atux_null
MQTT send alert
Wed Oct 31, 2018 8:12 am
Hi. i running my custom made home alarma by making use MQTT broker in a RPI zero W and ESP8266 with different modules.
Each module publishes to a particular topic in MQTT broker and from an android app like mqtt dash i can see the status.
i would like to take it a step further and make the system to be able to send alerts, such as emails or even create a preformated text and post it in another server in my LAN.
Has anyone any ideas on how to do stuff like that and give some guidance please?
DirkS
Re: MQTT send alert
Wed Oct 31, 2018 9:16 am
Many ways to do that...
If you want a flexible solution you could use e.g. https://github.com/jpmens/mqttwarn
atux_null
Re: MQTT send alert
Mon Dec 31, 2018 12:21 pm
hi. i am coming back since i have given a try and i cannot make it work. Up to know i have a RPI that acts as broker. all i did is
apt-get install mosquitto mosquitto-clients -y
pip install paho-mqtt
then i edited the /etc/mosquitto/mosquitto.conf and it has
pid_file /var/run/mosquitto.pid
persistence true
persistence_location /var/lib/mosquitto/
log_dest file /var/log/mosquitto/mosquitto.log
listener 1883
i have a number of ESP8266 with sensors that publish to the
/device/alarm/sensor/
, one as
hallway
, the other as
master_bedroom
, next is
bathroom
and the list continues.
it works fine for some time now and i see their status in an android application MQTT dashboard.
in the MQTT i see a 0 when door/window closes and 1 when it opens. i would like to execute a particular bash script when 0 and a different bash script when 1.
i am trying to play with https://github.com/jpmens/mqtt-launcher/issues/13 but it fails to work and i am stuck. here is the config of the launcher.conf
pi@rpiB:~/mqtt-launcher $ more launcher.conf
logfile         = 'logfile'
mqtt_broker     = 'localhost'       # default: 'localhost'. If using TLS, this must be set to the domain name signed by yo
ur TLS certificate.
mqtt_port       = 1883              # default: 1883
mqtt_clientid   = 'mqtt-launcher-1'
mqtt_username   = None
mqtt_password   = None
mqtt_tls        = None              # default: No TLS
# mqtt_username = 'jane'
# mqtt_password = 'secret'
topiclist = {
    # topic                         payload value       program & arguments
"/device/alarm/sensor/livingroom"          :   {
                                               '0' :   [ 'close', '/home/pi/scrpts/scriptlivingroom_0.sh' ],
                                               '1' :   [ 'open',  '/home/pi/scrpts/scriptlivingroom_1.sh'],
"/device/alarm/sensor/hallway"          :   {
                                               '0' :   [ 'close', '/home/pi/scrpts/scripthallway_0.sh' ],
                                               '1' :   [ 'open',  '/home/pi/scrpts/scripthallway_1.sh']
and here is the error when i execute it
pi@rpiB:~/mqtt-launcher $ python mqtt-launcher.py
  File "mqtt-launcher.py", line 152, in <module>
    mqttc.connect(cf.get('mqtt_broker', 'localhost'), int(cf.get('mqtt_port', '1883')), 60)
  File "/home/pi/.local/lib/python2.7/site-packages/paho/mqtt/client.py", line 839, in connect
    return self.reconnect()
  File "/home/pi/.local/lib/python2.7/site-packages/paho/mqtt/client.py", line 962, in reconnect
    sock = socket.create_connection((self._host, self._port), source_address=(self._bind_address, 0))
  File "/usr/lib/python2.7/socket.py", line 575, in create_connection
    raise err
socket.error: [Errno 111] Connection refused
What am i missing? May i have some help please?
neilgl
Re: MQTT send alert
Mon Jan 07, 2019 11:28 am
As jpmens replied in his github issues page, the program cannot connect to the host/TCP port you've specified.
