Im4X
Controlling the generated force of a voice coil actuator
Tue May 07, 2019 1:49 pm
Hey guys!
I am currently working on a project containing Hall-Sensors (measurment of magnetic fields) and voice coil actuators (high frequency linear motors, which have a force proportional to current output).
I don't know how to describe my knowlege better than "non-existent":
My task is to measure a magnetic field using a Hall-Sensor and generating a force proportional to that magnetic field. In order to do so, I've thought about this:
1. Measuring the magnetic field ( https://docs-emea.rs-online.com/webdocs ... 06a158.pdf)
2. Transforming that signal with an ADC (https://learn.adafruit.com/raspberry-pi ... sh-ads1115)
3. feeding the RaspPi with that information
3. using PWM to stimulate the gatevoltage of H-bridged motor driver (https://docs-emea.rs-online.com/webdocs ... 620d96.pdf)
4. using a current-power-supply for the motor driver
My goal is to control the current's amplitude, that is running through the motor and my questions are: is the idea above realizable, or is there a even better way?
Thank you!
Greetings
Im4X
omegaman477
Re: Controlling the generated force of a voice coil actuator
Thu May 09, 2019 10:37 pm
Hey guys!
Thank you!
Greetings
Im4X
A valid approach to design. Generally speaking, measuring magnetic fields is tricky, and usually requires several sensors depending on the field orientation(s), as is screening/rejection of environmental fields. Also depending on your sample, compute, control timing and sample rates, do ensure that the RPI is capable of handling the workload real time. But using dedicated ADC and PWM chips will assist greatly.Sounds an interesting project.
..the only thing worse than a stupid question is a question not asked.
Gavinmc42
Fri May 10, 2019 2:17 am
I have used light as the position feedback from voice coils.
It removes the magnetic field influences.
Voice coils are simple linear devices so if you measure/control current the rest is simple maths, which I have forgotten :oops:
I'm dancing on Rainbows.
