tlfong01
Re: Connecting electromagnet to pi
Tue Mar 05, 2019 4:45 am
jadel wrote:
Tue Feb 26, 2019 2:50 pm
I built the magnet myself and want to run 12V into it, it has 2 ohm resistance so the current will be 6 A.
Electromagnet DIY
I am jealous of someone building an electromagnet himself. So I am also building one myself. I googled the Cool Magnet Man and found his tutorial very good.
Electromagnets - Cool Magnet Man
http://www.coolmagnetman.com/magelect.htm
I am an electronics and smart home hobbyist.
tlfong01
Tue Mar 05, 2019 12:59 pm
tlfong01 wrote:
Tue Mar 05, 2019 4:06 am
I measured 1 to 4 magnets and found it very tiring to do the measurements, perhaps because (1) the magnet has a big range of values, so the values for 1, 2, 3, and 4 magnets do not add up proportionally, (2) My visual measurements are not accurate at all (I should have used the scope's digital ruler to do the measurements, but I am too lazy to learn). My conclusion is that my results are not reliable and not repeatable.
I can only said that the average inductance is very very roughly 5mH.
Measuring Solenoid Inductance
Now I am moving on to solenoid inductance measurement, and see if it is different from measuring electromagnets, and perhaps finding out anything wrong with my measuring procedures.
tlfong01
Tue Mar 05, 2019 2:23 pm
Measuring Solenoid Inductance - Unsatisfactory Results
I measured 4 solenoids, from 0.8N to 20N. The results is not satisfactory at all. Two solenoids find Vr leading instead of lagging Vs. I guess perhaps the coil's internal resistance is relative bigger than average, and make the measurements unreliable.
Anyway, I found the inductance values roughly 3 to 4mH.
jadel
Tue Mar 05, 2019 2:29 pm
Thanks for the help everyone got it working.
Just curious if I wanna have more than one magnet does each need it's own power supply or could I use the same one for more than one magnet.
tlfong01
Tue Mar 05, 2019 2:32 pm
All magnets can share the same power supply, if total power is not exceeded.
jadel
Tue Mar 05, 2019 2:42 pm
Would the circuits be similar to the one for a single magnet or would I have to make big adjustments?
tlfong01
Tue Mar 05, 2019 2:57 pm
the average inductance of the electromagnets is roughly 5mH.
the average inductance of the solenoids is roughly 4mH.
Finding Energy Stored in Solenoids
Now that I have a rough idea of the order of the inductance of the electromagnets and solenoids I am playing with is around 3 to 5mH, I can now calculate the energy stored using the formula below. Then I can select a big enough flyback diode.
But I have little confidence that my measurements are correct, because I am using a cheap function generator and my measurements using human eye, instead of scope doing the measurement and calculation (phase difference between Vs and Vr etc) is far from professional, and can only be treated as an appreciation of basic inductance concepts and experiments at undergraduate level. (After all the readings and experiments, now I appreciated the use of the mysterious j "operator", which previously I wrongly thought that j was an "unit"! :mrgreen: )
Anyway, let me now trying to calculate the energy stored in the electromagnet ZYE1-P20/15 DC6V 0.5A.
Apply the formula, assuming inductance 5mH, current 0.5A, the energy stored is:
E = 1/2 * 5mH * 0.5A ^ 2
= 0.5 * 5 * 0.001 * 0.5 * 0.5
= 0.000625 J (not sure if the unit is Joule! :mrgreen: )
= 625 uJ ??? (not proofread, because I cannot count more than 5 zeros!)
I have no confidence that I am doing anything meaningful. So I think I better stop here and just use the flyback diode I think OK - 1N5822, which I found is also being used OP's SaintSmart realy board! :mrgreen:
tlfong01
Tue Mar 05, 2019 3:09 pm
which the one? :mrgreen:
jadel
Tue Mar 05, 2019 4:58 pm
tlfong01
Wed Mar 06, 2019 12:58 am
which the one?
