Page 2 of 5
Re: Reading old weight scale
Posted: Fri Nov 23, 2018 11:59 am
by tlfong01
tlfong01 wrote:
Fri Nov 23, 2018 8:11 am
1kg Load Cell Test Results
Load / Output
500ml water = -1.9V
500ml water + 110 ml milk = -2.2V
Sensitivity Calculation
Linearity Graph
Posted: Fri Nov 23, 2018 2:20 pm
by tlfong01
5kg Load Cell Test Results
I have also tested a straight bar 5kg load cell.
/ to continue, ...
Posted: Sat Nov 24, 2018 4:03 am
by tlfong01
Load / Output
500ml water = -1.9V
Linearity Graph
1kg Load Cell Testing Results Update
Last time I had no confidence that the fake load cell worked, and also my hardware set up ok, so I was a bit casual and did not include the tray weight of about 160g. Now I have added the tray weight to the Excel worksheet, to make my sensitivity calculation more precise.
The sensitivity is about 0.43 mV/V
Posted: Sat Nov 24, 2018 4:41 am
by tlfong01
Load / Output
500ml water = -1.9V
Linearity Graph
Now I am using Excel to calculate the sensitivity of the 5kg load cell.
The results is too good to be true:
1.03 mV/V ! :mrgreen:
Posted: Sat Nov 24, 2018 5:30 am
by tlfong01
Load / Output 500ml water = -1.9V 500ml water + 110 ml milk = -2.2V
Sensitivity Calculation Linearity Graph
The results is too good to be true: 1.03 mV/V!
Load Cell Calibration Standard Weights
I am using a 3.5L fish tank, and 1L/1.2L lunch boxs filled with tap water as standard weights to calibrate the 1kg and 5kg load cells. For the 5kg load cell, I have done two sets of tests, one set the fish tank and a lunch box, the second set with 4 lunch boxes. The results of the first set is too good to be true. Now I am checking out the second set to see if I had a fake positive.
Posted: Sat Nov 24, 2018 7:26 am
by tlfong01
Load Cell Test Results Verified OK
I found 2nd test results looks like the 1st set. I quickly concluded that every thing is OK.
I am taking a break of testing load cells, next step is testing the HX711 thing.
Posted: Sat Nov 24, 2018 8:16 am
by tlfong01
HX711 Signal Analysis
Output Format
The output 24 bits of data is in 2’s complement format. When input differential signal goes out of the 24 bit range, the output data will be saturated at 800000h (MIN) or 7FFFFFh (MAX), until the input signal comes back to the input range.
Serial Interface
Pin PD_SCK and DOUT are used for data retrieval, input selection, gain selection and power down controls.
When output data is not ready for retrieval, digital output pin DOUT is high. Serial clock input PD_SCK should be low.
When DOUT goes to low, it indicates data is ready for retrieval.
By applying 25~27 positive clock pulses at the PD_SCK pin, data is shifted out from the DOUT output pin.
Each PD_SCK pulse shifts out one bit, starting with the MSB bit first, until all 24 bits are shifted out.
The 25th pulse at PD_SCK input will pull DOUT pin back to high.
Input and gain selection is controlled by the number of the input PD_SCK pulses. PD_SCK clock pulses should not be less than 25 or more than 27 within one conversion period, to avoid causing serial communication error.
25 pulses = A channel, gain 128
26 pulses = B channel, gain 32
27 pulses = A channel, gain 64
Clock high time = min 0.2 uS, max 50 uS
Clock low time = min 0.2 uS
0.2uS = 1,000,000 / 0.2 = 5 MHz,
50uS = 1,000,000 / 50 = 20 kHz)
Posted: Sat Nov 24, 2018 2:27 pm
by tlfong01
Output Format
Serial Interface
HX711 Testing Plan
1. Test input 1 = bench mark 0~5.5mV from adj regulated PSU
2. Test input 2 = real output from 5kg load cell.
ESP8266 Test Plan
1. Output function to write 10uS, 10kHz, 25, 26, 27 pulses to HX711 Channel B.
2. Input function to read 24 bits output from HX711
Posted: Sat Nov 24, 2018 3:01 pm
by tlfong01
ESP8266 Test Plan
Notes on writing a NodeMCU Lua program to output 26 10kHz pulses from ESP8266
Now I am doing the following preparation work.
