Cat spa tub weekend plumbing work - Part 3
Now I am order a digital float ball switch from TaoBao, for 14 yuan. I could not figure out how the things works, just by looking at the illustrations. So I need to wait for its arrival, hopefully in 2 days. I think I can use it for the cat spa tub.
Float Ball Switch
https://item.taobao.com/item.htm?spm=a1 ... 9024197118
https://item.taobao.com/item.htm?spm=a1 ... 4857563461
Float balll switch and Float ring switch
Earlier I made a laughable mistake of thinking that a float ball switch must have a floating object with the shape of a ball or sphere or at least an oblong ball like thing. So I ordered two things, one with a ball, another with a tube, with reed switch sensor inside the tube, thinking that they should work together.
But after seeing the objects, I know that they are two different things, each of which works alone, and not at all supposed to work together.
The float ball switch is sort of a all mechanical water tap, controlling the water flow, much like the float ball thing in home's traditional toilet flush tank.
The other is a floating magnetic core, used to sense the water position by switching on or off of a reed switch, to work like a push button, to be detected by say, a Rpi GPIO pin, ...
I often mixed up Reed Switch with Hall effect sensor. I once thought that Reed Switch was invented by a guy named Reed (I did not know the meaning of 'reed' then), and Hall effect sensor by another guy called Hall. I read that Hall was from Cambridge, and always thought that he was just another very smart guy from Cambridge, UK (I did not know then there is another Cambridge in US).
Just now Google told me that Reed switch was invented by Ellwood in 1936 at Bell Lab, US, and Hall effect discovered by 1879 by Edwin Hall while he was working on his doctoral degree at Johns Hopkins University in Baltimore, Maryland, US, ...
Posted: Sat Oct 27, 2018 8:18 am
by tlfong01
tlfong01 wrote:
Fri Oct 26, 2018 2:15 pm
Weekend Plumbing Work Plan
The Humble Plumber
So this morning I had all my plumber tools, and accessories ready, and started to according to my plan, insert two 1/2" pipes with screws before the hot and cold water batch taps.
I thought I could proudly complete the easy job within 20 minutes.
1. I first tried to remove the two 1/2 inch nuts from the far end of the pipe connecting the taps, but I found the screws got very rusty and stuck and impossible to turn. I gave up after 5 minutes of hard labour.
2. Then I tried to remove the two 3/4 screws nearest the taps instead. The 3/4 screws also refused to move, and I had to use WD40 to lubricate the threads. Finally, after more hard work, I could finally remove the taps.
2. I then tried to complete the job with all the accessories I just bought, including 3/4 inch to 1/2 inch adapters, with different combinations of external and internal threads, and 1/2 inch taps. But I found that I forgot to buy the most important adapter with the unique external/internal combination of threads. I tried all alternatives, but all with no luck.
3. The cheap 1/2 inch and 3/4 inch spanner I just bought also disappointed me. It is not doing its job properly, and my old adjustable spanners are awkward to use for big the 3/4 size screws. I also forgot to buy the 3/4 inch nylon washers, and had to use the old worn out ones
4. After two hours, I found it impossible to complete the job and so I fell back to the original arrangement.
In other words, I was going back to square one! But it is not exactly back square one, because the worn out washers were not fitting well, and one of the taps is leaking, so it is worst than square one.
5. My lesson learnt is not to look down other people's trade. Plumber's work looks simple and easy, comparing to the seemingly more complicated electronics, but, well, I now appreciate more why many plumbers make more money than electronics technicians (yes, I was once upon a time an electronics technician, doing maintenance work of semiconductor testing equipment in local factories;my tool of trade then was a screwdriver, not a spanner. :) , ...
So the humble plumber called it a day.
Posted: Wed Oct 31, 2018 9:41 am
by tlfong01
The Humble Plumber
5. My lesson learnt ...
Rooftop Garden Water Pipe Sizes
(Rooftop Garden) RE: GPIO.INPUT VOLTAGE LEVELS VS EDGE DETECTION Postby tlfong01 » 2018-Sep-06
viewtopic.php?f=32&t=219744&start=150#p1362098
Posted: Sat Nov 03, 2018 5:10 am
by tlfong01
The Humble Plumber
5. lesson learnt ...
