Digital VoltMeter for beginners
Posted: Thu Jun 14, 2018 10:21 am
by RedDragon
I am looking for experienced programmermate to construct a digital voltmeter application.
The project is based on MSP430 microcontroller with Raspberry Pi. The microcontroller function as a low frequency 16bit+sign resolution 26V maximum input VoltMeter. It has an OLED 0.91" display for standalone measurements and a radio communication to Raspberry Pi for extendending its capabilities.
The project is for beginnersas a first task to assemble a kit and download software and have a Digital VoltMeter to work.
Re: Digital VoltMeter for beginners
Posted: Thu Jun 14, 2018 10:48 am
by B.Goode
I am looking for experienced programmermate [ ... ] The project is for beginners
Can you clarify?
Do you want a beginner or experience?
Is this a kit you have purchased and need help to put together?
Or is this a product you are hoping to develop and need skilled help to bring to market?
Posted: Thu Jun 14, 2018 12:21 pm
by Idahowalker
I use an Arduino Mega with my PiB. One of the functions is that the Arduino measures voltages into the A to D converter via a voltage divider. According the the math, I should be able to measure up to 50 volts. The raw reading from the A to D converter is sent to the RPi for process and displayed on a OLED.
When I compare the measurement taken and displayed by the Arduino/RPi to my DMM, the readings are equal.
The project is quite doable.
Posted: Thu Jun 14, 2018 3:11 pm
by hippy
Using a micro or adding an ADC should allow a volt meter to be built round a Pi but I'm not so sure about achieving 16-bit plus sign resolution. Not sure that's even needed.
I would suggest that if the project is to have an OLED display it might be better to step it up from being just a volt meter to having some beginner level oscilloscope capabilities. That could make it a more appealing and useful project for beginners to undertake.
But it's not clear what "beginners" we are talking about here.