1. Start ESPlorer.
2. Format flash.
3. Upload two debugging program tools to flash.
4. Save the two debugging programs in Snippet 0 and Snippet 1.
5. Run the print Global variables and save a record.
6. Run the print Flash files and save a record.
The log file is listed below.
Wemos D1 Mini setting up snippets - tlfong01 2018nov24hkt2248
PORT OPEN 115200
Communication with MCU..Got answer! Communication with MCU established.
AutoDetect firmware...
Can't autodetect firmware, because proper answer not received (may be unknown firmware).
Please, reset module or continue.
Flash sig not correct: 0 vs fafaaf50
NodeMCU custom build by frightanic.com
	branch: master
	commit: c708828bbe853764b9de58fb8113a70f5a24002d
	SSL: false
	modules: dht,ds18b20,file,gpio,hdc1080,http,i2c,mqtt,net,node,ow,pcm,pwm,rtctime,spi,tmr,uart,wifi
build created on 2018-10-25 07:35
powered by Lua 5.1.4 on SDK 2.2.1(6ab97e9)
lua: cannot open init.lua
> file.format()
format done.
> Uploading to ESP file pf07.lua...Success
Uploading to ESP file pg07.lua...Success
> -- printFlashFiles V07 tlfong01 2018nov24hkt2238 --
> function printFlashFiles()
>> fileList = file.list()
>> for name, size in pairs(fileList)
>> do
>> print('name =', name, 'size =', size)
>> end
>> end
> printFlashFiles()
name =	pf07.lua	size =	224
name =	pg07.lua	size =	210
> title = 'pg07.lua - printGlobalVar v07 tlfong01 2018nov24hkt2235'
> function printGlobalVar()
>> for var, value in pairs(_G)
>> do
>> print ('variable =', var, 'value =', value)
>> end
>> end
> printGlobalVar()
variable =	module	value =	function: 0x3fff0d50
variable =	pairs	value =	function: 0x3fff11e0
variable =	__index	value =	lightfunction: 0x402543c4
variable =	package	value =	table: 0x3fff0b70
variable =	_G	value =	table: 0x3fff05f8
variable =	require	value =	function: 0x3fff0d90
variable =	ipairs	value =	function: 0x3fff1008
variable =	printFlashFiles	value =	function: 0x3fff06b0
variable =	title	value =	pg07.lua - printGlobalVar v07 tlfong01 2018nov24hkt2235
variable =	printGlobalVar	value =	function: 0x3fff09c0
variable =	fileList	value =	table: 0x3fff0a50
variable =	newproxy	value =	function: 0x3fff12a0
>> do
>> end
>> end
> printFlashFiles()
Posted: Sun Nov 25, 2018 4:23 am
by tlfong01
Small size load cells
The straight bar load cell is a bit bulky, and arkward to fix. Next time I resume playing Wheatstone bridge, I think I would consider miniature versions.
Appendices - Miniature load cell references
AliExpress BF350-3AA Precision resistive strain gauge load cell - US$3/10 pieces
https://www.aliexpress.com/item/Free-sh ... 60339.html
BF350-3AA STRAIN GAUGE SENSOR Model HCSENS0037 £ 1.98
https://hobbycomponents.com/sensors/962 ... uge-sensor
A resistive strain gauge sensor with a 350 ohm nominal resistance which varies when a force is applied. By measuring the change in the sensors resistance a measurement of the force applied to it can be obtained. Note that strain gauges exhibit small changes in resistance and so this sensor should be used in a Wheatstone bridge
BE120-3AA ¥3.20
https://detail.tmall.com/item.htm?spm=a ... 6acdd72af8
BF350-3AA-15
http://shop.cpu.com.tw/html/2603/BF350-3AA-15.html
http://shop.cpu.com.tw/product/46508/info/
Coding System of Strain Gauges
https://www.elecrow.com/download/Coding ... ersion.pdf
BX120/BF350
https://detail.tmall.com/item.htm?spm=a ... abbucket=6
https://detail.tmall.com/item.htm?spm=a ... acdd72af8 ...
