ranpitime
how to change the irq priority for nic / eth0
Tue Dec 05, 2017 8:53 pm
how could we change the prio for the irq for the eth0 network adapter?
How to do this?
BR
ranpitime
topguy
Re: how to change the irq priority for nic / eth0
Wed Dec 06, 2017 8:49 am
If the ethernet interface is on USB, is your question even relevant ?
Why not explain why you think you need/want to do this.
ranpitime
Wed Dec 06, 2017 4:04 pm
I need to have higher prio because we lose ethercat frames on receiving because the ethercat master is running in a prio/Task context
higher than the irq's are handled.
This is what I know and I try to change.
So i check which is the usb iqr by
cat /proc/interrupts
and then try to change the prio with:
sudo chrt -pf 70 62
But i fear this does not work because
does even show still the same prio for the usb irq
So maybe i'm totally wrong to do this that way?
Any suggestions?
BR
ranpitime
