RPi + Roostick to control Roomba?
Posted: Fri Nov 09, 2012 2:24 am
by mkopack
Hey gang...
After seeing the recent story on the front page about the RPi controlled Roomba, I decided to dust off my old 500 Discovery series, and my old USB Roostick+cable.
I installed PySerial
Then I hooked up the Pi, plugged the roostick+cable into the Roomba and into the Pi's USB Hub.
lsusb shows:
the Hub
3 "Standard Microsystems Corp" entries
The mouse
The Keyboard
and finally: "Cygnal Integrated Products, Inc. CP210x UART Bridge / myAVR mySmartUSB light"
Unplugging the roostick and running lsusb again shows that it's that last item in the list that is the roostick.
I threw together a little python test program, basically exactly what's in the Roomba SCI interface document:
import serial
ser = serial.Serial(0, baudrate=19200,
timeout=0.1)
ser.open()
# wake up robot
ser.setRTS (0)
time.sleep (0.1)
ser.setRTS (1)
time.sleep (2)
# pulse device-detect three times
for i in range (3):
       ser.setRTS (0)
       time.sleep (0.25)
       ser.setRTS (1)
       time.sleep (0.25)
Seems like no matter what I put in for the device it comes back saying it can't connect.
Looking in /dev, I see /ttyUSB0 show up when I plug the Roostick in... But trying to use /dev/ttyUSB0 as the port gives an exception "Port is already open" error.
Any ideas???
Re: RPi + Roostick to control Roomba?
Posted: Sat Nov 10, 2012 1:35 am
by mkopack
Ok, nevermind, got it working!
Here's a little test program that establishes connection, turns on a couple of the lights, and plays a tone...
(And Python is NOT my primary language, so I'm sure there's plenty to be done to make this better/easier...)
import serial
import time
# main....
ser = serial.Serial("/dev/ttyUSB0",baudrate=57600, timeout=0.1)
ser.write(serial.to_bytes("\x80"))
# everything has to be sent as hex code bytes. So using the SCI programmer's
# guide to get the decimal codes, convert to hex
# and put them in here with \x in front of each 2 digit byte to denote hex...
time.sleep(0.1)
ser.write(serial.to_bytes("\x82"))
time.sleep(0.1)
ser.write(serial.to_bytes("\x8b\x19\x00\x80"))
time.sleep(6)
# make a song with some tones
ser.write(serial.to_bytes("\x8c\x00\x06\x60\xff\x30\xff"))
#now play it.
ser.write(serial.to_bytes("\x8d\x00"))
time.sleep(20)
ser.close()
My wifi adaptor, and webcam came in. Just waiting on the powered hub (should have arrived today, so probably tomorrow or Monday) and I should be able to start putting it all together into a little roving telepresence bot :)
Posted: Wed Nov 14, 2012 6:20 pm
by doitnowlabs
Cool! I probably should have bought a RooStick too, but I'm too cheap for that. ;)
Posted: Sat Nov 17, 2012 5:16 pm
by mkopack
Well, I actually found a full library for talking to Roomba over Python.
http://bilibot-ros-pkg.googlecode.com/s ... _driver.py
Looks pretty easy to control the Roomba via that...
I'm also trying to figure out how I want to do the control/interface... Was thinking maybe some sort of Web interface. Not sure yet... Also trying to figure out how I want to stream video from the webcam.
--Mike
