How Many Sensors/Motors Can a Raspberry Pi 3 Handle at Once?
Posted: Mon Sep 16, 2019 10:58 pm
by SmokeySpace
I'm building a robot with the Raspberry Pi 3 and I have 2 small 3-6v DC motors with wheels hooked up to an H Bridge Motor Drive Controller (powered separately with a 9 volt battery) and I also want to be able to have the robot see around itself as its driving with the motors, whether this is with 3 separate range sensors or one range sensor on a micro servo motor. I've done some research but I haven,t been able to come up with a definite answer, so are either of these options available? Which would be better / more efficient? I'm pretty new to circuits like these so thanks for all the help!
Here are the parts I'm using -
H Bridge - https://www.amazon.com/gp/product/B01M2 ... UTF8&psc=1
Range Sensor - https://www.amazon.com/IIVVERR-Ultrason ... =hi&sr=1-5
Servo motor - https://www.amazon.com/Muluo-10PCS-Heli ... =hi&sr=1-3
Motors (only using 2) - https://www.amazon.com/gp/product/B07DQ ... UTF8&psc=1
Thanks for all the help!
Re: How Many Sensors/Motors Can a Raspberry Pi 3 Handle at Once?
Posted: Tue Sep 17, 2019 7:38 am
by pcmanbob
Hi.
You can work this out for yourself,
The pi has 26 possible gpio pins for use ,
you just need to add up how many gpio pins you need for each device
H-bridge = 6
range sensor = 2 for 3 sensors = 6
servo = 1
total 13
so you still have 13 gpio left
its as simple as that.
Posted: Tue Sep 17, 2019 12:57 pm
by SmokeySpace
Hi.
H-bridge = 6
servo = 1
total 13
Ok that makes sense, but is the Raspberry Pi actually able to power all that at once? If not how much can it power?
Posted: Tue Sep 17, 2019 1:51 pm
by pcmanbob
You are only taking about sending high or low signals to the H-bridge so a mA or 2 at most per gpio pin,
same goes for the servo pwm signal for control ,
you should be able to power a small servo like the SG90, from the 5v gpio pin , probably 200mA max,
range sensor assuming HC-SR04 15mA per sensor.
So if you total all this up approx 250mA, you should have no problem powering it all from the pi gpio.
Posted: Tue Sep 17, 2019 3:32 pm
by amcdonley
(Corrected)
"GPIO 5v pin" means one of the two 5v pins on the GPIO connector.
The SG90 can draw 600-700 mA stall and instantaneous which can sag the 5v supply in some cases. It would be advisable to add a small 5v switching supply connected to your 9v motor battery for any servo power.
(If I center both of my SG90s from their limits simultaneously, my RPi sets the voltage throttled flag. )
Posted: Tue Sep 17, 2019 3:35 pm
by joan
I have powered multiple small 9g servos from the Pi's 5V pins.
The logic supply required from the 3V3 GPIO to position a servo is insignificant.
Posted: Tue Sep 17, 2019 3:44 pm
by SmokeySpace
Ok thanks so much for all the help!
