Gadjetnut
Alarm System
Fri Apr 05, 2013 9:31 pm
http://www.projects.privateeyepi.com/home
Learn how to create a home alarm system with your Raspberry Pi.
This project is free of charge and built by Raspberry Pi enthusiasts for others to enjoy and contribute.
The alarm system has the following features:
- Email alerts
- Web based dashboard where you can arm zones, view alarm alerts and activity logs. Access your dashboard from your iPhone or your PC!
- Configuration tool that allows you to set up as many zones and alarm contacts as you like
We supply you with all the instructions on how to build the electronics required to interface with sensors. And we also supply you with all the code (Python) and instructions on how to install and run it.
You do not need to have any prior electronic or programming experience. The tutorial is designed to provide you with a very useful tool that you can build quickly.
Please visit our website and check it out !
Thank you,
Jonathan Evans