[/quote]
Hot water Cold water 3/4 inch / 1/2 inch piping Saturday morning exercise
Last Saturday morning my plumbing work ended up in a big mess. This Saturday morning I was more prepared and planned, and completed the job in less than one hour. However the pipe joints are slightly leaking. I guess I did not know some of the tricks. I only observed the plumber when he comes to work and thought I know all the tricks. Well, all jobs, including computer programming, are easier seeing than doing.
Posted: Mon Nov 05, 2018 4:10 am
by tlfong01
Cat Bath Float Ball Switch
Now I have bought a 50 yuan float ball switch for the cat bath.
AliExpress / TaoBao Float Ball Switch
https://www.aliexpress.com/item/EM15-2- ... 8d2e761856
https://detail.tmall.com/item.htm?id=52 ... 3ad4Rx4BZL
Posted: Mon Nov 05, 2018 5:33 am
by tlfong01
Float switch calibration
I found the float ball has a hysteresis of about 90 degrees. The ball flips about about +45 degrees and flops about -45 degrees.
Update 2018nov06hkt1125
The big plastic float ball switch has inside a small but heavy stainless steel ball which rolls along a grove. When the big plastic ball tilts upwards, the small steel ball rolls down towards a micro switch and activates it. When the big ball tilts downwards, the small steel ball rolls away from the micro switch and deactivates it.
Posted: Tue Nov 06, 2018 6:34 am
by tlfong01
Rooftop Garden Solar Panel Design Notes
TaoBao Solar Panel
https://item.taobao.com/item.htm?spm=a2 ... t=9#detail
AliExpress Solar panel 30w 12v US$25
https://www.aliexpress.com/item/solar-p ... d9792eda7b
Solar panel 30w 12v solar system for home, charger, boat
Material :polycrystalline
Maximum 30 degree arc bendable.
Short circuit and surge protection technology keep you and your devices safe.
Wide application, suitable for laptops, car batteries, car, Boat, Ship and more.
Description
The unique process component, beautiful and strong anti-snow, convenient installation.
Suitable for home lights, electric fans, such as solar water pumps, solar street lights, small solar systems, etc.
Light and thin, easy to use and carry.
Material: polycrystalline
Size: 420 * 370mm
Color: white & black
Posted: Wed Nov 07, 2018 8:29 am
by tlfong01
Weekend Plumbing Work Plan[/color][/color] [/color]
The Humble Plumber[/color][/color]
lesson learnt ...
Cat Jacuzzi Design Notes
Last Saturday's pipe work is leaking heavily. I gave my plumbing homework a C-- grade.
Anyway, I fixed the problem this afternoon, also adding a tap for the cat milk bar.
I am also reading jacuzzi things, thinking of making a cat jacuzzi some time.
Appednices - Rpi Jacuzzi
Raspberry P Wifi Jacuzzi Automation 2016
https://www.youtube.com/watch?v=YuuIRmlLjZ0
Raspberry Pi Hot Tub Controller 2016
https://www.youtube.com/watch?v=LOwnG5V ... oller.html
Hot tub 2013
viewtopic.php?t=52840
Jacuzzi Remote 2018
https://lb.raspberrypi.org/forums/viewt ... p?t=175399
Posted: Thu Nov 08, 2018 8:11 am
by tlfong01
The Humble Plumber
lesson learnt ...
Cat Jacuzzi Design Notes. I gave my plumbing homework a C-- grade.
Cat milk drinking fountain tap
Now I am assembling a TaoBao 50 yuan 1/4 inch quick connector drinking fountain tap.
