atulkatti
ADXL345 Accelerometer output
Fri Oct 26, 2018 5:57 am
HI Gurus
I have recently built a basic system by connecting ADXL345 to Pi and Im seeing output like X=-229, Y=-188
,Z=409. Understand that these represent acceleration along 3 axis. Want to understand what the units these values represent. Is it m/s^2 ? How can i convert these to physical units ?
scotty101
Re: ADXL345 Accelerometer output
Fri Oct 26, 2018 8:53 am
You need to have a look at the datasheet for the device
https://www.analog.com/media/en/technic ... DXL345.pdf
The title on page one says
3-Axis, ±2 g/±4 g/±8 g/±16 g
which lets me know that there are 4 modes of measurement for this device. When you initialise the device, you need to set it's sensitivity to one of the modes and use that value to figure out what the data from the device means.
It also says
The ADXL345 is a small, thin, ultralow power, 3-axis accelerometer
with high resolution (13-bit) measurement at up to ±16 g. Digital
output data is formatted as 16-bit twos complement and is accessible
through either a SPI (3- or 4-wire) or I2C digital interface.
Now I know I'm dealing with a 13 bit value stored inside a 16bit twos compliment word. So I need to be cautious and take in to account whether the Most Significant Bit is set to tell whether the measurement is positive or negative.
Next table 1 (page 4) has rows showing "Scale Factor at XOUT, YOUT, ZOUT", extract below
Range                         Typical
±2 g, 10-bit resolution       3.9mg/LSB
When the device is in the 2g sensitivity mode, each LSB is approximately 3.9 milli g (a g being 9.8m/s^2)
So if the device outputs a value such as
0x0002 this means that the output is two and is equivalent to 3.9 x 2 micro g = 7.8mg
7.8mg is roughly 0.07644 m/s^2. (7.8e-3 x 9.8)
Does that give you enough info to get started with?
FYI, there are probably libraries that do this conversion for you.
Idahowalker
Fri Oct 26, 2018 11:42 am
After reading the high bits and the low bits from the unit, the bits will need to be combined, in the same step I twos compliment the data before applying the scale factor. For accelerometers, it is, when applying the scale factor the time to apply any offsets and drift rates that were obtained during calibration
        Read Gyro and Accelerometer by Interfacing Raspberry Pi with MPU6050 using Python
	http://www.electronicwings.com
mpu6050  rpi3
scl to RPiJ8-5
sda to RPiI8-3
GND to GND
VCC to 3.3 volts
check if I2C user port enabled
enter ls /dev/*i2c* in terminal desktop
response should be /dev/i2c-1
is not run raspi configuration
sudo raspi-config in a terminal window
select interfacing options I2C <yes> <ok>
might need reboot
try sudo i2cdetect -y 1
(might need to get i2c tools.
sudo apt-get install -y i2c-tools)
mpu6050 should show up as being device 68
wait at least 30ms, after waking unit, to acquire gyro info
calibrate mpu6050
firmly physically hold mpu6050 from moving
I put mpu6050 on breadboard, I place weights on each side of breadboard. I have breadboard on soild surface
Iike to play music with a heavy beat. during calibration turn music off. sit quietly, avoid low frequency sounds and movements.
run MPU_Cali()
results will print out. enter offset results for each offset.
I found calibration measurement of less than 51 measurements to be innaccurate offsets and
measurements above 300 data points of little gain in accuracy.
