ranpitime
CODESYS on Raspberry PI
Fri Dec 20, 2013 3:28 pm
using Raspberry PI as plc with CODESYS V3 is now possible and available:
Steps to use it:
1. Register here and download CODESYS V3.5SP4
http://www.codesys.com/download/password-inquiry.html
-> install it
2.
then download the Raspberry Pi Image here:
http://store.codesys.com/codesys-contro ... ry-pi.html
boot the pi with that, now yoou could scan the raspberry Pi
Install the package in CODESYS (Package Manager)
Many CODESYS examples are included with that Package:
(After installing the Package you'll find the examples here:
"c:\Users\<yourname>\CODESYS Control for Raspberry PI" )
What is possible?
EthercatMaster
ModbusTCP / Master & Slave
Ethernet / IP Scanner
Using PIFace
Using PICam (Trigger Images by plc...)
Webvisu which is executable on Android's and IPhone/Ipad
SoftMotion
If anyone need a debian package for installing the plc on his existing image you need to ask support@codesys.com for
codesyscontrol_V3.5.4.0.deb ...
have fun!