Posted: Sun Nov 25, 2018 5:10 am
by tlfong01
Neomorph wrote:
Sat Nov 17, 2018 4:03 pm
digital weight scale ...
to simply read out the information from the scale and print it to the terminal? ...
someone using an HX711 weight sensor ...
HX711 based Digital Weight Scale
It is very likely that your scale uses HX711, sealed inside the black dot. A work around is forget the black dot, and connect your own HX7111 to the load cell. You can also replace the LCD and button by the AliExpress cheap thing below.
The good thing of this work around is that you can data log and print anything you like, or add ESP8266 to wifi you reading, ... :lol:
AliExpress 1602 Module Display For Arduino Uno Raspberry Pi -US$2.25
https://www.aliexpress.com/item/1PCS-LC ... 02339.html
Posted: Sun Nov 25, 2018 7:18 am
by tlfong01
Saving init.lua in ESPlorer snippets and ESP8266 Flash
So I have done more preparation work, as list below.
1. Write a Hello World, saved it in ESPlorer as snippets and also in ESP8266 flash, which now has the following files.
> printFlashFiles()
name = init.lua size = 140
name = hw08.lua size = 140
I also listed the global variables for reference
> printGlobalVar()
variable = printFlashFiles value = function: 0x3fff09f0
variable = title value = pg07.lua - printGlobalVar v07 tlfong012018nov24hkt2235
variable = printHelloWorld value = function: 0x3fff09a0
variable = fileList value = table: 0x3fff13d8
variable = printGlobalVar value = function: 0x3fff06b0
	branch: master
	SSL: false
Hello World
> title = 'hw08.lua - printHelloWorld v08 tlfong01 2018nov25hkt1457'
> function printHelloWorld()
>> print('Hello World')
>> end
> printHelloWorld()
Hello World
>> do
>> end
>> end
> printFlashFiles()
>> do
>> end
>> end
> printGlobalVar()
Posted: Sun Nov 25, 2018 8:24 am
by tlfong01
ESP8266 writing 26 pulses to HX711 Program Testing Notes
Now I have debugged a program to blink D4 LED 26 times. The blink time is 100mS or 10Hz. I am not sure if ESP8266 can blink 10 times faster, at 10kHz. The program is listed below.
ESP8266 Blinky YouTube
https://youtu.be/fjFXk1qtBI4
-- bl2608 - blink D4 LED 26 times tlfong01 2018nov25hkt1606
title = 'bl26'
printTitle(title)
High, Low = true, false
Output, Input = true, false
D0, D1, D2, D3, D4, D5, D6, D7, D8 = 0, 1, 2, 3, 4, 5, 6, 7, 8
TenthSecond, EighthSecond, FifthSecond, QuarterSecond   = 100,   125,    200,   250
HalfSecond,  OneSecond,    TwoSeconds,  FourSeconds     = 500,   1000,  2000,  4000
EightSeconds, TenSeconds, TwelveSeconds, SixteenSeconds = 8000, 10000, 12000, 16000
OneTime,   TwoTimes,    ThreeTimes,    FourTimes    =  1,  2,  3,  4
FiveTimes, SixTimes,    SevenTime,     EightTimes   =  5,  6,  7,  8
TenTimes,  TwelveTimes, FourTeenTimes, SixteenTimes = 10, 12, 14, 16
TwentySixTimes = 26
function printTitle(title)
  local threeStars = '***'; local twoNewLines = '\n\n'
  print(twoNewLines, threeStars, title, threeStars)
end
function printTitleNum(title, num)
  local twoNewLines = '\n\n'; local fiveSpaces = '     '
  print(fiveSpaces, title, num)
end
function setPinMode(pinNum, pinMode)
  if pinMode == Output
    then
      gpio.mode(pinNum, gpio.OUTPUT)
    else
      gpio.mode(pinNum, gpio.INPUT)
  end
end
function setPinHigh(pinNum)
  gpio.write(pinNum, gpio.HIGH)
end
function setPinLow(pinNum)
  gpio.write(pinNum, gpio.LOW)
end
function setAllPinsOutput()
  for i = 0, 8, 1
    do
      setPinMode(i, Output)
  end
end
function setAllPinsLow()
  for i = 0, 8, 1