idahowalker 16-Apr-2018
import smbus			#import SMBus module of I2C
import time
import math
import datetime
#some MPU6050 Registers and their Address
PWR_MGMT_1 address Hex=0x6Bb, Decimal=107
bit7         bit6   bit5  bit4 bit3     bit2,1,0
DEVICE_RESET SLEEP  CYCLE   x  TEMP_DIS CLKSEL (2-0)
bit6 to 1 = low power sleep mode
bit5 = 1 with SLEEP 0 unit cycles sleep n wake to take single sample readings
       at a rate determined by register 108
bit3 = 1 to disable temperature sensor
bit2,1,0 sets clock source default 0 = 8Mhz
PWR_MGMT_1   = 0x6B
bit7, bit6        bit5    bit4    bit3    bit2    bit1    bit0
LP_WAKE_CTRL(1:0) STBY_XA STBY_YA STBY_ZA STBY_XG STBY_YG STBY_ZG
LP WAKE UP
0 1.25HZ
1 5HZ
2 20HZ
4 40HZ
SET OTHER BITS TO PUT PARTS OF UNIT INTO STSNDBY MODE
##PWR_MGMT_2   = 0x6C
SMPLRT_DIV
Sample Rate Divider
8 bit value determined by
SampleRate=Gryoscope Output Rate/(1+SMPLRT_DIV)
Gyroscope Output Rate=8Khz default
see DLPF_CFG register (26) to change)
SMPLRT_DIV = 8 bit value
SMPLRT_DIV   = 0x19
CONFIG (26)
Configures Frame Synchronization (FSYNC) pin and
Digital Low Pass Filter (DLPF) for gyros and accelerometers
bit2,1,0 DLPF_CONFIG
         Accel         Gyro
DLPF_CFG Hz  Delay(ms) Hz   Delay(ms)   Fs(kHz)
0        260 0         256  0.98        8
1        184 2.0       188  1.9         1
2        94  3.0       98   2.8         1
3        44  4.9       42   4.8         1
4        21  8.5       20   8.3         1
5        10  13.8      10   13.4        1
6        5   19.0      5    18.6        1
7 RESERVED
CONFIG       = 0x1A
GYRO_CONFIG
Used to trigger gyro self test and full scale range
FS_SEL bits4,3
FS_SEL  Full Scale Range
0       +/- 250 deg/sec
1       +/- 500 deg/sec
2       +/- 1000 deg/sec
3       +/- 2000 deg/sec
decimal 24=+/- 2000 deg/sec
GYRO_CONFIG  = 0x1B
Configure Interrupt (int)
11011100
b7 to b0
b7 = 1, int active low
b6 = 1, open drain set Pi to pull up
b5 = 0, mpu int out 50us pulse
b4 = 1, int status cleared on data read
b3 = 1, FSYNC pin active low
b2 = 1, enable int
b1 = 0, bypass i2c bus
b0 = 0, n/a
CONFIG_INT = 0X37
INT_ENABLE
enables interrupt generation by interrupt sources
bit4 FIFO_OFLOW_EN when 1 enables FIFO buffer to generate interrupy
bit3 I2C_MST_INT_EN when 1 enables I2C Master interrupt sources to generate interrupt
bit0 DATA_RDY_EN when 1 this enables a Data Ready Interrupt, which occurs each time
a write operation to all the sensor registets has been completed
INT_ENABLE   = 0x38
SIGNAL_PATH_RESET = 0x68
ACCEL_XOUT_H = 0x3B
ACCEL_YOUT_H = 0x3D
ACCEL_ZOUT_H = 0x3F
GYRO_XOUT_H  = 0x43
GYRO_YOUT_H  = 0x45
GYRO_ZOUT_H  = 0x47
Ax = 0.0
Ay = 0.0
Az = 0.0
Gx = 0.0
Gy = 0.0
Gz = 0.0
AxRaw = 0.0
AyRaw = 0.0
AzRaw = 0.0
GxRaw = 0.0
GyRaw = 0.0
GzRaw = 0.0
bus = smbus.SMBus(1) 	# or bus = smbus.SMBus(0) for older version boards
Device_Address = 0x69   # MPU6050 device address
GX_OFFSET = 0.9448346055979611
GY_OFFSET = 0.42473282442748
GZ_OFFSET = -0.007175572519084001
AZ_OFFSET = -0.20509161536206405
AY_OFFSET = -0.0027156625622984485
AX_OFFSET = -0.00187335092348285
X_Rotation_Offset = 0.5184471935554903
Y_Rotation_Offset = -0.7581521549108168
GX_Drift = 0.0
GY_Drift = 0.0
GZ_Drift = 0.000103
ACCEL_SCALE = 18192.0
GYRO_SCALE = 65.5
iRound = 8
iCaliPoints = 300 #do at least 100 calibration measurements
iCaliSleepTime = 1
K = 0.98
K1 = 1 - K
lastX = 0.0
lastY = 0.0
tDiff = 1.0/400.0
def MPU_Init():
        #Write to power management register
	bus.write_byte_data(Device_Address, PWR_MGMT_1, 1) ## x gyro as clock source
	## time.sleep( .1 ) ## wait
	## bus.write_byte_data(Device_Address, SIGNAL_PATH_RESET, 7) #reset device signal paths
	## time.sleep( .1 )
        #write to sample rate register
	bus.write_byte_data(Device_Address, SMPLRT_DIV, 7)
	#Write to Configuration register
	bus.write_byte_data(Device_Address, CONFIG, 0)
	#Write to Gyro configuration register
	bus.write_byte_data(Device_Address, GYRO_CONFIG, 24)
	#Write to interrupt comfigure & enable register
	## bus.write_byte_data(Device_Address, CONFIG_INT , 220)
	## bus.write_byte_data(Device_Address, INT_ENABLE, 1)
	return;
def read_raw_data(addr):
	#Accelero and Gyro value are 16-bit
        high = bus.read_byte_data(Device_Address, addr)
        low = bus.read_byte_data(Device_Address, addr+1)
        value = 0
        value = twos_complement( ((high << 8) | low) )
        return value;
def MPU_Cali():
    global GX_OFFSET
    global GY_OFFSET
    global GZ_OFFSET
    global AZ_OFFSET
    global AY_OFFSET
    global AX_OFFSET
    global X_Rotation_Offset
    global Y_Rotation_Offset
    X_Rotation_Offset = 0.0
    Y_Rotation_Offset = 0.0
    GX_OFFSET = 0.0
    GY_OFFSET = 0.0
    GZ_OFFSET = 0.0
    AZ_OFFSET = 0.0
    AY_OFFSET = 0.0
    AX_OFFSET = 0.0
    iCalibrateCount = 0
    MPU_Init()
    while (iCalibrateCount != iCaliPoints) :
        MPU_ReadRawData()
        iCalibrateCount = iCalibrateCount + 1
        ##gather info to be averaged
        GX_OFFSET += GxRaw
        GY_OFFSET += GyRaw
        GZ_OFFSET += GzRaw
        AZ_OFFSET += AzRaw
        AY_OFFSET += AyRaw
        AX_OFFSET += AxRaw
        X_Rotation_Offset += fGet_x_rotation(AxRaw, AyRaw, AzRaw)
        Y_Rotation_Offset += fGet_y_rotation(AxRaw, AyRaw, AzRaw)
        print ("Pass number: " + str(iCalibrateCount))
        time.sleep(iCaliSleepTime)
    #calculate averages n change sign
    GX_OFFSET = -(GX_OFFSET/iCaliPoints)
    GY_OFFSET = -(GY_OFFSET/iCaliPoints)
    GZ_OFFSET = -(GZ_OFFSET/iCaliPoints)
    AZ_OFFSET = -(AZ_OFFSET/iCaliPoints)
    AY_OFFSET = -(AY_OFFSET/iCaliPoints)
    AX_OFFSET = -(AX_OFFSET/iCaliPoints)
    X_Rotation_Offset = -(X_Rotation_Offset/iCaliPoints)
    Y_Rotation_Offset = -(Y_Rotation_Offset/iCaliPoints)
    print(str(GX_OFFSET) + " GX OFFSET")
    print(str(GY_OFFSET) + " GY OFFSET")
    print(str(GZ_OFFSET) + " GZ OFFSET")
    print(str(AZ_OFFSET) + " AZ OFFSET")
    print(str(AY_OFFSET) + " AY OFFSET")
    print(str(AX_OFFSET) + " Ax OFFSET")
    print(str(X_Rotation_Offset) + " X_Rotation_Offset")
    print(str(Y_Rotation_Offset) + " Y_Rotation_Offset")
    return;
def twos_complement( val ):
    if ( val >= 0x8000 ):
        val = -( ( 65535 - val ) +1 )
    return val;
def millisTime():
      dateDateTimeNow = datetime.datetime.now()
      return ((dateDateTimeNow.microsecond/1000) + (dateDateTimeNow.second*1000));
Inspiration for the gyro drift rate code
from M.Hefny, mohammad.hefny@gmail.com, Date: 13 June 2015
#Uses calibrate averages, and try to detect drift
def fCal_Gyro_Drift():
    iCount = 0
    timeOld = 0.0
    timeNew  = 0.0
    timeDiff = 0.0
    fltGyro_x_int = 0.0
    fltGyro_y_int = 0.0
    fltGyro_z_int = 0.0
    fltGyro_x = 0.0
    fltGyro_y = 0.0
    fltGyro_z = 0.0
    fltGyro_AvgDriftRate_X = 0.0
    fltGyro_AvgDriftRate_Y = 0.0
    fltGyro_AvgDriftRate_Z = 0.0
    print ("calibrating gyro (min average error selection) - getting drift")
    print ("Start time " + str(datetime.datetime.now()))
    MPU_Init()
    while iCount < iCaliPoints:
        iCount = iCount + 1
        timeNew = millisTime()
        timeDiff = timeNew - timeOld
        MPU_ReadRawData()
        timeOld = timeNew
        #apply offset
        fltGyro_x = GxRaw + GX_OFFSET
        fltGyro_y = GyRaw + GY_OFFSET
        fltGyro_z = GzRaw + GZ_OFFSET
        fltGyro_x_int += (fltGyro_x / timeDiff)
        fltGyro_y_int += (fltGyro_y / timeDiff)
        fltGyro_z_int += (fltGyro_z / timeDiff)
        print ("Pass number: " + str(iCount))
    fltGyro_AvgDriftRate_X = -(fltGyro_x_int / iCount)
    fltGyro_AvgDriftRate_Y = -(fltGyro_y_int / iCount)
    fltGyro_AvgDriftRate_Z = -(fltGyro_z_int / iCount)
    print ("Calibrating loops (rad/sec) %d  x:%f y:%f z:%f"
        %(iCount, fltGyro_AvgDriftRate_X, fltGyro_AvgDriftRate_Y, fltGyro_AvgDriftRate_Z))
    print ("End time " + str(datetime.datetime.now()))
    return;
def MPU_ReadRawData():
    global Ax
    global Ay
    global Az
    global Gx
    global Gy
    global Gz
    global AxRaw
    global AyRaw
    global AzRaw
    global GxRaw
    global GyRaw
    global GzRaw
    AxRaw = 0.0
    AxRaw = read_raw_data(ACCEL_XOUT_H)
    AyRaw = 0.0
    AyRaw = read_raw_data(ACCEL_YOUT_H)
    AzRaw = 0.0
    AzRaw = read_raw_data(ACCEL_ZOUT_H)
    GxRaw = 0.0
    GxRaw = read_raw_data(GYRO_XOUT_H)
    GyRaw = 0.0
    GyRaw = read_raw_data(GYRO_YOUT_H)
    GzRaw = 0.0
    GzRaw = read_raw_data(GYRO_ZOUT_H)
#### adjust with scale factors
#### acclerometer offset adjustments made here
    preScaled = AxRaw
    AxRaw = AxRaw / ACCEL_SCALE
    Ax = ( preScaled + AX_OFFSET ) / ACCEL_SCALE
    preScaled = AyRaw
    AyRaw = AyRaw / ACCEL_SCALE
    Ay = ( preScaled + AY_OFFSET ) / ACCEL_SCALE
    preScaled = AzRaw
    AzRaw = AzRaw / ACCEL_SCALE
    Az = ( preScaled + AZ_OFFSET ) / ACCEL_SCALE
#### do not adjist gyro offsets here
    GxRaw = GxRaw / GYRO_SCALE
    Gx = GxRaw
    GyRaw = GyRaw / GYRO_SCALE
    Gy = GyRaw
    GzRaw = GzRaw / GYRO_SCALE
    Gz = GzRaw
    return;
# used for obtaining tilt angles from accelerometrs
def fDist(a,b):
    return math.sqrt((a*a)+(b*b));
def fGet_y_rotation(x,y,z):
    radians = math.atan2(y, fDist(x,z))
    return math.degrees(radians);
def fGet_x_rotation(x,y,z):
    radians = math.atan2(x, fDist(y,z))
    return -math.degrees(radians);
def fRunLoop():
    global Ax
    global Ay
    global Az
    global Gx
    global Gy
    global Gz
    global lastX
    global lastY
    gyroTotalX = 0.0
    gyroTotalY = 0.0
    now = time.time()
    time_diff = 0.01
    ## K = 0.98
    ## K1 = 1 - K
    print (" Reading Data of Gyroscope and Accelerometer")
    MPU_Init()
    MPU_ReadRawData()
    while True:
        MPU_ReadRawData()
        AxRotRaw = fGet_x_rotation( AxRaw, AyRaw, AzRaw )
        AyRotRaw = fGet_y_rotation( AxRaw,  AyRaw,  AzRaw )
        AxRot =  fGet_x_rotation(  Ax,  Ay,  Az )
        AyRot =  fGet_y_rotation(  Ax,  Ay,  Az )
