konnecttosanjay
Codesys <<--- >> VMwarePlayer((RaspberryPI)) putty ssh login -- ok
Thu Aug 01, 2019 12:00 pm
i am trying the following configuration : with the following error
[INFORMATION] Executing SSH command on pi@192.168.234.128: Stop runtime system
[INFORMATION] Executing SSH command on pi@192.168.234.128: Package: store existing CFG file
[INFORMATION] Executing SSH command on pi@192.168.234.128: Package: remove old
[INFORMATION] Executing SCP command on pi@192.168.234.128: Package: transfer new runtime system
[INFORMATION] Executing SSH command on pi@192.168.234.128: Package: install new runtime system
[INFORMATION] Executing SSH command on pi@192.168.234.128: Retrieving package information
[INFORMATION] Executing SSH command on pi@192.168.234.128: Retrieving CPU type
[INFORMATION] Executing SSH command on pi@192.168.234.128: Retrieving user cfg file
[ERROR] Expected exit value of command failed: expected 0, received 1
[ERROR] Error output: cat: /etc/CODESYSControl_User.cfg: No such file or directory
codesys not able to find/load my virtual raspberry pi machine
screen shot attached .. help needed ..
ranpitime
Re: Codesys <<--- >> VMwarePlayer((RaspberryPI)) putty ssh login -- ok
Sat Sep 14, 2019 6:32 pm
this works only on the real PI hardware...
There is a Linux SL available but only for 64Bit Debian,
BR
ranpitime
