rooster
raspberry pi power source
Mon Oct 01, 2012 10:02 am
I just got a Pi from maplin this morning. It contains a powered usb hub and a power source. also a note saying not too stress the usb sockets too much and to use the powered hub if necessary.
there was a discussion here once about powering the Pi from the usb hub so you don't need the power source for the Pi.
Has anyone done this? Does it work? I will try tonight but wanted to get some feedback incase it blows the Pi.
rew
Re: raspberry pi power source
Tue Oct 02, 2012 8:34 am
Yes, I've done it and it works.
That is: If you have a rev 1 board, there is a polyfuse between the "downstream" USB ports (those next to the ethernet) and the hub. So that won't be able to power a 'pi. You'll have to use a proper miniUSB cable between one of the ports of the hub and the power input on the 'pi.
If you have a rev 2 board, the datacable between the hub and the rpi might be able to carry power "upstream" into the 'pi.
This alll does depend on the hub being "cheap" in that they didn't separate the incoming and outgoing power rails.
Check out our raspberry pi addons: https://www.bitwizard.nl/shop/
simplesi
Tue Oct 02, 2012 8:44 am
The latter day rev1 boards had greenish polyfuses replaced with a black "zero ohm" components so if you've got the black ones you can power your RPi fine using the USB connector
regards
Simon
Seeking help with Scratch and I/O stuff for Primary age children
http://cymplecy.wordpress.com/ @cymplecy on twitter
