I need to make photographs of plants outside in the garden regularly. So my raspberry pi zero will be connected to a battery.
The pi should turn on every day once or twice at the same time. When the pi boots up it takes a photo then shuts down. So the powering should run maximum 5 minutes at once. That's more than enough. It would be ideal to run this cycle for several weeks, of course it depends on the battery.
For this I would like to use some 5v time delay switch but I don't have experience in it. I've found some on aliexpress but from the funny chinese decriptions I don't get exactly wich one is good for this task. (A bigger 12v relay is maybe consumes a lot power so I think that's not an option...)
Because I need several devices the timing device should be relatively cheap. (Some dollars maybe)
Could you help me on this?
https://www.aliexpress.com/item/DC-5-35 ... 269.94dRrc
https://www.aliexpress.com/item/Widely- ... 278.Ff3j6e
https://www.aliexpress.com/item/Trigger ... autifyAB=0
Thank you.