    do
      setPinLow(i)
  end
end
function setupPins()
  setAllPinsOutput()
  setAllPinsLow()
end
function togglePin(pinTable)
  pinNum		= pinTable.pinNum
  highTime		= pinTable.highTime
  lowTime		= pinTable.lowTime
  toggleCount		= pinTable.toggleCount
  toggleDelayTime	= pinTable.toggleDelayTime
  taskCount		= pinTable.taskCount
  printTitleNum('pinNum          =', pinNum)
  printTitleNum('highTime        =', highTime)
  printTitleNum('lowTime         =', lowTime)
  printTitleNum('toggleCount     =', toggleCount)
  printTitleNum('toggleDelayTime =', toggleDelayTime)
  printTitleNum('taskCount       =', taskCount)
  highTimer = tmr.create()
  lowTimer  = tmr.create()
  taskTimer = tmr.create()
  function highTimerCallback()
    setPinLow(pinNum)
    currentToggleCount = currentToggleCount - 1
    if currentToggleCount > 0
      then
        lowTimer:start()
      else
	taskTimer:start()
    end
  end
  function lowTimerCallback()
    setPinHigh(pinNum)
    highTimer:start()
  end
  function taskTimerCallback()
    taskCount = taskCount - 1
      if taskCount >= 0
        then
          currentToggleCount = toggleCount
          setPinHigh(pinNum)
          highTimer:start()
        else
	  printTitle('End of all toggle tasks.')
	  highTimer:stop()
	  lowTimer:stop()
	  taskTimer:stop()
      end
  end
  highTimer:register(highTime,        tmr.ALARM_SEMI, highTimerCallback)
  lowTimer:register (lowTime,         tmr.ALARM_SEMI, lowTimerCallback)
  taskTimer:register(toggleDelayTime, tmr.ALARM_SEMI, taskTimerCallback)
  taskTimer:start()
end
pinTable01 =
    pinNum          = D4,
    highTime        = TenthSecond,
    lowTime         = TenthSecond,
    toggleCount     = TwoTimes,
    toggleDelayTime = OneSecond,
    taskCount       = TwentySixTimes
function main()
  printTitle(title)
  setupPins()
  togglePin(pinTable01)
end
main()
*** Sample Output ***
> pinTable01 =
>> pinNum          = D4,
> function main()
>> printTitle(title)
>> setupPins()
>> end
> main()
	***	bl26	***
     	pinNum          =	4
     	highTime        =	100
     	lowTime         =	100
     	toggleCount     =	2
     	toggleDelayTime =	1000
     	taskCount       =	26
>      	taskCount =	25
     	taskCount =	24
     	taskCount =	23
     	taskCount =	22
     	taskCount =	21
     	taskCount =	20
     	taskCount =	19
     	taskCount =	18
     	taskCount =	17
     	taskCount =	16
     	taskCount =	15
     	taskCount =	14
     	taskCount =	13
     	taskCount =	12
     	taskCount =	11
     	taskCount =	10
     	taskCount =	9
     	taskCount =	8
     	taskCount =	7
     	taskCount =	6
     	taskCount =	5
     	taskCount =	4
     	taskCount =	3
     	taskCount =	2
     	taskCount =	1
     	taskCount =	0
     	taskCount =	-1
	***	End of all toggle tasks.	***
Posted: Sun Nov 25, 2018 1:29 pm
by tlfong01
TTP223 Capacitive Touch Button to Control HX711 Weight Sensor
Now I am thinking of using 0.5 yuan / piece touch button as input to control HX711
Button 1 - Channel B 32x
Button 2 - Channel A 64x
Button 3 - Channle A 128X
Button 4 - Reset
AliExpress TTP223 Capacitive Self Locking Touch switch sensor US$0.1 / piece
https://www.aliexpress.com/item/10PCS-L ... aa092bcf68
Posted: Mon Nov 26, 2018 1:18 pm
by tlfong01
Bad News - Program cannot blink faster than 500Hz! :(
So I changed the pintTable01 to below, with highTime and lowTime = 1 mS, and used my scope to check if D4 pin output is 1 / (1mS + 1mS) = 500Hz. Everything went well.
