RF Transmitter FS1000A control up to 1000 Channels/Items
Posted: Fri Nov 22, 2013 11:18 pm
by thienson30
Control Power Outlet or 315/433/433.29mhz Relay Receivers by using RF Transmitter - FS1000A. By using only 1 Raspberry and this RF transmitter , I can control up to 1000 channels( fan, gate, light, hard drive security, garage, curtain, lock, door entry, HVAC,etc..). Check out my video at http://www.youtube.com/watch?v=5dmvT6vTV2w
Re: RF Transmitter FS1000A control up to 1000 Channels/Items
Posted: Wed Nov 27, 2013 5:22 pm
by danjperron
Hi thienson30,
Nice job, impressive!
You didn't talk about the receiver which is the more important stuff in my point of view. Sending is easy but receiving it is an other part. What did you use on the receiving part.
I do have concern when everything is wireless. Did you encrypt the signal ? What append if your neighbour got the same system. If I capture a data packet with a snifer and if I reproduce it , will it work?
Daniel
Posted: Wed Nov 27, 2013 7:20 pm
by thienson30
The signal on this one is similar to this Transmiter http://www.ebay.com/itm/Hot-433MHZ-Wire ... 1c37240442
(this link is not my product).
It's ASK Transmitter module. The receiver producs are available on ebay. If I encoded the signal, then it won't work; however,
if customer want me to do freelance work for more secured system, I can implement it by using 4 Channels Receiver with one Relay and 3 AND gates (triad maybe) two transmitter modules on Raspberry PI to send signal out. One transmitter to scramble and other to send out message. On the Receivers side is 4 Channels to control one relay. If you know how these transmitter and receiver work, you will know the number of possibilities that can't be hack in. I can make this system is about 99.99 percent unhackable signal. But in the mean time for general audiences and general receivers available on the market, I made it this way.
Thank you for your output
Posted: Wed Nov 27, 2013 7:23 pm
by thienson30
One more thing, the system still work even most of the time, even if neighbors have the same system because most of the RF receivers will not have the same code. Only time it's not working is both of them turn on the same time;
Regards;
Posted: Sun Dec 15, 2013 11:57 am
by chiragpatelbh
thienson30 wrote:I have a project to control 315/433/433.29mhz Receivers by using RF Transmitter - FS1000A. By using only 1 Raspberry and this RF transmitter , I can control up to 1000 channels( fan, gate, light, hard drive security, garage, curtain, lock, door entry, HVAC,etc..). Check out my video at https://www.youtube.com/watch?v=KZ59sDgKqXE
Can you please share the project details like hardware required and program file, my mail id is chiragpatelbh@gmail.com
i am working on similar project but could do only with GPIO and struglling with serial programming and WIFI operations.
Posted: Sun Dec 15, 2013 4:02 pm
by thienson30
rfCommandMe Software - you can download at http://CommandMe.net/DownloadFiles/rfCommandMe and you can use to control GPIOs for free. If you want to check the hardware out, below are the links to all hardwares from RF power outlet to RF Receiver.
wget http://CommandMe.net/DownloadFiles/rfCommandMe
chmod a+x rfCommandMe
rfCommandMe GPIO gpioNumber ON or OFF
Transmitter
http://www.ebay.com/itm/Raspberry-PI-rf ... 3f2c50cc90
RF Outlet and RF Receiver
http://www.ebay.com/itm/Raspberry-PI-Ho ... 3f2d84c061
http://www.ebay.com/itm/Raspberry-PI-rf ... 3f2c6627b2
http://www.ebay.com/itm/Raspberry-PI-RF ... 3f2bcacab3
http://www.ebay.com/itm/RF-Transmitter- ... 3f2c2a8a71
Posted: Thu Dec 26, 2013 2:19 pm
by chiragpatelbh
Dear Thienson,
with GPIO i can control 8 items but how can i 1000 nos,
still not getting, pls explain
Posted: Thu Dec 26, 2013 3:42 pm
by thienson30
Before I mentioned about control 8 items /devices... at the time, I was hardwire multiple transmitters to Raspberry PI (each transmitter control 4 devices/RF Relay Receiver). That was why I said 8 items. Now, I am using only one Transmitter FS1000A module to control up to 1000 devices/ RF Relay Receivers. Just place your raspberry PI at your TV to play movie while controlling things in the house.
Posted: Sat Dec 28, 2013 2:02 pm
by chiragpatelbh
Dear Thienson,
thanks for reply,
FS1000A is transiver for wifi connection,
but which pins you are using GPIO, I2c or UART,
and how you are giving adresses to slaves.
can you share your python program?
Posted: Wed Jan 08, 2014 6:37 am
by thienson30
I'm using GPIO 23 to connect to Data PIN on Transmitter. I can use any GPIO to transmit ( I had tested and most of GPIOs will work); Source code will not be given out; however, it is very cheap to purchase rfCommandMe Licenses ( $4.99 per 4 channels / RF receivers). You can use it with you own software or you can use with my web interface or CommandMe Android App.
Check out my SIMULATOR at http://CommandMe.net and click on SIMULATOR(this PI is running from my house. I just disconnected the Transmitter Module for demonstration purpose).
Posted: Fri Apr 18, 2014 7:36 pm
by sej7278
i'm interested in this but don't understand how you can use one transmitter to control 1000 devices, as usually these modules (e.g. with remote keyfob or learn button) only have 4 codes.
Posted: Sat Apr 19, 2014 4:27 am
by thienson30
If you really want to see how it work, I list them on Ebay (just search for rfCommandMe) you can purchase and try them out . I have RF Power outlet, Door Sensors and RF receiver
RF Power Outlet, Transmitter Module and 85volt to 250 volt RF Relay Receiver
http://www.ebay.com/itm/271371126859?ss ... 1555.l2649
12Volt RF Relay Receiver
http://www.ebay.com/itm/271370972537?ss ... 1555.l2649
Posted: Sun Apr 20, 2014 12:00 pm
by sej7278
i've seen them on ebay, but i won't buy something if i don't know how/if it works. your relay module in the single listing looks different to others on ebay (same as your 5 listing), so i assume you've added a microntroller to expand the number of channels possible, which would make them incompatible with "normal" relay modules elsewhere on ebay.
Posted: Tue Apr 22, 2014 10:27 pm
by thienson30
These are Radio Frequency Relay Receivers, It acts like a switch to turn on/off but by electronic signal and controlled by a transmitter module.
Posted: Sat Dec 20, 2014 12:04 am
by fabricioncosta
In this product, is it possible to the raspberry identify if the relay is on or off?
Thanks,
Fabrício
