Waterproof Ultrasonic Distance Measuring Sensor
Posted: Tue Jun 21, 2016 2:24 pm
by Mettauk
Wondering if this "TE501" 5v sensor will work "off the shelf" with Pi/Raspbain in much the same way as HC-SR04 sensors do?
Anyone know of a tutorial or code examples/wiring?
http://www.ebay.co.uk/itm/Ultrasonic-Mo ... SwyjBW31Hd
Re: Waterproof Ultrasonic Distance Measuring Sensor
Posted: Tue Jun 21, 2016 3:22 pm
by joan
It looks like you wire it just like a HC-SR04 and use the same software.
Posted: Tue Jun 21, 2016 5:06 pm
by Mettauk
Maybe but if you look at one of the photos of the back there is a small jst socket??
Posted: Tue Jun 21, 2016 5:22 pm
by joan
I really think that is irrelevant (unless you have a JST plug you want to use).
Posted: Tue Jun 21, 2016 5:55 pm
by Mettauk
joan wrote:I really think that is irrelevant (unless you have a JST plug you want to use).
So its not a maybe for a 12v supply for the single sensor or sounder or display or....?
EDIT, just discovered that the jst IS the connector for the sensor to the board! :shock:
