atulkatti
Connecting spread out sensors wirelessly
Sat Oct 20, 2018 4:09 am
Hi all
I am planning a couple of projects in agriculture and shop floor where the sensors (Accelerometer, humidity , temperature) are spread out over a distance. I have one rasperry pi. How can i connect the sensors to Rpi wirelessly. I am thinking of Zigbee and Bluetooth. Can someone provide detailed info on this. Using wires to connect may be a messier approach.
OutoftheBOTS
Re: Connecting spread out sensors wirelessly
Sat Oct 20, 2018 9:29 pm
Most people use ESP8266 as nodes on each sensor then send the data back to the RPi via MQTT as a client and run a MQTT broker on the RPi
Here's a bit of a tutorial from Adafruit https://learn.adafruit.com/diy-esp8266- ... spberry-pi
baetis
Sat Oct 20, 2018 9:50 pm
I agree - the modules can be bought on ebay for $3-5, use very little power (9v battery could last months) and are small pretty easily hooked up to i2c, spi, rs232.....
I'ld rather weather proof an esp8266 compared to a RPi.
PhatFil
Sat Oct 20, 2018 9:55 pm
for esp825/6 and esp32 devices both off the shelf and diy check out tasmota firmware https://github.com/arendst/Sonoff-Tasmota/wiki
you should be able to source bluetooth ble sensors that broadcast/advertise information your pi can 'crack'
https://zsiti.eu/xiaomi-mijia-hygrother ... pberry-pi/
https://github.com/ThomDietrich/miflora-mqtt-daemon
for example..
atulkatti
Sun Oct 21, 2018 6:35 am
Thank You experts...Im assuming we dont need wifi to transmit data from ESP8266 to Rpi. Getting a wifi in the field will be a problem.
B.Goode
Sun Oct 21, 2018 6:44 am
I thought the main point of an esp8266 was that it enabled WiFi communication. If you don't want to use that facility maybe an esp8266 is not an optimum choice? What alternative form of communication do you plan to use?
If you have an RPi (either with built--in WiFi, or an external dongle) then you can have WiFi access 'in the field.' https://www.raspberrypi.org/documentati ... s-point.md
atulkatti
Sun Oct 21, 2018 6:52 am
I have Rpi 3B+ which is wifi enabled like the ESP....But finding a WLAN network in the field could be difficult. If there is bluetooth module per sensor i can stream this data to Rpi and then get the data out via a long Network cable to the modem located several meters away
Sun Oct 21, 2018 10:28 am
Make your RPi run as the access point. Your ESP8266 (aka Wemos) based sensors can then connect to it wirelessly.
This is a doctor free zone.
atulkatti
Sun Oct 21, 2018 2:30 pm