Big Picture and Long Description Please! :mrgreen:
Oh my goodness, you speak like my girl friend - shorter than her mini skirt. I wish you speak like my grandma, longer than her wrinkles. :mrgreen:
Big/Long Example
https://www.raspberrypi.org/forums/view ... 0#p1437206
Remember we want information - no information no help. The use of crystal balls & mind reading is not supported - pcmanbob
Longer - Dan Fogelberg - 6,037,889 views
https://www.youtube.com/watch?v=5Go6I2_PpBU
tlfong01
Wed Mar 06, 2019 5:54 am
Flyback diode for Songle 5V Relay
Now I want to know the energy stored in the Songle 5V relay, then select a Schottky diode strong enough to swallow the flyback in one bite.
tlfong01
Wed Mar 06, 2019 6:29 am
Songle 5V Relay Inductance ~= 40mH
tlfong01
Wed Mar 06, 2019 6:36 am
tlfong01
Wed Mar 06, 2019 7:07 am
Energy Stored in Songle Relay = 100uJ
Now I know the inductance of the Songle relay is 40mH, and the current is 70mA, I can calculate the energy stored in the relay.
E = 1/2 * (L * (I^2))
= 0.5 * 40mH * 70mA * 70mA
= 0.5 * 40 * 70 * 70 * 10^-9
= 98uJ
~= 100uJ (no proofread, because I cannot count more than 5 zeros! :mrgreen: )
Appendix - Songle Relay References
Songle Relay Characteristics
https://www.raspberrypi.org/forums/view ... 5#p1326822
https://www.raspberrypi.org/forums/view ... 5#p1324588
KY019 Sognle Relay Circuit
https://www.raspberrypi.org/forums/view ... e#p1422847
Optocoupler EL817/EL354
https://www.raspberrypi.org/forums/view ... 0#p1340670
KY019 Total Optical Isolation
https://www.raspberrypi.org/forums/view ... 0#p1340703
Forbes Relay Board
https://www.raspberrypi.org/forums/view ... 0#p1340696
MCP23017 + ULN2803 Relay Circuit
https://www.raspberrypi.org/forums/view ... 5#p1325530
Old Relay Posts to Refresh Memory
https://www.raspberrypi.org/forums/view ... e#p1357461
jadel
Wed Mar 06, 2019 10:22 am
My question is more about a general possibility. Could I control let's say five electromagnets using one relay board and one power supply?
(while supplying each magnet with about 12V)
tlfong01
Wed Mar 06, 2019 11:56 am
tlfong01
Wed Mar 06, 2019 2:04 pm
Songle 5V Relay Toggling at 1 Hz
Songle relay 2019mar0601
https://youtu.be/XZxZ5fhoK9o (youtube)
tlfong01
Wed Mar 06, 2019 2:33 pm
tlfong01 wrote:
Tue Mar 05, 2019 1:10 am
tlfong01 wrote:
Mon Mar 04, 2019 6:18 am
No flyback diodes across relay switch
ULN2803 Output Clamp Diode passes relay flyback current
ULN2803A Darlington Transistor Arrays Datasheet - TI
http://www.ti.com/lit/ds/symlink/uln2803a.pdf
tlfong01
Wed Mar 06, 2019 3:00 pm
50Ω 17mH Electromagnetic Buzzer Testing
https://youtu.be/EFLLeVPuYbs (youtube)
tlfong01
Thu Mar 07, 2019 7:23 am
50Ω 17mH[/b][/color] Electromagnetic Buzzer Testing
6Ω DC3V~6V TT Motor Induceance Measurement - Unsatisfactory
I found the inductance of the motor roughly 2mH. Perhaps because the coil resistance is too small, so the measurement is difficult to make. I found Vr even leading Vs. I guess there is something wrong with my setup or procedure. Anyway, I think the order of 2mH is 50% OK. :mrgreen:
