vindi93
Rack and pinion
Sun Mar 03, 2019 10:41 pm
Hi im new to this automation part of things. Im looking at using my stepper motor with a rack and pinion setup. My stepper motors shaft is 7mm. on trying to find a spur gear to fit it i find MOD1 sizes which seems to replace TPI. Am i right in thinking a MOD1 spur gear will fit a MOD1 rack?
Gavinmc42
Re: Rack and pinion
Mon Mar 04, 2019 2:48 am
Yep Mod1 gears will fit Mod1 rack.
Module gears are easy to figure out.
10 tooth mod1 is 10mm diameter when meshed.
However with a rack it is Pi x mod x teeth distance travelled per revolution.
10 teeth 1 rev = 31.4159...mm
You may need something above 15, 16 teeth to allow for that shaft size.
SDP/SI is my first port of call for specs, many places stock their parts.
https://www.sdp-si.com/
7mm is a bit of an old shaft size, 6mm, 1/4" and 8mm are more common.
Easy enough to get smaller hole size and drill it out.
I'm dancing on Rainbows.
OutoftheBOTS
Re: Rack and pinion
Mon Mar 04, 2019 3:29 am
Just out of interest why are you using a rack and pinion over a lead screw or belt pulley??
There is tons of buy off the shelf and plug and play of these 2 systems
here is example of belt driver for a linear actuator https://www.aliexpress.com/item/Durable ... st=ae803_5
here is example of lead screw linear actuator https://www.aliexpress.com/item/NEW-Ope ... st=ae803_5
Gavinmc42
Re: Rack and pinion
Mon Mar 04, 2019 5:35 am
Rack and pinion is quite common for the messier cutter, tolerant of dirt etc
http://www.shopbottools.com/mProducts/ShopBotdesign.htm
I have even seen toothbelts as a sort of rack, the belt is fixed at each end.
vindi93
Re: Rack and pinion
Mon Mar 04, 2019 10:29 pm
i am building an automated fish feeder so i dont really want a lead screw design as it needs to be fairly compact but still run a linear motion.
