Will5455
robot controller
Fri Dec 07, 2018 12:47 am
Does anybody know of a good robot controller capable of 6v with variable speed who is not a hat?
I do strange things and am sometimes the techhead stereotype.
deal with it!
mikronauts
Re: robot controller
Fri Dec 07, 2018 1:04 am
Do you mean motor driver?
PWM allows speed control with geared motors.
Or do you mean stepper motors or servo's?
You should also post the maximum current your motor may need.
Please post a link to the motors web page.
Will5455
Fri Dec 07, 2018 3:00 am
yep meant motor controller not rbot controller!
https://www.dfrobot.com/product-1477.html
this is the set of stuff
deal with it!
mikronauts
Fri Dec 07, 2018 3:18 am
Good looking chassis!
From their site, I would get
https://www.dfrobot.com/product-1534.html
Will5455
Fri Dec 07, 2018 12:56 pm
it seems to output a minimum of 6.5 or 7 volts (I am not to great with data sheets yet) so would that kill it? it is a 90 buck set and that is a little much to frie because I don't know what I am doing.
deal with it!
mikronauts
Fri Dec 07, 2018 1:55 pm
From chassis spec
Rated Voltage: 6 V
Operating Voltage Range 2~7.5V
From driver board
Voltage supply: DC 7 ~ 24 V
Voltage supply limit: 6.5 ~ 27 V
Note motor drivers drop 0.5v ... 1v from their supply voltage before "feeding" the motor
However you can get any driver board as long as it can supply 2.3A per motor.
Will5455
Mon Dec 10, 2018 5:11 pm
THANK YOU!
deal with it!
Will5455
Mon Dec 10, 2018 5:15 pm
now a important question. Any battery for at least 30 minutes of playtime?
deal with it!
mikronauts
Mon Dec 10, 2018 6:32 pm
Assuming 1A load while moving @ 7.4V, with two motors
2 * 1A * 0.5h is 1amp-hr capacity for an rc nimh or nicad 7.4v battery pack
But, it is best to test this in real life, as it depends on weight of robot, surface you are on, speed and more.
Btw, use a separate usb battery pack for the pi etc
Will5455
Mon Dec 10, 2018 6:35 pm
hmm maybe use a 2 ah for the purpose of making sure?
deal with it!
Will5455
Mon Dec 10, 2018 6:41 pm
also maybe a link because I am new to this?
deal with it!
mikronauts
Mon Dec 10, 2018 6:59 pm
My friend, go to a local rc hobby shop, or google for 7.4v rc battery pack, 2ah :)
I do drive by help posts here im my coffee breaks and when compiling code or flashing chips, I usually do not have time to also do the googling leg work for those I help.
Will5455
Mon Dec 10, 2018 8:00 pm
I live in a little town you have never heard of known as harrisonville mo
deal with it!
mikronauts
Tue Dec 11, 2018 2:06 am
One example: https://www.amazon.com/Venom-5000mAh-Ba ... B000VUF3O2
There is a hobby shop in your town
https://www.yellowpages.com/peculiar-mo ... =530737830
Took me 10sec to find via google
Gavinmc42
Tue Dec 11, 2018 2:53 am
Those are probably one of the best looking tracks on a tracked bot I have seen.
I want some :D
I prefer 12V motors running at lower speeds and lower current, with 8-10 AA NiMH cells.
Brushless motors are getting more affordable, gearboxes are still the issue, too noisy.
Magnetic gears are now entering mainstream, low cost hobby magnetic gear box?
I'm dancing on Rainbows.
Will5455
Thu Dec 13, 2018 1:03 pm
that is in peculiar I am in harrisonville!
deal with it!