pinTable01 =
pinNum = 4,
highTime = 1,
lowTime = 1,
toggleCount = 1,
toggleDelayTime = 1,
taskCount = 1000000
Then I set highTime lowTime = 0.1ms, and 0.01mS etc, to get higher frequencies. However I already got the following error message at 0.1mS:
stdin:46: bad argument #1 to 'register' (Range: 1-6870947)
Now I know the smallest time for NodeMCU tmr is 1mS, or the highest frequency is 500Hz!
HX711's max high time is 50uS, or 1/50uS = 1000k/50 = 20 kHz!
So I am going back to the drawing board!
Posted: Tue Nov 27, 2018 4:33 am
by tlfong01
The good thing of this work around is that you can data and print anything you like, or add ESP8266 to wifi you reading, ...
Digital Weight Scale Hacking Notes
So this morning I started messing around with my toy. I found it very hacker friendly. Just loosen two screws inside the battery apartment, the weight tray with the load cell can easily be removed.
It took me only 30 seconds. I think the designer is himself a hacker, therefore has made the toy so hacker friendly, ... :lol:
Posted: Tue Nov 27, 2018 4:40 am
by tlfong01
Digital Weight Scale Hacking Notes 1, 2
Digital Weight Scale Hacking Notes 3, 4
It took me another 30 seconds to loosen two little screws at the top of the case inside, and removed the PCB and LCD. Then I cut the load cell's red, black, green, and white connecting wires and separated the load cell with tray from the PCB.
Posted: Tue Nov 27, 2018 5:27 am
by tlfong01
Digital Weight Scale Hacking Notes 5, 6
Now that the load cell is detached from the digital scale, HX711 (I guess what the black blob is) now has no input, and can report nothing but zero. I think I can any time attach a load cell of any weight, say 500g to 20kg to it, as long as the power supply is 3V to 5V (just guessing), and output voltage (to find out later) is the same as the original 500g load cell.
The detached load cell has a red blk resistance of 660R. The two M3 screws is 10mm centre to centre.
Everything looks OK. Next step is to secure the load cell with plate to somewhere.
Posted: Tue Nov 27, 2018 7:46 am
by tlfong01
Digital Weight Scale Hacking Notes 7, 8
Now that the load cell with tray is sitting tight, next step is to add a high class I2C LCD to the whole assembly.
Posted: Tue Nov 27, 2018 8:03 am
by tlfong01
Digital Weight Scale Hacking Notes 9
And I have added a 20 char x 4 lines LCD.
AliExpress LCD2004 + I2C HD44780 I2C Module US$4.20
https://www.aliexpress.com/item/TZT-1PC ... c46475c7b8
Posted: Tue Nov 27, 2018 9:15 am
by tlfong01
Digital Weight Scale Hacking Notes 9[/b]
NodeMCU Lua HX711 Module
I spent 2 hobbyist months to learn the difficult, internet driven, NodeMCU Lua, just hoping to write a blink program to blink the built in LED connection to D4 pin.
