brucelevy
Reading sensor
Tue Dec 04, 2018 5:19 am
I have a AM2302 temp/humidity sensor (https://www.adafruit.com/product/393) and a Pi 3 B+.
I am attempting to read the temp data from GPIO15 (Pin10) but cannot find the correct code to pull the data.
+ is connected to 3v3 (Pin1)
Out is connected to GPIO15 (Pin10)
- is connected to GND (Pin6)
What code can I use to display data in Python 3?
I was unable to pull the serial of the sensor with the following:
sudo modprobe w1-gpio
sudo modprobe w1-therm
cd /sys/bus/w1/devices/
ls
markkuk
Re: Reading sensor
Tue Dec 04, 2018 12:07 pm
Install the Adafruit DHT library. AM2302 is not a Dallas 1-wire sensor, it's a DHT22 in a different package.
