neilpercy
230V>5V power module
Thu Jan 04, 2018 3:43 pm
Hello All,
I've looked into this before but never found with (I think?) I am looking for....
I would like to use a mains voltage converter, 230V UK, to 5V (or 5.2V) to use inside an enclosure to power a Pi Zero W, ultimately to use for a remote access central haeting controller project, a bi like this https://www.youtube.com/watch?v=Guhf7eohl98 , or this https://www.element14.com/community/com ... er-project
Ideally I would like to buy a module rather than take a Plug adaptor apart, ideally with screw terminals for the 230V (fused) input (I don't want to have to install a plug socket just for the Pi (there's power for the controller there already)).
I have found some modules at RS/Farnell etc but they all seem quite pricey compared to a Plug style PSU - https://uk.rs-online.com/web/p/products ... lsrc=aw.ds
and some at stupid money(>£400).
I'm just not sure that I'm looking for the right thing....?
Any pointers much appreciated.
Cheers, neil
gordon77
Re: 230V>5V power module
Thu Jan 04, 2018 5:47 pm
The RS psu says £20.78 not £400.
Maybe this one, although maybe larger than you want..
https://uk.rs-online.com/web/p/embedded ... s/7703248/
neilpercy
Thu Jan 04, 2018 8:22 pm
no, but this one is !! - https://www.tu-eshop.com/230VAC-to-5V-1 ... ply-Module - Actually, I'm not sure what currency that is, I had presumed Euros but my browser doesn't display whatever it is properly.
(sorry, didn't express myself very well in the first post).
Thanks fort the input gordon, I was hoping to find something like 'base' board that they use in a regular plug PSU.
cheers, neil
pcmanbob
Thu Jan 04, 2018 8:54 pm
You could always buy a plug type psu and simply take it apart you often find there are wires connecting the PCB to the plug part so you can simply un-solder them. just be aware of the dangers of running an un-cased psu as the PCB will have mains on the tracks.
if you have the room you could always re-case the PCB in a small plastic project case.
HermannSW
Thu Jan 04, 2018 9:02 pm
... Actually, I'm not sure what currency that is, I had presumed Euros but my browser doesn't display whatever it is properly. ...
I just pasted "₹450.00 in $" into google and got this:
450 Indian Rupee converts to 7.10 US dollar
⇨https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://stamm-wilbrandt.de/github_repo_i420toh264
https://github.com/Hermann-SW/fork-raspiraw
https://twitter.com/HermannSW
mattmiller
Thu Jan 04, 2018 11:33 pm
In the interests of your safety - you really don't want to be mixing mains voltages inside the same enclosure as a Pi
neilpercy
Fri Jan 05, 2018 3:26 pm
Hi Matt, I don't mean to be flippant but could you explain why ? I respect mains electricty and fully understand the dangers when mishandled but I cannot understand why a PSU board properly wired would cause an increased risk inside an enclosure with a Rasp Pi ??
neil
mattmiller
Fri Jan 05, 2018 3:43 pm
Because you would have mains components next to the RaspPi - its really not that hard for a small error to cause fatal results.
in most countries - such a device would require certification and testing (for good reasons)
Much (by many orders of magnitude) safer to use a certified mains PSU and connect at the 5V DC level
Note
This is a recurring request on this forum and almost all the "old-timers" take it in turns to warn people from doing it :)
Imagine someone helped you with your quest and then things went very badly wrong....... :)
sparkie777
Fri Jan 05, 2018 4:15 pm
what speaks against:
- it's cheap
- it's secure
- needs no plug socket
- it's tiny size
