Can I use Pi;'s GPIO out signal as the signal of RC receiver
Posted: Mon May 27, 2013 11:35 pm
by yusuk
I want to controll multicopter using Raspberry Pi.
So.. is it possible to use Pi's GPIO signal as the signal of the RC receiver's(ex. http://www.hobbyking.com/hobbyking/stor ... ch=turnigy 9x) out signal.
Re: Can I use Pi;'s GPIO out signal as the signal of RC rece
Posted: Mon May 27, 2013 11:56 pm
by redhawk
The Pi's GPIO can provide several TTL outputs so assuming you're referring to the 2.4GHz transmitter and not the Pi as a transmitter then I see no reason why it shouldn't work.
Richard S.
Posted: Tue May 28, 2013 2:46 am
by elektrknight
If you want to drive servos from Pi GPIO then many RC servos will work with the 3.3V
signal level Pi can output, however some older ones might need a TTL like levels.
There is this thread "Servo's and the raspberry pi" you might want to check
http://www.raspberrypi.org/phpBB3/viewt ... 26&t=44402
BTW Pi GPIO is not TTL.