Aliexpress Lead-free Drinking Water Filter System Faucet SUS304 Stainless Steel Kitchen Drinking Water Filter Tap Faucet TP-02 US$30
https://www.aliexpress.com/item/Lead-fr ... 53437.html
TaoBao 304 Stainless 1/4 inch quick connector drinking fountain tap food grade ¥49
https://item.taobao.com/item.htm?spm=a1 ... 6738044756
Posted: Thu Nov 08, 2018 8:36 am
by tlfong01
Cat Milk Spa 1/4 inch pipe and tap assembly notes
Posted: Fri Nov 09, 2018 7:57 am
by tlfong01
Cat Bar Milk Fountain Making Notes
Posted: Fri Nov 09, 2018 12:24 pm
by tlfong01
Cat Bar Milk Fountain Making Notes 1
Cat Bar Milk Fountain Making Notes 2
Posted: Sun Nov 11, 2018 7:31 am
by tlfong01
ESP8266 Shower Timer
I felt jealous of the guy with a wifi shower timer. So I will make myself one.
ESP8266 Shower Timer - Patrick Walsh 2016nov29
https://www.spiria.com/en/blog/iot-m2m- ... er-esp8266
Posted: Sun Nov 11, 2018 7:42 am
by tlfong01
Esp8266 Wifi Show Timer
Posted: Wed Nov 14, 2018 8:00 am
by tlfong01
[/color]
Rooftop Garden Mobile Cat Milk Bar Cart Assembly Notes
Posted: Wed Nov 21, 2018 4:16 am
by tlfong01
[/color]
Weekend Plumbing Homework Preparation Notes
Aeroponics/Hydroponics/Vertical/Urban Farm References
US vertical farm grows without soil, sunlight or water - 2016aug14
https://www.theguardian.com/environment ... revolution
Netherlands Floating Farm - 2018nov17
https://www.bbc.com/news/business-45130010
UAE Bio Farm
https://www.youtube.com/watch?time_cont ... lm4-3yjga8
Japan Farming Without Soil - 2017may22
https://www.scmp.com/magazines/style/ar ... -fruit-and
Smart Robots Clean the Bathroom - 2018nov15
https://www.youtube.com/watch?time_cont ... x3QdaPD8bw
Posted: Sat Nov 24, 2018 9:35 am
by tlfong01
Cat Milk Bar Stand Assembly Notes
Posted: Mon Nov 26, 2018 9:03 am
by tlfong01
Posted: Wed Nov 28, 2018 1:12 pm
by tlfong01
Cat Milk Car Cart Assembly Notes
Posted: Wed Nov 28, 2018 1:57 pm
by tlfong01
Rpi3B+ ESP8266-12 Based Smart 5kg/1g Weight Scale Making Notes Part 1
viewtopic.php?f=37&t=227137&sid=2462eec ... 0#p1398186
Posted: Tue Dec 04, 2018 1:00 pm
by tlfong01
Model LXC-15D Water Meter Spec
01. GB/T778.1~3-2007 ISO04064.
02. Brass body dry type, magnetic drive single stream.
03. 15mm, Q3/Q1 = 80, Overflow Q4 = 3.125 m3/h, Regular Q3 = 2.5 m3/h.
04. Threshold flow Q2 = 50 l/h, min flow Q1 = 31.3 l/h.
05. Min reading = 0.00005 m3, Max = 99999 m3.
06. Temperature grade = T30.
07 Pressure grade = Map 10.
08. Press loss = d P63
09. Up stream field sensitivity grade = U5
10. Down stream field sensitivity grade = D0
11. Max permissible error Low range (Q1 <= Q <= Q2) = 5%.
12. Max permissible error High Range (Q2 <= Q < Q4) = 2%
LXS-15F3 Water Meter Intro Video (Chinese)
http://llmeter.com/shipin1.asp?tab=%CA% ... B3%CC&id=3
Posted: Wed Dec 05, 2018 2:25 am
by tlfong01
tlfong01 wrote:
Sat Jun 02, 2018 2:10 pm
I bought a KY019 relay module some weeks ago. I could not find the specification
Fake KY019 vs Real KY019
The KY019 I bought is a fake!