So logon to the pi where you are running mqtt and the python script and try this in a terminal:
mosquitto_sub -v -t '#' -h localhost
That should show all the mqtt topics that are published to the mqtt server (mqtt broker)
Re: MQTT send alert
Mon Jan 07, 2019 1:32 pm
It's also a good idea to check whether mosquitto is listening with sudo netstat -tlnp | grep 1883;. There was a bug a while ago where it wouldn't listen on port 1883 without a
listener 1883
protocol mqtt
in your config file.
Note: Having anything remotely humorous in your signature is completely banned on this forum. Wear a tinfoil hat and you'll get a ban.
This is a doctor free zone.
mattmiller
Re: MQTT send alert
Mon Jan 07, 2019 3:56 pm
From what you previosuly posted, your broker is working fine on your Pi so lets try it out step by step and be explicit
e.g use the example launcher.conf first and see if you get any errors with that
So copy mqtt-launcher.py to /home/pi/mqtt-launcher.py
copy launcher.conf.example to /home/pi/launcher.conf
make sure you are in /home/pi
then run
On my system - it just sits there without errors (which I take to mean its working) - I use ctrl-c to exit
What happens on your system?
atux_null
Re: MQTT send alert
Mon Jan 07, 2019 9:08 pm
hi. if i execute the command to manually run mosquitto to listen to all topics
root@Rpi2: ~ $ mosquitto_sub -v -t '#' -h localhost
^C
root@Rpi2: ~ $
it works.
also
root@Rpi2: ~ $ netstat -tlnp | grep 1883
tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      310/mosquitto
tcp6       0      0 :::1883                 :::*                    LISTEN      310/mosquitto
root@Rpi2: ~ $
so what it wrong?
Re: MQTT send alert
Mon Jan 07, 2019 9:13 pm
Leave mosquitto_sub running, then run mosquitto_pub -t 'test/topic' -h localhost -m "test message"
If that works try your publisher program again. If it doesn't work, we need to see the whole program not just snippets and not just examples of how it fails.
atux_null
Re: MQTT send alert
Mon Jan 07, 2019 9:24 pm
it seems to work
test/topic test message
so why the mqtt-launcher is not working?
Re: MQTT send alert
Mon Jan 07, 2019 9:50 pm
I've just downloaded it with cd /tmp; wget https://github.com/jpmens/mqtt-launcher/archive/master.zip, unzipped it, edited the sample config (to add my broker's ip address) and renamed it as /tmp/mqtt-launcher-master/launcher.conf. Ran the launcher with ./mqtt_launcher.py
dougie@apollo:~$ mosquitto_pub -t 'test/topic' -m "test" -h 192.168.3.14
dougie@apollo:~$ mosquitto_pub -t 'sys/file' -m "info"
dougie@apollo:~$ mosquitto_pub -t 'sys/file' -m "create"
dougie@apollo:~$ mosquitto_pub -t 'sys/file' -m "false"
dougie@apollo:~$
dougie@apollo:~$ mosquitto_sub -t '#' -v -h 192.168.3.14
sys/file info
sys/file/report *****> Command '['/bin/ls', '-l', '/tmp/file.one']' returned non-zero exit status 2
sys/file create
sys/file/report (null)
sys/file info
sys/file/report -rw-r--r-- 1 pi pi 0 Jan  7 21:44 /tmp/file.one
sys/file false
sys/file false
sys/file info
atux_null
Re: MQTT send alert
Tue Jan 08, 2019 6:43 am
i will try to reinstall the image and build it from scratch. I've tried everything, but still it resists to work. I imagine that something broke in my system. A fresh install will reveal if it's the case.
PhatFil
Re: MQTT send alert
Tue Jan 08, 2019 7:43 am
Node Red may be worth looking at it has nodes to both publish and subscribe to mqtt host/topics as well as nodes devoted to socail media twitter and email etc for external coms/alerts, I host node red alongside my mqtt broker on a pi-0-w as it also provides a gui dahboard interface too.