I did finally complete an almost bug free program. And now I hope to modify the blink program to blink 26 times at 20kHz, as input signal to KX711, to request for reading the weight.
Disappointedly, I found my blink program can only blink slowly, not faster than 1 kHz. In others words, my time has wasted.
So I gave up and hope to use the NodeMCU module, if any. I found one, but it only uses Channel A, not B. In other words, I cannot use Channel B for calibration and testing.
Anyway, I might just see if I can do more later. For now I will just use the NodeMCU one.
NodeMCU HX711 Module 2015-10-09 Chris Takahashi
https://nodemcu.readthedocs.io/en/maste ... les/hx711/
This module provides access to an HX711 load cell amplifier/ADC. The HX711 is an inexpensive 24bit ADC with programmable 128x, 64x, and 32x gain. Currently only channel A at 128x gain is supported.
hx711.init() Initialize io pins for hx711 clock and data.
hx711.read() Read digital loadcell ADC value.
hx711.init()
Syntax
hx711.init(clk, data)
Parameters
clk pin the hx711 clock signal is connected to
data pin the hx711 data signal is connected to
Returns
nil
Example
-- Initialize the hx711 with clk on pin 5 and data on pin 6
hx711.init(5,6)
hx711.read()
Syntax
hx711.read(mode)
Parameters
mode ADC mode. This parameter is currently ignored and reserved to ensure backward compatability if support for additional modes is added. Currently only channel A @ 128 gain is supported.
mode channel gain
0 A 128
Returns
a number (24 bit signed ADC value extended to the machine int size)
Example
-- Read ch A with 128 gain.
raw_data = hx711.read(0)
Posted: Wed Nov 28, 2018 5:20 am
by tlfong01
500g Load Cell Calibration Data
Bridge input = 3.27V
Full load 500g output = 4.2mV
Sensitivity = 4.2mV / 3.27V = 1.28mV/V
Posted: Wed Nov 28, 2018 6:25 am
by tlfong01
Calibration Weights
So I have bought some TaoBao calibration weights for my HX711 projects.
AliExpress Calibration Weight 500g 7PCS/Set 200g 100g 50g 20g 10g 5g - US$15
https://www.aliexpress.com/item/New-Arr ... 69101.html
AliExpress 500g/100g/50g/20g/10g/5g/1g Precision Chrome Calibration Scale Weight Set US$0.6 - 11
https://www.aliexpress.com/item/High-Qu ... 49748.html
TaoBao Calibration Weight Single M1, Set M2 ¥3 -19
https://detail.tmall.com/item.htm?_u=s3 ... 0932784707
Posted: Wed Nov 28, 2018 7:57 am
by tlfong01
Load Cell 500g Calibration Record
I have used the 7 in 1 500g calibration weight set to calibrate the load cell. My cheap multimeter is only accurate to 0.1mV. So the output mV readings, especially at the low end, are not that reliable.
Average Sensitivity = 1.26mV/V
Posted: Wed Nov 28, 2018 8:20 am
by tlfong01
So I gave up and hope to use the NodeMCU HX711 module, if any. I found one, but disappointedly it only uses Channel A, not B. In other words, I cannot use Channel B for calibration and testing.
Giving up ESP8266-12 NodeMCU Lua programming for HX711, will use Rpi3B+ MCP23017 Python instead
So I will suspend ESP8266-12 for now, and wait for ESP8266-32 to resume my project.
In the mean time, I will fall back on Rpi3B+ MCP2307 Python. Some 3 months ago, I wrote a python program to read DHT22, but found Rpi3B+ I2C (100kHz) too slow for DHT22 and I gave up. Now I am checking out if I2c 100kHz is good enough for HX711.
(Rpi3B+ MCP23017 DHT22 Tests) RE: RELAY MODULE KY-019 5V - tlfong01 2018-Aug-21
viewtopic.php?f=37&t=77158&start=350#p1355771
