Priyank_Patel
Communication with Siemens PLC
Thu Jul 26, 2018 12:32 pm
I have RPi 3B+ system. I want to send data from Siemens S7-1200 PLC to cloud server via RPi card.
I think to connect PLC & RPi by Modbus RS485 or Modbus TCP/IP.
Now, Ethernet port of RPi is in use of PC connection.
Our query is, can we use single Ethernet port of RPi card is work over a Modbus TCP/IP as well as Ethernet simultaneously?
If we want to data transfer by RS485, then what to do?
epoch1970
Re: Communication with Siemens PLC
Fri Jul 27, 2018 1:03 pm
Just in case.
The Pi's integrated ethernet works well with VLAN so you could assign the native ethernet link (eth0) to Modbus TCP/IP and a VLAN (eth0.1234) to the regular network. Assuming a switch/router that will handle VLAN.
Or add an USB ethernet adapter, so you'll get eth0 and eth1 on the Pi.
ranpitime
Sat Jul 28, 2018 5:39 pm
I would use Profinet to connect the PI to the Siemens plc - either PN Controller or PN Device on PI side...
https://faq.codesys.com/display/CDSFAQ/Raspberry+-+FAQ
BR
ranpitime
vishal3894
Wed Jan 08, 2020 11:33 am
CAN I UPLOAD DATA FROM SIEMENS S71200 PLC TO CLOUD OVER TCP?
