balanga
spi.py
Fri Nov 02, 2018 2:17 pm
I have two files called spi.py:-
/usr/local/lib/python3.5/dist-packages/pifacecommon/spi.py
/usr/lib/python3/dist-packages/pifacecommon/spi.py
How do I tell which is being used when I enable the SPI kernel module using raspi-config? and how would I go about enabling the other one?
Re: spi.py
Fri Nov 02, 2018 5:05 pm
In all sane cases you'll find that /usr/local/... trumps /usr/...
There is an assumption that python2 & python3 are sane (we know that to be false because of the V2 versus V3 pain).
Note: Having anything remotely humorous in your signature is completely banned on this forum. Wear a tinfoil hat and you'll get a ban.
This is a doctor free zone.
balanga
Re: spi.py
Tue Nov 06, 2018 1:27 pm
To enable SPI I have to run raspi-config then select 5 - Interface Options -> P4 SPI.
What does this actually do? ie which files are actually affected?
balanga
Re: spi.py
Tue Nov 06, 2018 9:27 pm
After some rummaging around it appears that setting SPI on consists of uncommenting
#dtparam=spi=on
in
/boot/config.txt
Can anyone confirm?
Presumably a reboot is required to make it effective...
DirkS
Re: spi.py
Wed Nov 07, 2018 9:39 am
#dtparam=spi=on
in
/boot/config.txt
Can anyone confirm?
Correct
