rajunair
How to deagin a digital water meter using RPI
Wed Mar 06, 2013 7:08 am
Hi
hoe can i design a digital water meter using rpi ..?
malakai
Re: How to deagin a digital water meter using RPI
Wed Mar 06, 2013 7:45 am
Can you be more specific. Are you measuring the depth of the water? PH or chemical make-up? Temperature? or all of the above? Ultimately that would help decide the type of meter you would be looking at purchasing then a search for code that has already been made for that meter and the Pi.
http://www.raspians.com - always looking for content feel free to ask to have it posted. Or sign up and message me to become a contributor to the site. Raspians is not affiliated with the Raspberry Pi Foundation. (RPi's + You = Raspians)
rajunair
Wed Mar 06, 2013 8:55 am
Basically i am looking for a water usage meter .For billing purpose
domodom
Thu Mar 07, 2013 2:37 pm
The solution that i implemented in my home is buying watermeter like this one : http://www.wickes.co.uk/34in-class-c-do ... vt/228208/
Then i glued a magnet on one of the needle (the needle that count the liters at each turn).
With a reed switch like this one (http://www.produktinfo.conrad.com/daten ... R_6_VA.pdf) connected to a 1-wire counter (ds2423).
Best regards
dom
Des cartes d'extension françaises pour Raspberry PI : www.yadom.fr
aeb
Mon Mar 11, 2013 9:39 pm
Presuming you have a ballcock on your water tank;
Mount a piece of plastic above the ball cock
Mount a microswitch (one with the lever on it) so that it is
switched by the ballcock (make the microswitch adjustable for height)
Connect to a GPIO pin and 0v with 10 k resistor to 3.3v pin and Gpio pin
Get Pi to count time time that the ballcock is down via the GPIO pin.
Calibrate ........in litres per sec
Consumption is total of times x calibration
only problem may be that (some) your water may come directly off the supply
superpat999
Wed Mar 13, 2013 2:42 pm
HI
Ebay have a lot of pulsed water meters, A WRAS approved type is around £50.00
cheers
P
bwoodbury
Wed Mar 13, 2013 3:21 pm
Although the following link is for a water meter setup using an arduino it may give you some ideas to consider
http://labs.teague.com/2010/11/04/diy-a ... ter-meter/
