Hello pcmanbob,
thank you very much for your fast reply. i didn't programm anything yet so far, I just wanted it to work first, hence I am using Python to controll the gpio's directly. The board is connected to the GND PIN 9; GPIO 5, 6, 13, 19, 26, 16, 20 and 21.
have you tried checking that you are actually driving the inputs high using a meter set to volts and connected between ground and each input on the chip,
then you can do the same on the outputs connecting your meter between 24V + and each output pin on the chip.
What I did is checking with the Benning Duspol expert, if everything is correctly connected, but that's not what you suggest, isn't it? So I would have to use a multimeter? Or could i use the Duspol, turn on the whole system and check, whether the flow is correct? (as you can see, I have a lot to learn)
I thought I did connect the common on the ULN2803A (-> attached picture)
Could it be that my resistor network is broken? Can it be broken?
Thank you very much in advance.