Real KY019) RE: SIMPLE RELAY CIRCUIT - woodystanford 2017-Mar-15
viewtopic.php?f=37&t=177427#p1131013
(Fake KY019) RE: RELAY MODULE KY-019 5V - tlfong01 2018-Jun-02
viewtopic.php?f=37&t=77158#p1323061
Posted: Thu Dec 06, 2018 5:08 am
by tlfong01
Fish Tank Management System - Adafruit Learning System
Reef-Pi: the ultimate Raspberry Pi fish tank management system - last updated 2018dec05
https://www.raspberrypi.org/blog/reef-p ... nt-system/
https://learn.adafruit.com/reef-pi-inst ... figuration
If you’ve ever had a pet fish, even the saddest of fairground goldfish, you’ll appreciate how much work and attention they require. And to those who have never owned a fish: believe me, it’s more than you’d assume.
And the moment you upgrade from goldfish to brightly coloured, tropical beauties, and replace the standard silk reeds and gravel with live aquatic plants and soil, you suddenly have to factor in things like optimum temperature and chemical levels.
Thankfully, Adafruit Learning System author and loving fish parent Ranjib Dey has been working on a tutorial series called Reef-Pi, a collection of how-to guides that help you build the ultimate in Raspberry Pi reef aquarium management system.
Reef-Pi monitors pH, chemical, and water levels, controls temperature, light, and power, and automates the management of these aspects so you don’t have to think about them. Phew!
And if you don’t fancy a massive coral-filled saltwater tank like Ranjib’s, you can use parts the Reef-Pi series for your own tank, whatever its setup, because many of the operations are similar or easy to adjust for your needs.
Any excuse to show off beautiful Jean to the world
Take, for example, my new Betta, Jean Tannen. While Jean’s tank is a much smaller size, and Jean its only resident (for now), I still need to keep an eye on the chemical balance of his water, the heat of his tank, and when his lights should be turned on or off. Even the most commonplace goldfish will appreciate many of the services Reef-Pi automates.
The Reef-Pi system uses a variety of components, including Raspberry Pi Zero and/or Raspberry Pi 3, and each stage of building the project is well-documented on the Adafruit Learning System. So if you’re looking to upgrade your tank, or have always fancied having pet fish but don’t want the hassle of tank management, give Reef-Pi a gander and see what you think.
We’re going to try it!
Sarah, our new Operations Manager, has been looking to upgrade her giant fish tank with a Raspberry Pi or two, so we’ll be sure to share her progress in the new year. If you decide to give Reef-Pi a try, or have already automated your tank with a Pi, let us know in the comments, or tag us on Twitter or Instagram!
Posted: Sun Dec 09, 2018 12:13 pm
by tlfong01
Smart Cat Bath Water Flow Volume Meter installation Notes
Water meter proximity sensor - Domoticz
https://www.domoticz.com/wiki/PiFace
Analog water meters are equipped with a x0.0001 m3 dial which makes one revolution per liter. On top of this dial a half moon iron disc is attached. By sensing the revolutions of this disc and counting them the water flow can be logged in Domoticz.
This solution uses a proximity sensor available through dx.com described as K1208065 Metal Detection Sensor Module for Arduino at just USD 7,99. It has 3 wires: Brown (+12V), Blue (ground) and black. The black wire connects to ground when metal is detected within a range of 4mm from the sensor. Also a LED at the rear of the sensor will light up. Check the documentation on the device itself because the information at the dx.com website is different (and wrong) at the time of writing.
ESP8266 Battery Powered Plant Watering - Instructables
https://www.instructables.com/id/Smart-Plant-Watering/
https://www.instructables.com/id/Batter ... -Watering/
Posted: Tue Dec 11, 2018 5:03 am
by tlfong01
(Load Cell Testing) RE: READING OLD WEIGHT SCALE - tlfong01 2018nov22
viewtopic.php?f=37&t=227137#p1395349