#### if no last rotation / time past get one.
        if (  lastX == 0.0 ):
            lastX = AxRot
            lastY = AyRot
## apply gyro offsets here
        Gx += ( GX_OFFSET - X_Rotation_Offset )
        Gy += ( GY_OFFSET - Y_Rotation_Offset )
## obtain gyro rotation since last reading Gx * tDiff
## get rotation accelerometer use scaled and adjusted accelerometer data fGet_x_rotation
##  complementary filtet to combine data
        lastX = K * ( lastX + ( Gx * tDiff ) ) + ( K1 * AxRot )
        lastY = K * ( lastY + ( Gy * tDiff ) ) + ( K1 * AyRot )
        print( "Time:%.4f ArotX %.2f gX %.2f lastX %.2f ArotY %.2f gY %.2f lastY %.2f" %( time.time(), AxRot, Gx, lastX, AyRot, Gy, lastY ) )
        time.sleep( .5 )
    return;
must be mannualy entered into
##GX_OFFSET = 0.0
##GY_OFFSET = 0.0
##GZ_OFFSET = 0.0
##AZ_OFFSET = 0.0
##AY_OFFSET = 0.0
##AX_OFFSET = 0.0
overwrite existing values with calibration values
run MPU_Cali() first to get averages
## MPU_Cali()
calibrate gyro drft uses average drift rate
to calculate gryo drift over time
in rad/s^2
mamually enter results into the variables
GX_Drift = 0.0
GY_Drift = 0.0
GZ_Drift = 0.0
run after MPU_Cali() to get drift rates
## fCal_Gyro_Drift()
uncomment fRunLoop() to see mpu6050 data
compare before and after calibration.
remember the loop displays mpu data +/- .0000
tiny numbers
## fRunLoop()
Here is some code that heals with Gyros and Accelerometers, you can ignore the code for Gyros. The above includes code to calibrate offsets, calibrating drift rates, angle drift rates, obtaining tilt angles from accelerometers, applying scale factors, two compliment, a complementary filter to integrate gyro / accelerometer output data, and more.
The output of this code does not contain info on how to convert the values to servo uSec counter torque values to keep a X/Y platform level, which can be done with just accelerometers. The issue with just using accelerometers to keep a platform level is that accelerometers tend to be noisy and reactive. Thus, the use of a complementary filter.
Without knowing why you are deleting my postings, I will not know how...
bensimmo
Fri Oct 26, 2018 2:23 pm
It probably tell you in the code
What's the code/what are you using to read it.
henmina53
Wed Oct 31, 2018 8:13 am
Hey, these are the decimal values which will be divided by the "g" resolution unit multiplied by the m/s conversion
for code mentioned in this link - https://github.com/ControlEverythingCom ... ADXL345.py
xAccl = ((data1 & 0x03) * 256) + data0 // generating the hexa decimal value by shifting MSB to left side and adding the LSB on right side
 // for making signed or unsigned bit, suppose we are taking 16g then the decimal value readings will appear like 0 to 65535 (which shows the unsigned bit) means 2^0 to 2^15
 // Mentioned below is  for checking the signed value decimal readings will appear like -512 to 512 means   - (2^8) to + (2^8)
if xAccl > 511 :
	xAccl -= 1024 // now I ll be using xAcc value to convert in m/s or km/h
// for checking the value in m/s or in km/h I am going to use mentioned below formulae
// [xAcc/(G resolution)]*1.6 = X_accelration
hope this will help you out
