lucas1
raspberry pi connect button problem
Sat Mar 30, 2019 5:48 pm
Hi, is it possible to connect such a button to the raspberry pi and read values from GPIO?
Am I forced to connect all 5 pins from this button? I tried only with 3.3 v, GMD and pin "C" but I received unstable results. Something like 111111000000001111111
I tested using this code
import RPi.GPIO as GPIO
import time
GPIO.setmode(GPIO.BOARD)
GPIO.setup(7, GPIO.IN, pull_up_down=GPIO.PUD_UP)
for _ in range(100000):
    time.sleep(0.5)
    print(GPIO.input(7))
B.Goode
Re: raspberry pi connect button problem
Sat Mar 30, 2019 5:55 pm
Purely a guess - looking at the documentation or data sheet for the assembly would be more reliable - but my interpretation would be C = Common; NC = Normally Closed; NO = Normally Open.
So I would use C and whichever of the other 2 seems to match your needs.
PhatFil
Sat Mar 30, 2019 5:58 pm
connect either 3.3v or Gnd to C (common).
then connect either NC (Normally closed) or NO (Normally Open) to a gpio pin. NO for normal use...
you should also probably use a pull up/down resistor too
https://grantwinney.com/using-pullup-an ... pberry-pi/
If C (Common) is connected to +3v3 a 220ohm resistor between your button gpio and gnd will pull the signal down to gnd when the button is not pressed
if you connected gnd to common use the 220ohm resistor to connect the gpio to +3v3 to pull the signal high when not pressed.
edit ** disconnect the pi from power before touching the gpio and check everything 3 times before powering back up.
Burngate
Sat Mar 30, 2019 7:16 pm
At a guess, the other pins labelled + and - are for an in-built LED and can be ignored.
ptimlin
Sun Mar 31, 2019 8:45 pm
Agreed. This is a lighted button and if the original poster wants to just use the switch then they need "C" and then at least one other of the NC or NO terminals. "C" all by itself, as in the original post, does nothing for you. Switch schematic should be...
When the switch is not being pushed then C and NC (normally closed) are shorted together. When you push the button then C switches over to short with NO (normally open but now that you are pushing the button, you are no longer "normal" default state).
