RaspberryPiBeginners
Suitable moter and battery for the GertBoard
Fri Nov 16, 2012 2:27 pm
Can anyone recomend a Suitable moter and battery for the GertBoard
Click here for my unofficial YouTube Channel > http://goo.gl/oFYBD
joan
Re: Suitable moter and battery for the GertBoard
Fri Nov 16, 2012 3:16 pm
That might be too general a question. I'm not familiar with the gertboard but I guess it could drive lots of different hobby type motors. Do you have a particular use in mind? Is the battery to drive the motor?
Fri Nov 16, 2012 4:14 pm
Yeah the battery would be to drive the motor. Not sure it doesn't have to be massive just something maybe big enough to power a fan?
poglad
Fri Nov 16, 2012 4:16 pm
Gert implied in another thread that driving a motor with < 9V power into the motor controller is unlikely to work.
poing
Fri Nov 16, 2012 4:22 pm
The Anker battery I use has two 5V USB outputs and one 9/12V output: http://www.ianker.com/anker-astro-exter ... 2-B16P100A
jweob
Sat Nov 24, 2012 4:11 pm
I found this thread while trying to figure out why I couldn't get the motor controller to work on the gertboard. Thanks poglad for suggesting that there is a minimum supply voltage, I think this is my problem. I am using a mini 5V motor for testing, but looking at the datasheet for the motor controller (http://users.ece.utexas.edu/~valvano/Da ... /L6203.pdf) the minimum supply voltage is 12V. I need to get a bigger motor!
Thought I would put this up here in case anyone else has the same problem...
Gert van Loo
Sun Nov 25, 2012 6:32 pm
Hi, the same as been remarked in the Gertboard thread.
I have found, just like others, that the controller seems to function down to 9V.
-- Gert
