ab.rodrigo
Simulation of a One Wire Sensor using Raspberry Pi
Fri Jan 04, 2019 6:54 pm
I'm currently developing my undergraduate thesis and I have to build a simulator of a DS18B20 Temperature Sensor using the Raspberry Pi platform. In other words, I have to show how a DS18B20 works by constructing codes (in C++ or Python) that simulate the activities of the sensor. This codes will run in a Raspberry Pi 3 Model B (which will function as a slave device) and it will communicate by a One Wire Network with another Raspberry Pi 3 Model B (which will function as a master device). Is there any material that can help me with this task?
bensimmo
Re: Simulation of a One Wire Sensor using Raspberry Pi
Fri Jan 04, 2019 6:55 pm
OWFS (One Wire File System)
Look at that, it'll do everything you ask.
hippy
Fri Jan 04, 2019 11:47 pm
My previous comment to your question asked on another thread asking about using a Pi as a 1-wire slave -
viewtopic.php?f=44&t=163028#p1409936
ab.rodrigo
Sat Jan 05, 2019 2:29 pm
Thank you so much for your replying! :)
ab.rodrigo
Sat Jan 05, 2019 2:30 pm
Thank you so much for your replying! I’ll have a looke at this file! :)
